Old April 30th, 2006, 06:59 PM   #1
quicksilver
I'm with stupid
quicksilver's Avatar
Chevy cavalier stalls.
I know this is a off road forum but I have no one else to ask. I am thinking about buying my buddys kids car it is a 95 cavalier 2.2l but the thing stalls when you put it in gear. It only does it when it is warmed up. We were messing with it an found that it will stay running in gear but dies when you give it gas. Any ideas? It runs great when it is cold...
Thanks
quicksilver is offline   Reply With Quote
Old April 30th, 2006, 08:32 PM   #2
Buy a Jeep save the UAW!
fuel pump. most likely its week and and can't handle the extra load. are you able to drive it or is it just barely able to stay running in gear?
Old April 30th, 2006, 09:26 PM   #3
quicksilver
I'm with stupid
oh we can drive it. It drives nice and has good power until it warms up then it dies when you come to a stop. It will start right back up and run good but dies again when you put it in gear. we drove it up to autozone to get the codes read but there were none. The guy at autozone was saying something about the Lock up converter causing the problem. it sat for a long time (like a year) so we are going to change all the fliuds and try it again.
Old April 30th, 2006, 11:11 PM   #4
Sonicjay
Back in black
Sonicjay's Avatar
Had the exact same issue on an old cavalier of mine; it was some sensor that's in the engine compartment towards the front. I can't remember the name of it, but I want to say it was between $60-80, but fixed it immediately. I worked a t a Chevy dealer at the time; I told one of the techs about the problem, and he knew immediately what it was cause they go bad all the time.
Sonicjay is offline   Reply With Quote
Old April 30th, 2006, 11:28 PM   #5
xjmichigan
通网- 通天下之志成天下之务
xjmichigan's Avatar
temp sensor or o2 sensor
xjmichigan is offline   Reply With Quote
Old April 30th, 2006, 11:30 PM   #6
ex girlfriend had the temp sensor go, and it was doing exactly the same thing.
replaced it, and it was good to go
Old May 1st, 2006, 05:11 PM   #7
Yankabilly
Lockup solenoid is gone. if you find the relay for it you can unplug and it will work again. It WON"T have lock up so it is reccomended you replace the $25 solenoid.
Old May 2nd, 2006, 05:30 PM   #8
quicksilver
I'm with stupid
Thanks alot for the help. We changed all the fluids and it didnt do it right away but it did do it again. I unpluged what I thought was the connector for the lockup converter and it didnt do it again. I guess it was just the 25.00 soleniod.
Jeremy
Old May 3rd, 2006, 12:33 PM   #9
AWK
AWK's Avatar
If it's a temp sensor bad it should have a code, like P0112-118. If it runs good but dies when you let off I would inspect the IAC (Idle Air Control) motor (#2). The seat may be dirt (usally give higher rpm), or the port may be clogged (stalls on decel). Rather simple thing to check before changing parts.
AWK
AWK is offline   Reply With Quote
Old May 3rd, 2006, 01:07 PM   #10
deuce228
S C O T T
deuce228's Avatar
Send a message via Yahoo to deuce228
is there a sensor on the top of the tranny? When it dies try disco'n that.
deuce228 is offline   Reply With Quote
Page generated in 0.18516 seconds with 33 queries
