My truck is a 1983 longbed frame (1st gen) which was better than all of my 2nd gen frames, which were rotted to poo.
The key area to check on your frame is the sections all around the front hanger for the rear springs. That area where it bends up, especially on the inside of the rails. Get a hammer and a big chisel or screwdriver, and tap on the frame all over, looking for soft spots. I had to re-plate my frame in this area on the insides of the rails. My 85 trucks broke at the front spring hangers. Its all too typical for MI. I run a 2nd gen xtra cab on my truck, though, for the extra room, and my 83 cab was rotten.
The doubler, yes, a double t-case. The early transmissions were shorter than the later ones, which debuted in 1984. Most likely you have a L43 or something, although you might be getting a spare L52 in that deal? The L52 is the strongest of the early short transmissions, its what I run in my truck. The doubler added about 7" of length which helped me out a lot for my front drivershaft angle. My rear shaft is still 48" long.
The rears-up-front FAQ here at pirate answers most questions. For me, I run my stock 83 rears up front, with the overloads removed, and 3 leaves from an 85 rear pack added to them.
http://www.pirate4x4.com/forum/showt...ht=rears+front
I use 2nd mid 90s chevy 1/2 ton springs, with the overloads cut to 7" long to serve as a block. My setup is unusual, in that I use the stock shackle hanger, and then relocated my front hanger 15" forward from stock. This moved the axle forward 4" but I had a longbed, so didn't mind. My front axle is also 4" forward of stock, so I still have about a 108" wheelbase, which works extremely well offroad.
I fab my own parts, so it was cheap. I did my complete lift, including 13" travel shocks, front shock mounts (ford f250), marlin crawler extended brake lines, springs, etc, for about $300. Flexes/rides well for my trail truck.
The front springs are pretty much a bolt it. The stock rear springs are about 3" longer than the stock front springs, so running a boomerang shackle is a good idea. You can also use YJ lift springs, or Wagoneer springs up front as well.
The chevy rear springs require a new front hanger to be welded to the frame. All of my shock mounts are non-stock, except the front lower mounts.
