Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Tow rigs and trailers
Old June 23rd, 2006, 01:08 PM   #1
Driveshaft Eliminator!
Trailer winches ??
What do you recomend.. I was reading over on pirate about them and wanted some opiniona from you.. i saw a 2k unit at Harbor Freight last night for 60 bux and thought about it.. I figure use a block and double line pull it would work...
Any thoughts on this unit. or any recomendations on others without breaking the bank..
Andy
Old June 23rd, 2006, 01:39 PM   #2
Lets do it! Break it down
I'd imagine it would work..
I still am using my old ratchet style hand winch, which has been enough power for anything i put onto the trailer so far.
Just watch to not overheat/burn out the motor, that would be my guess to the weak link.
Old June 23rd, 2006, 02:45 PM   #3
I would go at least 4K... just wait until you bend a tie rod so you are toe-in or have ac aliper seize or have flat tires and have to pull the rig up the ramps with the wheels locked....
A 2K would be fine if the rig had 30psi in the tires and rolled freely, but then you wouldn't need the winch....
EDIT- a problem with the 2K winch is that the spool is only long enough for 50' of wire that is only rated at 2K lbs. Put a snatch block on it and your wire is only good for 4K (kind of) and is only 25' long
99 stroker
Old June 24th, 2006, 01:00 AM   #4
trailer is only 18ft and the price is right so i think i may go with that unit.... once i get some dough ill upgrade...
Andy
Page generated in 0.11187 seconds with 21 queries
