Mischievous Badger
Front GM 10 bolt ???
some crazy questions
i know that a D44 and a 10 bolt are very similar but will a front D44 carrier fit into a Front GM 10 bolt housing? also i know that a rear GM 10 bolt has 30 spling shafts. so can i use the rear 10 bolt spyder gears for 30 spline and stick front Dana 44 shaft into a 10 bolt housing? that should test ya |
#2 |
The D44 carrier will not fit in the 10 bolt. Why not just put the whole carrier in instead of just the spiders. I believe the hub on the 30 spline is bigger then the 28 spline. As far as the spline fitting it should. but I believe the shafts are short and long 1/2 between the dodge and a chevy. Find you a newer housing from a 88-90 suburban they will have 30 spline shafts in the front.
I cut the hole twice and it's still to big ![]() MEMBER OF: SWAMP STOMPER'S 4x4 CLUB UNITED FOUR WHEEL DRIVE ASSOC. DIXIE CRAWLERS 4x4 CLUB |
#4 | |
:tonka:
Doing business with "Kennedy" on GL? See this thread for details. Doing business with "Silver Bullet" on GL? He'll leave you Negative Feedback without even doing business with you. See this thread for details. |
#6 | |
2003 Dodge Ram 1500 Hemi 35's 1989 s10 D44's D300 38's Locked and Loaded 2000 Honda 400EX UNLIMITED OFF ROAD CENTERS 810 936 7000 |
#7 |
I have some backing plates I'll sell ya...
#8 | |
| Thread Tools | |
| Display Modes | |
