Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
Old December 2nd, 2005, 07:02 AM   #1
Tonka
tire plug kit use #2
Tonka's Avatar
tj heat selector issues and repairs
your tj stuck on defrost?
heat only work on certain speeds(if any) ?
click here.
http://www.jeepforum.com/forum/showt...6&page=1&pp=15
Old September 11th, 2006, 10:37 AM   #2
Mookie
Mookie's Avatar
Location: Dearborn(home of hommous, Fattoush, tabbouli), Wayne County, Michigan
Send a message via AIM to Mookie Send a message via MSN to Mookie Send a message via Yahoo to Mookie
Im going to look up my vacuum lines but i do have one problem, I have 4 ports for vacuum lines to go into my intake manifold but only 2 hoses coming out. the open 2 holes are plugged but i do not know how many im actually supposed to have being used. why in the hell would i have 4 ports for only 2 to be used.
Mookie is offline   Reply With Quote
Old September 12th, 2006, 08:27 PM   #3
Tonka
Tonka's Avatar
The manifolds were designed for multiple applications.
Some vehicles use the extra ports, others do not.
Old September 12th, 2006, 11:08 PM   #4
Mookie
Mookie's Avatar
is there a way that i can find out what i am/am not supposed to use? i have a 97 tj with ac and a 2.5 engine.
Old September 13th, 2006, 02:02 AM   #5
Tonka
Tonka's Avatar
Where are you located?
Has anything been messed with before?
Do you have a current issue
(say heat not working right) that you are trying to solve?
Old September 13th, 2006, 09:44 AM   #6
Mookie
Mookie's Avatar
I'm in dearborn.
Not that im aware of, i bought the jeep in feb/march of this year during the week when the temps werent so bad
yeah, the blower doesnt blow the heat out of the right vents and im looking to see where that problem is, the heat also doesnt blow so hard. when i switch the selector switch to cold though, the air blows good but still doesnt get redirected.
Old September 16th, 2006, 01:52 AM   #7
Tonka
Tonka's Avatar
your problem is probably one (or more) of three plastic arms for the vacuum actuators that controll the vent doors.
they are located under the dash, near the level of the heater controls, on the driver's side.
Mine broke, and I was stuck with the default defrost mode.
I added red arrows to a factory servic manual pic. They point to the plastic pieces theat break internally and cause the condition you described.
Name:	tj plastic parts that cause default defrost.JPG
Old September 16th, 2006, 04:48 AM   #8
Mookie
Mookie's Avatar
i found one of the broken arms, now i just have to get the time to fix it in the next week. it sucks getting my 6'4'' frame in there.
Old September 17th, 2006, 11:38 PM   #9
Tonka
Tonka's Avatar
I'm 5'10" and it's a pain. I pulled the plastic and the metal panel off under the steering column. It hepled a little.
Page generated in 0.17372 seconds with 32 queries
