| Jeep tech FAQ Look here first! |
I'm klklkjiouiy
Crawl Ratio Calculator
This is one of the better ones I have found, it is missing some trannys and tire sizes, but you can plug in what you want if it isn't listed.
Pretty good calculator that will show crawl ratio and speed @ 3K RPM Though I doubt your Jeep will actually be able to do 163 MpH @ 3K RpM with 44s and a NV3550 without some other modifications. :tonka: Play around with it a little, and see what different trannys and crawl boxs can do for your crawl ratio- a crawlerbox will do much more for less coin than regearing axles, in many instances. If you already know your gearing, use a calculator (Or Be a Man and figure it out in your head) Or, even better- you can use Jesus 's Nifty Keen Excel Sheet that Cooter can't use due to being only computer literate enough to be able to say "I would like a chicken salad sandwich" and "where is the bathroom, I have a burning in my loins" Last edited by Cooter; September 22nd, 2006 at 10:40 AM. |
#2 | |
http://www.greatlakes4x4.com/showthread.php?t=4384
#3 |
I'm klklkjiouiy
There ya go- I looked around a little, and didn't see it. Do you mind if I add it to the original post here. (I have to take your word on it working, I'm not able to start the apllication)
#5 |
so no autos huh? Interesting that the people that should be most worried about crawl ratios are rigs that run rocks, yet a manual is a nightmare in the rocks, and the calc doesn't have info for autos
#6 |
which also brings up the age old question of what gear reduction do you assume for a torque converter?
#7 |
I'm klklkjiouiy
Yeah, I noticed the same thing, but you can plug in your slushbox's ratio- TF999 is 2.74, IIRC. The auto/manual thing is kinda aplles to oranges anyway, as far as crawl rtios go- you can get away with a lot less with an automatic because of the torque converter. And once you get to 90/1 or lower, a manual tranny is a pleasure on the rocks, IMO.
#8 | |
I'm klklkjiouiy
#9 |
Yeah, at that 2:1 factor is mainly only there below stall speed.
I'd agree with Cooter, once you are properly geared, a manual rocks the rocks. In my truck I have overall final gears of: 100:1 59:1 44:1 37:1 26:1 25:1 22:1 19:1 16:1 12:1 11:1 9:1 7:1 5:1 4:1 At 100:1, even the wimpy 22RE idles up rocky steambeds with no bashing, no throttle needed. Downhill is slow enough that I'm on the gas to go downhill.
#10 |
The Green Machine
Here is a good site that lists trans ratios if your not sure what yours is...
http://www.vibratesoftware.com/html_...nsmissions.htm
88 MJ, 4.7L, 35's, Caged, Long Arms, ARB, xd9000i |
#11 |
Hack
Here's another calculator:
http://www.grimmjeeper.com/gears.html |
| Thread Tools | |
| Display Modes | |
