Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech
Old November 5th, 2005, 10:21 PM   #1
Grandman
do i look old !
Grandman's Avatar
Jeep 5.2 V8 motors
Heres a little heads up im just ran into . I own a 94 Grand 5.2 , do to miles i tore down an extra motor i had to rebuild out of a 95 grand .
Well the heads up is the heads . Seems there very prone to cracking . This motor ran fine as does my current motor but once its tore down you find there is stress cracks between the valves . Given it is a design flaw its near impossible to find good used ones and the best price iv found on bare heads is $ 275.00 each .
Also these are roller cam engines , there the Magnum design and a rebuld kit will run you near $600.00 With out machine shop work or labor you looking at $1200.00 dollars in parts .
The good news is , the one i tore down still ran good and had 240,000 miles on it . They do last well .
Old November 5th, 2005, 11:33 PM   #2
GerkTJ
so even with the cracks they are not leaking antifreeze into cylinders?
GerkTJ is offline   Reply With Quote
Old November 6th, 2005, 12:24 AM   #3
GreaseMonkey
Ho Ho Ho Bitch!
GreaseMonkey's Avatar
Check out www.manciniracing.com for any Mopar motor parts you might need. I've gotten quite a few stuff from them for the 440 BB I'm rebuilding.
Old November 6th, 2005, 12:27 AM   #4
Grandman
do i look old !
Grandman's Avatar
Nope no leaks , but its like a time bomb so im not putting them on a new motor . My whole point is to reagain reliability .
Its not uncommon to have heads that dont leak but magnuflux them and find cracks .
Old November 6th, 2005, 12:31 AM   #5
Does the 360 from the 98 Limited use a different head? Might want to see if they are compatible.
Old November 6th, 2005, 12:55 AM   #6
h8pvmnt
Swamp Stomper
h8pvmnt's Avatar
Naw magnum heads are magnum heads from what I understand. You can get heavy duty replacement style heads or the magnum r/t mopar performance heads, with hardened inserts instead of induction hardened seats, which prevents the cracking. A good site for small block stuff is :
www.hughesengines.com
They have a nice 420 c.i. small block for the 5.9's
h8pvmnt is offline   Reply With Quote
Old November 6th, 2005, 06:13 AM   #7
Grandman
do i look old !
Grandman's Avatar
The thinkg that is causing the cracks is the new shape of the combustion chamber . The heart shape is causing a hot spot . Yes 5.2 or 5.9 either one is having the same issues .
Again there is options , theres just no cheap option on it .
Old November 6th, 2005, 08:51 AM   #8
5.9zj
5.9zj's Avatar
nope same head as all 360. Even the dakota rt's have the same heads, even though some of those guys think they have the R/T heads. There are some expensive alternatives, mopar R/T heads and edelbrock aluminum heads.
5.9zj is offline   Reply With Quote
Old November 8th, 2005, 01:51 PM   #9
84Scrambler
NObama!!!
Send a message via AIM to 84Scrambler Send a message via Yahoo to 84Scrambler
Yep, all 5.2 and 5.9 magnums have the same heads. I had the same cracks on my '96 5.2 heads. Both were cracked between the inner most cylinders. It is all too common with these motors. I have a set of 2.02 Mopar Magnum R/T heads sitting in the garage, but those are a little more than $275 a piece. ;)
'84 Scrambler - D60 rear, D44 front, 258, T-18, caged, leather seats...
'87 Grand Wagoneer "Ken's Jeep"
'98 5.9 Limited ZJ
'04.5 Dodge Ram 3500 CTD
'04 Take-3 37' Gooseneck Car Hauler
'07 Forest River Wildcat 32QBBS Fifth Wheel Bunkhouse
84Scrambler is offline   Reply With Quote
Page generated in 0.17498 seconds with 31 queries
