Regular Sale price is 818, if you enter
gl4x4 in the promo code spot you will get another 20 dollars off....that is
798.95 and still free shipping....
XD9000i, Premium Series Recovery Winch
Click here to visit the sale
No load line speed of 38-feet per minute, three-stage planetary gearing and the ability to run cool with low amp draw for long winching cycles are just a few reasons why. Both winches are quiet and double durable – pure and simple.
The XD9000i features an integrated control pack and all metal housing, which protects the winch’s electrical components the way a roll cage protects you.
XD 9000i Specs:
Rated line pull: 9000 lbs. (4080 kgs.) single-line
Motor: Series Wound™12V 4.6 hp, 24V 2.5 hp
Remote Control: Remote switch, 12’ (3.7m) lead
Geartrain: 3-Stage Planetary
Gear ratio: 156:1
Lubrication: Aeroshell #17
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum diameter/Length: 2.5”/9.0” (6.4cm/23cm)
Weight: XD9000i: 85 lbs. (38.5kgs.)
XD9000: 78 lbs. (35kgs.)
Wire rope: XD9000i: 125’, 5/16”dia. (38m, 8mm)
XD9000: 100’, 5/16” dia. (30m, 8mm)
Fairlead: Roller (Multi-Mount kit includes Hawse fairlead)
Recommended Battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72” (1.83m)
Finish: Argent Gray Powder Coat
