Old September 28th, 2006, 03:14 PM   #1
4x4forlife
4x4forlife's Avatar
6.9 liter diesel
are these engines any good? because I just picked up a 1985 F-250 with one in it. it needs headgaskets though. just wondering what people thought about these engines. problems?
4x4forlife is offline   Reply With Quote
Old October 3rd, 2006, 12:56 AM   #2
junk90xj
ALLPRO AUTO
junk90xj's Avatar
ran one in my old tow truck for 250k never much to replace other than injectors,glowplugs and one a pump rebuild.
junk90xj is offline   Reply With Quote
Old October 3rd, 2006, 09:13 AM   #3
yup, run forever, except for the head gaskets usually are replaced every 180K or so. Injection pumps usually go bad at about the same time. Don't EVER use starting fluid on that motor though, it will cause head gasket failure. Just put in a block heater if it doesn't already have one (pretty cheap), keep the glow plugs and relays in good shape and it should start easily even in the coldest weather....
99 stroker
Old October 3rd, 2006, 10:38 PM   #4
4x4forlife
4x4forlife's Avatar
so how are these for torque and pulling things?
Old October 3rd, 2006, 10:56 PM   #5
ScOoTeR
667-Neighbor of the Beast
ScOoTeR's Avatar
170hp/318lbft They're pretty good for pulling things at low altitude.
Old October 9th, 2006, 12:28 AM   #6
busyfixin
busyfixin's Avatar
mine towed real well, only problem i had was the glow plug relay. they have good response from a stop too. i think they have more power than a 7.3 before turbo
Old October 9th, 2006, 12:12 PM   #7
smasheromalley
crapcharger
smasheromalley's Avatar
not even close, '89 7.3L IDI 180hp/360tq. They tow fine, jsut dont think theyre gonna steam down the road like a newer diesel.
still they are good old diesels. more prone to head gaskets/less prone to cylinder wall cavitation(than the 7.3). Still they use the crappy stanadyne rotary injection pump.
You may have to go thru the normal old diesel battery issues/leaking fuel system issues/glow plug issues. But once you get them ironed out they'll run trouble free. Mine started fine down to single digits F and colder and I never once plugged it in.
It is an 80s truck and it will tow like an 80s truck powered by an 80s engine. Back then it was a monster, today it is adequate.
go to www.thedieselstop.com for all the info you could want
smasheromalley is online now   Reply With Quote
Old October 22nd, 2006, 10:59 PM   #8
busyfixin
busyfixin's Avatar
i didnt say it had more power, its not even close. i mean before turbo, as in before the turbo spools, pre-boost, off-boost, when the turbo is not yet forcing air... the 6.9 has far more compression than a 7.3 turbo. this allows better power before the turbo spools. the turbo forces more air, which in turn builds your compression in the 7.3, not mechanically like the N/A 6.9.
Page generated in 0.17043 seconds with 29 queries
