Bike Dude
Heavy duty t-case crossmember
Well i bought some steel yesturday, went a little over board and cam back with a piece of 2x5 1/4" wall tubing and other stuff. Im going to make this into a tcase crossmember.
Whats your opinion? |
#2 |
Should definately be strong!
I'm running a Front Range Offroad center section on mine, custom arms, bushings at the frame. It transmits a bit too much vibration. I'm going to be going flat-belly this summer, hopefully, or as close as I can get(my double adapter isn't clocked )..My advice is to raise your drivetrain as much as possible.. every inch under there helps.
#3 |
Bike Dude
This alone will give 2 inches and keeps the drivetrain in its stock position. PLus it should be overkill and uses the stock mount for some comfort. Should be easy to mod when i do tuck the drivetrain... for now i just want it to run.
Still waiting on the machine shop for my block |
#6 |
Bike Dude
good point... im starting as soon as i get my engine back... its been almost a month at the shop....
I mihg tjust try it flat we'll see. Send me some pics of what your doing when you get to it |
#7 |
Parts Galore Spokesmodel
well I made a lo-pro crossmember and here's what I came up with
it raises the T-case an inch and gives 3¼" more clearance than stock. I retained the stock mount a for vibe control. slightly booty fab but it'll work. made from 3"x¼" anlge iron, butchered and TIG'd back together. it is pretty strong as I picked the entire truck up by it. ![]() ![]() ![]() ![]() |
#8 |
Bike Dude
looks like that will work pretty well. I think thats kinda how im going to go... maybe lift the t-case a bit more though... we'll see
#9 | |
you can see in the second picture how much the T-case is lifted. |
| Thread Tools | |
| Display Modes | |
