Old July 5th, 2006, 11:12 PM   #1
xlinkinpark2438x
03 Rubicon
xlinkinpark2438x's Avatar
92 Explorer running problems
I have a 92 explorer and today drove it from taylor to newport about 30 min drive and a couple of hours later i filled up on gas and came back to taylor and it ran fine and about an hour after i got back i went out to go somewhere nd my truck sounds like it hs a miss and is running rough. soo i took it around the block thinking that it just got carbon build up or something nd would just clear up but that did not help at all. i opend the hood and notice that there was gas on the connection from the manifold to the rest of the exhaust (not a perfect connection there) and figured a miss soo i checked all of my plug wires and they are all good. and the plugs were petty black soo i bought all new and that did no difference. soo i tried to narrow doun the problem and ran the engine on just the three cylinders on the passenger side and then on the driver side and noticed that the driver side 3 cylinders ran worse soo i had just those three connected and disconnected them one by one and found that the front cylinder on the driver side is not making any difference when i unplug it and plug it back in. and i am getting spark to the spark plug. and i am getting gas i know because i am getting gas leaking out at the manifold. i was woundering what anybodys thoughts are. and just for the record the truck has 290,000 miles and has been running exelcent for a while now i have driven it from 7oclock in the morning till about midnight doing escorting for manufactured homes a couple of times this year and ran exelcent. and now been using it to drive to and from work which is about 30 minutes away. i was planning on using it to tow my jeep to silver lake sand dunes leaving friday morning soo any help would be great.
thanks
xlinkinpark2438x is offline   Reply With Quote
Old July 6th, 2006, 06:18 AM   #2
given the long run you gave it I would suspect the egr valve is stuck open, pull it off and clean out the valves seat and reinstall, it should cure the bad idle. the fuel leak should be delt with or you could burn up the truck.
Old July 6th, 2006, 09:56 AM   #3
xlinkinpark2438x
03 Rubicon
the only problem with that one is that there is no egr on this truck and the gas is coming from one or all of the cylinders from flooding itself.
Old July 6th, 2006, 11:06 PM   #4
offroad86b2
offroad86b2's Avatar
Send a message via AIM to offroad86b2
a friend of mine bought a 96 and it ran rough like it was missing,he replaced all the sencers and it still did it...then he rebuilt the engine and still the same missing...it ended up being the computer,something was shorting out in it.So i dont know the diffrents in computers between a 92 and 96 but thats what was wrong with his...Good luck
offroad86b2 is offline   Reply With Quote
Old July 6th, 2006, 11:22 PM   #5
xlinkinpark2438x
03 Rubicon
yeah ill try the computer from my other explorer and see if that helps. hopefully it does because if not i am driving the jeep there Thanks
Old July 8th, 2006, 06:45 AM   #6
biggs-cj
biggs-cj's Avatar
i had that problem twice .first time was a bad fuel regulater.....second was the fuel pump & ignition relay switches
biggs-cj is offline   Reply With Quote
Old July 8th, 2006, 11:27 AM   #7
MuddyPaws
Boink
MuddyPaws's Avatar
If it had an egr, and was stuck upen, it would effect ALL cylinders, not just one. And it would run fine under power. He says the miss is still there.
BUT
You guys are missing what he said.
Basicly he did a cylinder balance test. Pull a plug wire one at a time and see if the rpm drop. All cylinders should drop about the same. He found one cylinder that does not drop any rpm so that means that that cylinder is not firing for some reason. This cylinder is his problem.
He replaced the plugs, so not that. He says he has spark there, so not the wire.
What do you need to make an engine run?
Fuel
Air
Compression
Spark
What is he missing?
He says he has fuel, air, and spark.....
I would do a compression test on the cylinder. The fluid he is seeing on the exhaust doughnut area could be coolant. There is no way it could be running and have raw fuel coming out of the cylinder, going down the inside of the maifold and leaking out the exhaust connector. It would either catch fire inside the exhaust from the other cylinders blowing fire out the ports or it would evaporate from the heat before it got to the exhaust connector.
I call head gasket...explorers are good for those.
Old July 9th, 2006, 05:08 PM   #8
xlinkinpark2438x
03 Rubicon
BUT
Fuel
Air
Compression
Spark
What is he missing?
actually when i was checking if the spark plugs were getting spark it caught on fire at the exhaust doughnut area soo i would imagine that it was gas. and like you said i dont see how it got there it should of burnt up or evaroprated. and i just got back from silver lake and i am going to do an compression check on it when i get the time and when i feel like messing with it for now i got my jeep to drive. but thanks for the advice hopefully i will get it going
Old July 9th, 2006, 07:07 PM   #9
xlinkinpark2438x
03 Rubicon
i just went out there to check it out again and there is also oil at the exhaust manifold connection to the rest of the exhaust and i smell gas in the oil and looked in my radiator and i dont see any antifreeze. i do not think that it overheated because i usually watch all of my guages to make shure they dont go over the half way mark. (but maybe i didnt notice it) so i am not forshure that that it didnt overheat i also see some oil on that side of the block looked to be coming from the head gasket.
i was woundering on your thoughts on if it could be a bad head gasket, or bad piston rings or both thanks
Old July 9th, 2006, 11:41 PM   #10
MuddyPaws
Boink
MuddyPaws's Avatar
The more you type, the more I think head gasket.
Old July 10th, 2006, 09:59 AM   #11
xlinkinpark2438x
03 Rubicon
thats what i am going to hope it is but its just going to sit for a lil while until i feel like messing with it and if i find out more bad news i might just sell it and use my jeep as a daily driver wntil i get enough money to buy a newer truck.
but thanks
Old July 11th, 2006, 02:31 PM   #12
biggs-cj
biggs-cj's Avatar
there good for melting the first piston on the drivers side also
Old July 11th, 2006, 02:55 PM   #13
ScOoTeR
667-Neighbor of the Beast
ScOoTeR's Avatar
fuel injector on "faulty" cylinder stuck open.
Old July 11th, 2006, 03:15 PM   #14
Yup, thats what I thought here:
http://www.greatlakes4x4.com/showthread.php?t=15262
Old January 10th, 2007, 11:22 AM   #15
I would do a lot of things before I did the headgaskets....
#1- Go to Autozone and see if any codes are set
#2- compression test
#3- swap fuel injectors from one cylinder to another, see if the problem follows the trade
#4- buy new spark plug wires
#5- pay a cheap shop to run a coolant compression/leak test
94 Powerstroke, roallin' coal
Page generated in 0.28130 seconds with 43 queries
