Old December 6th, 2005, 09:32 AM   #1
Lets do it! Break it down
Poop Pipe Info!
OK, since I do work on my truck with pipe, thought I'd post a little info.
Pipe is Pipe and Tube is Tube, they are different.
Tube is measured by outside diameter and wall thickness.
Pipe is 'measured' by inside diameter and schedule (wall thickness)
However, pipe is still a standard OD, and the ID varies based on the schedule. So for a 1-1/4" pipe, the OD is 1.66". Schedule 80 would have a smaller ID than Schedule 40...etc..
There's a lot of misinfo about pipe, people thinking its brittle, weak, etc. Not really true. There are a lot of different types of pipe, just like there are lots of types of tube. So getting the right material, no matter what you do, is the key to getting strong material. You will find plenty of circle track cars with pipe-built roll cages, which are going to have higher impact forces than on most any 4x4.
There are lots of types of pipe out there. Going to the home depot and buying a 10 chunk of pipe you don't know what you are getting, and its propably crap. Some types of pipe might be butt welded, so there are butt seams in the pipe that may be weak. Some types might be a weaker iron that leads people to think of the pipes being brittle.
A common one used in building cages is ASTM A53 type S grade B.
This is a carbon steel pipe, with a yield strength of 35,000 psi, and tensile strength of 60,000 psi.
I personally use ASTM A500 grade B, which is a carbon steel pipe known as structural tubing. The A500 standard actually covers both rounds and shapes such as sqaure tubing, and is often what you are buying when you buy square & rectangle tube. It is known as tubing although the rounds are available in pipe sizes. It is specifically designed for use in structural applications, and not going to be brittle or weak like people think. Min yield strength is 42,000 psi, tensile strength is 58,000 psi.
For most roll bars, bumpers, sliders, etc, 1-1/4" schedule 40 makes a nice size. That is a 1.66" OD, with a wall thickness of 0.140". Currently, a 21 ft stick of A500b 1-1/4" sch 40 runs about $35 at Pontiac Steel.
I am using 2-1/2" sch 40 for my rear driveshaft, as well.
Haggar is online now   Reply With Quote
Old December 6th, 2005, 09:40 AM   #2
Nominal Pipe Size OD Nominal Pipe Sizes Wall Thickness
--------O.D.-----Sch. 5 Sch. 10 Sch. 40 Sch. 80 Sch. 160 XXS
1/4"---0.540”----N/A----.065-----.088-----.119-----N/A-----N/A--
3/8"---0.675”----N/A----.065-----.091-----.126-----N/A-----N/A--
1/2"---0.840”----.065---.083-----.109-----.147-----.187-----.294-
3/4"---1.050”----.065---.083-----.113-----.154-----.218-----.308-
1"-----1.315”----.065---.109-----.133-----.179-----.250-----.358-
1-1/4"-1.660”----.065---.109-----.140-----.191-----.250-----.382-
1-1/2"-1.900”----.065---.109-----.145-----.200-----.281-----.400-
2"-----2.375”----.066---.109-----.164-----.218-----.343-----.436-
2-1/2"-2.875”----.083---.120-----.203-----.276-----.375-----.552-
Old June 15th, 2006, 02:03 PM   #3
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
How do you poop down a 1-1/4" pipe?
Old June 15th, 2006, 02:53 PM   #4
Play-doh fun factory..
Old June 15th, 2006, 03:31 PM   #5
mschaffer66
So what you are saying is the right pipe and a cheap harbor freight pipe bender could be a cheap solution for someone that wants to do some tube fenders, bumper, etc... on the cheap?
mschaffer66 is offline   Reply With Quote
Old June 15th, 2006, 03:34 PM   #6
Chop
Mischievous Badger
Chop's Avatar
yes i believe that is what he is sayin
Old June 15th, 2006, 04:12 PM   #7
Yup.. Funny, I posted this info 6 months ago..not sure why the joke was made today..
But, yes, proper graded pipe is quite strong. If you take your time, you can get some good results.
Not as nice as a bender, but I can get close to 90* bends pretty well. All of the tube work on my truck is done with it.
The bender looks like this:
So, you can see here, when I did the main hoop, you can do fairly complex parts
Its actually easier, IMO with a pipe bender than a tube bender, to get your piece correct, because the center of the bend stays at the center of the die, instead of the camming action of a real bender, where its 'grabbed' and 'pulled' around the die. On a real bender, you need to learn where the reference points will end up after you bend a piece.
BTW, the pics, thats 1-1/4" Sch 40 A500 grade B, so thats 1.66" OD with a 0.140" wall, which is stronger than the usual mild steel HREW 1-5/8" 0.120" wall that most people use.
Old June 16th, 2006, 01:35 AM   #8
RDK_YJ88
Comagoneer
RDK_YJ88's Avatar
where do u buy ur pipe (sry if you already said it but i didnt see it)
RDK_YJ88 is online now   Reply With Quote
Old June 16th, 2006, 08:39 AM   #9
Pontiac Steel
479 University Dr
Pontiac MI
248-858-2350
Usually about $35 for a 21 ft stick with two flame cuts.
Old June 16th, 2006, 10:03 PM   #10
mschaffer66
How about welding? Pretty much the same strength as welding other mild steel?
Old June 19th, 2006, 01:06 PM   #11
junk90xj
ALLPRO AUTO
junk90xj's Avatar
what size die did you use for that pipe
junk90xj is online now   Reply With Quote
Old June 19th, 2006, 01:30 PM   #12
Yes, its mild steel structural rated tubing, in pipe sizes.
Again, there is lots of types of pipe, just like lots of types of tube.
What I used in those pictures is carbon steel, not cast iron or anything.
Old June 19th, 2006, 01:31 PM   #13
I realize this might be shocking... but I used the 1-1/4" pipe die for the 1-1/4" pipe.
Old June 19th, 2006, 01:40 PM   #14
Blackjackbender
any pictures of a complete 90 degree bend? was thinking of building tube(pipe) fenders with one of these if possible.
Old June 19th, 2006, 01:53 PM   #15
kevsCJ7
kevsCJ7's Avatar
I used sched.40 for my front fenders and the HF bender did a 90 bend just fine IMO.
kevsCJ7 is offline   Reply With Quote
Old June 19th, 2006, 01:56 PM   #16
Blackjackbender
sweet, any pictures?
Old June 19th, 2006, 03:12 PM   #17
kevsCJ7
kevsCJ7's Avatar
I'll try and get some tonight.
Old June 20th, 2006, 09:30 AM   #18
kevsCJ7
kevsCJ7's Avatar
Heres some pics.
Not sure if they'll help or not.
ID:	1351  Click image for larger version
ID:	1352  Click image for larger version
ID:	1353  Click image for larger version
ID:	1354  Click image for larger version
Old September 26th, 2006, 06:57 AM   #19
artistic_gore
I own @ halo
artistic_gore's Avatar
Send a message via AIM to artistic_gore
Haggar,
What were the dimensions of your main hoop? I would like to copy it but don't want to mess with all the damn prep work that any normal human would have to do, like measuring.
artistic_gore is offline   Reply With Quote
Old September 26th, 2006, 08:51 AM   #20
Dunno, I just measured, transfered the measurements in chalk to the garage floor, and fabbed it.
Considering I have a 2nd gen xtra cab on a 1st gen frame with modified body mounts and an indeterminant amount of body lift, I'd just measure your own truck and see.
Tags
acid shit pipe
