Old May 31st, 2006, 03:02 PM   #1
A/C Clutches...
Anyone replace one? All I can find in the parts store is the whole unit, they tell me the clutch is non-replaceable, but what the hell do they know
Old May 31st, 2006, 03:18 PM   #2
I think I may be in the same situation right now. My shit won't turn on and power is present all the way to the compressor. Is yours slipping, or non-responsive?
Old May 31st, 2006, 06:04 PM   #3
GreaseMonkey
Detroit Lions! 0-4
GreaseMonkey's Avatar
Just replace the entire unit....even if the clutch is servicable, you will more than likely fukc it up when taking it off.
Old June 1st, 2006, 09:20 AM   #4
I probably won't screw it up.
Old June 1st, 2006, 09:21 AM   #5
On the way home from Baldwin this weekend, I lost A/C, then smelled smoke. Today the clutch is screaming when off and won't engauge.
Old June 1st, 2006, 09:34 AM   #6
Old June 1st, 2006, 08:52 PM   #7
MuddyPaws
Boink
MuddyPaws's Avatar
I have replaced many clutches....never had to replace the whole compressor. With the clutch kit you get the bearing/pulley, the magnet coil, and the driven plate along with the shims for installing the clutch.
Old June 1st, 2006, 09:51 PM   #8
I have done a few as well... what threw me off is no one offers a clutch kit for my truck...
At any rate I got a full compressor from a yard on the way tomorrow, I guess I will see if the clutch comes off
Old June 2nd, 2006, 12:25 AM   #9
4x4inAllDay
Dodge Father-Ram Daughter
4x4inAllDay's Avatar
Send a message via AIM to 4x4inAllDay
mine just started squeeling the other day... its REALLY irratating and my a'c doesnt work that well now...
wtf?
4x4inAllDay is offline   Reply With Quote
Old June 3rd, 2006, 03:22 PM   #10
MuddyPaws
Boink
MuddyPaws's Avatar
wtf?
It's broke.
Old June 4th, 2006, 04:30 PM   #11
Well?
Old June 5th, 2006, 12:31 AM   #12
4x4inAllDay
It's broke.
your quick
Old June 7th, 2006, 12:19 AM   #13
Well?
Just got it done last night... it came off just fine.
1. Remove nut on compressor shaft.
2. Slide off outer wheel.
3. Remove snap ring.
4. Pull serp pulley (use a pully puller, I used a prybar... gently)
5. Pull next snap ring.
6. Pull magnet.
Then install the new parts back in. Took maybe 30 min?
I have a bare working compressor for sale now if anyone needs one
Old June 7th, 2006, 09:36 AM   #14
Chop
Mischievous Badger
Chop's Avatar
HAHA
Old June 7th, 2006, 10:00 AM   #15
6. Pull magnet.
The Dealer was surprised when I mentioned that you couldn't find a clutch kit. They thought they were available in the aftermarket.
Anyway - they claim my lines are leaking. The compressor apparently does not turn on when there isn't enough refrigerant in the system? I'm not 100% sure if I believe it, but a leak after 8 years is reasonable. The real problem was that nobody local had the lines and they had to order them from Dallas. That would take a couple days and does not help me for this weekend, when I need to use the truck on some long runs. This was the factory charge I finally lost, mind you. Whatever leak there is, its not that big. What they didn't actually tell me was whether the compressor ran after they did the test charge this morning - I just called back for that specific piece of info. If the bitch does run, I'm going to order the lines, charge it for the weekend, and get the work done next week.
If it doesn't, I may take that compressor off your hands. What's the part # and actual motor/year it was pulled from?
Old June 7th, 2006, 12:48 PM   #16
It was pulled from a 95 dak.
Model U 4605.
There is a MIN and MAX refrigerant pressure window in which the CPU will engage the clutch.
If it's a slow leak you could buy a refil kit with some gauges and fit it to the highside of the limit and it would probably last all weekend if not longer.
Old June 7th, 2006, 01:09 PM   #17
Yeah, that's the plan - if these asshats at Szott Dodge would call me back to confirm that the compressor actually works. I'm beginning to suspect that they did not test charge it and assumed it all leaked out because I brought it to them evac'd, even though I told them that it was evac'd.
Old June 15th, 2006, 04:14 PM   #18
noodles
give 'er sh*t ay?
noodles's Avatar
did you find a clutch kit? becasue i cant find one and i would like to get my ac working again.
Old June 15th, 2006, 09:27 PM   #19
6. Pull magnet.
He found one on the end of a compressor. :tonka:
Old June 16th, 2006, 03:00 PM   #20
noodles
give 'er sh*t ay?
noodles's Avatar
thanks for the help... lol is there anyother way to get a clutch??? thats what im getting at.
