Mischievous Badger
D44 front, ford 9 inch?
i might be getting a D44 front 8 lug. but i have a 9 inch rear axle with the 5x5.5 bolt pattern can i change the 9 inch to an 8 lug or would it be cheaper to change the D44 to a 5 x 5.5 ??
also is there any write ups or information on both of those options?? yes i have searched |
#2 |
Support the Sport!
I've not researched the price but I'm betting that it would be cheaper to do the front. DO you already have rims for 5 on 5.5? Cuz that would save some cash too. For the 44 they cam in 5 on 5.5, 5 on 4.5, 6 lug and 8 lug versions. Earlier fords like 71-77 broncos were 5 on 5.5 as were 78-79 Ford Bronco, F-150, F-250, 74-80 front scout II's
You should be able ot find rotors from one of those models that will fit your spindle and junk. It might help folks to know where this 8 lug is comign from to give you an even more specific answer. |
#5 |
Low Range Drifter
check this out
My recommendation would be to take of the 8-lug parts and put them on the shelf. Do not sell them. Then, if you want to upgrade to a 14-bolt, d60, or d70, you'll have the parts in hand. If you have not plans for high-steer, go pull the knuckles out off any old ford d44 (ttb is fine), grab the outer shafts. If you want high steer (or the option to use it later) find a set of chevy or FSJ flat top knuckles and the small bearing spindles, and use the ford parts listed in the link and go that route. |
#14 | |
2003 Dodge Ram 1500 Hemi 35's 1989 s10 D44's D300 38's Locked and Loaded 2000 Honda 400EX UNLIMITED OFF ROAD CENTERS 810 936 7000 |
| Thread Tools | |
| Display Modes | |
