Old August 22nd, 2006, 01:34 PM   #1
Symmes
Location: Grand Rapids/Wyotech blairsville pennsilvania
Send a message via AIM to Symmes
Horrible gas smell
I have a 95 tahoe, and there is a horrible gas smell from the truck. It doesnt leave a spot of gas on the drive way, and there isnt any spots on the tank. ANY ideas???
thanks
jake
Symmes is offline   Reply With Quote
Old August 22nd, 2006, 03:42 PM   #2
SS
Resident Tanker
SS's Avatar
Send a message via AIM to SS
Look at your intake manifold and see if it looks wet right when you park it after a drive
It might be your injectors leaking from the o-rings
Does it crank a little longer to start it then before it started smelling like gas?
SS is offline   Reply With Quote
Old August 22nd, 2006, 08:17 PM   #3
Maybe a line is starting to rott out and is leaking enough just to spread and smell. Could have a bad rubber line on top of the tank.
Old August 22nd, 2006, 08:49 PM   #4
are you one of those guys who click the gas nozzle ten times to get every drop in it? if so you have filled the charcoal canister with gas and now its venting it out instead of filtering the fumes
Old August 23rd, 2006, 11:38 AM   #5
Symmes
IM going to have to look at that because it is defintally taking longer to start than it did before.
thanks jake
Old August 23rd, 2006, 02:00 PM   #6
shredder70
Chillin with the top off.
shredder70's Avatar
Also check the fuel pressure regulator for leaking.. Take the vacuum hose off (if you can get to it) And see if it is leaking past the diaphram.. That will also give you a hard start intermittently..
Not sure if this applies to your year and make.. Also check and see if the hose to canister next to radiator is off..
shredder70 is offline   Reply With Quote
Page generated in 0.14004 seconds with 25 queries
