Originally Posted by Yetti
the dash light is probably the problem. if the light doesn't come on while the key is one and the engine is off, the light bulb itself is the key. its the fuse for the circut and will prevent you from charging. if the brown wire doesn't see ground through a bulb then it won't charge.
The MH has a gauge also (maybe I should have mentioned that), so it must not use the light. I check and there is no buld in that socket. I check and the wire to the "I" terminal has 12 volts at the Gen. The Gen is a Bosch re-man from Murray's. I still have the old Gen, I might get that re-checked. Murray's checked it and it failed ( I did see the fail on the screen).
AWK
