Old August 25th, 2006, 09:38 AM   #1
sinnaevd
Engine Trouble
I have an 87 chev with a 305, fuel injected. It starts upi and idles like a dream, but when it revs up it kind of sputters and hesitates a little. after a little hwile it will go like its suppose to but it takes some time.
anyone have any ideas? i was htinking distributor??
TIA
sinnaevd is offline   Reply With Quote
Old August 25th, 2006, 10:18 AM   #2
Yankabilly
could be a TPS issue. Take an ohm's reading of the TPS and match it to a chilton's manual.
Old August 25th, 2006, 10:28 AM   #3
more info needed-
does it only act up when the engine is hot?
only when cold?
any notice in mpg?
When you say "after a little hwile it will go like its suppose to" do you mean a second or two, or what?
99 stroker
Old August 25th, 2006, 10:52 AM   #4
sinnaevd
haven't been driving it enough to know about MPG or when its hot, sorry.
when i say after a fews seconds, i mean about 10 or 15 seconds. but when you let it back down to idle, and then try it again (wihtout shuting off the engine) it does the same thing. engine has about 160,000 mi if that helps at all. Thanks guys (and gals).
Old August 25th, 2006, 10:54 AM   #5
sinnaevd
are new TPS expensive?
Old August 25th, 2006, 11:28 AM   #6
Yankabilly
I would say around $50... but I wouldn't uy it until you do some diagnosing.
Old August 25th, 2006, 12:09 PM   #7
sinnaevd
absolutally, thanks for the suggestion
Old August 25th, 2006, 01:37 PM   #8
AWK
AWK's Avatar
1. Disconnect TPS electrical connector.
2. Remove two TPS attaching screws, lockwashers and retainers.
3. If equipped, remove screw attaching TPS actuator lever to end of throttle.
4. Remove TPS.
5. With throttle valve(s) in normal closed idle position, install TPS. Ensure TPS pickup lever is located above tang on throttle actuator lever.
6. Apply suitable thread locking compound to screw threads, then install retainers, lockwashers and screws. Adjust TPS. Refer to "THROTTLE POSITION SENSOR (TPS), ADJUST" for procedure.
All-data says that the voltage should read .48 volts. for the 5.0 non california
AWK
AWK is offline   Reply With Quote
Old August 25th, 2006, 03:35 PM   #9
sinnaevd
Thanks for the stats AWK, i will try and fix it this weekend.
Old August 25th, 2006, 09:42 PM   #10
user name
user name's Avatar
sounds like it has really bad hesitation? i would go with the K.I.S.S. method and think fuel filter. then again im probly wrong
Old August 26th, 2006, 08:18 AM   #11
sinnaevd
No offense but i hope you car because then i would probably end up doing all the fuel lines wiht the fuel filter(they are getting a little on the rough side it seems) lol
the person i bought it off of said that he thought it was the TPS as well, so i will give it a check.
like i said be4, i'm new to this kinda stuff and i have never changed a fuel filter be4, is it as simple as i'm thinking it would be? I was kinda htinking it would be best to change that n e way.
TIA!
Page generated in 0.18139 seconds with 35 queries
