- tech
- 70s and 80s Toyota LC and Truck wiring diagrams..
- Lifting for now
- With all the Yota people joining lately, I would think someone would have a problem..
- What do you guys think about the FJ Cruiser?
- Lincoln locking 8inch
- lookin for some yota parts....
- My buildup...
- Discuss.
- Hello there
- tranny swap
- What Birfields/Front Axles are you using?
- Pics of my 89 Yota.
- What is the SR5 package?
- New build up
- Looking for a good FourRunner Mechanic
- here's my project
- Heavy duty t-case crossmember
- Sweet Yota vids...
- Some updated pics of mine in the mud..
- Drivetrain tuck
- maybe someone is interested....
- Turbo Supra r154?
- My Toy
- my new yota
- timing chain ???
- Replacing a head (SR5 V6)
- looking for topper
- MY new yota :)
- 01-04 taco's
- Just Posted All Toy Stuff
- Blew up the yota this weekend.
- Axle nut size on 89 4wd Yota?
- Toyota buildup questions
- i need a 3.4 head
- My 40 is on the road.
- lookin for a yota frame
- Got the yota home today...
- sheet metal help...
- lookin for a straight axil.
- Haggar!!! I need help
- Reg Cab
- Sway bar????
- Whole mess of TOyota parts - including a frame..
- toyota timing... and Cam question
- Fj40
- Some nice pics of my Toy in this thread...
- Where to get interior trim pieces for a Camry
- Axle help
- Inferior Front Suspension
- Toyota tuning
- dana 44 toyota 8" hybrid
- toyota video
- Working on the cruzah a little...pics..
- 2nd Gen 4Runner.. what to look for?
- Does anyone have any tips for an engine swap?
- Power steering
- New look! to my FJ60
- new to the yota game got a problem with my 4x4
- i just got an '84 extracab
- Before & After
- More power little truck, Engine swap???
- carb problems?
- Toyota Tacoma Factory Service Manual
- 1,372:1
- Tercel Knock
- Indroucing myself
- whats a 40 worth
- Where to get CEL scanned on my p/u?
- removing the proportioning valve
- 4.3 swap?
- 87 yota 4x4 22r.....runs good but slow and no power
- 87 22r truck to 88 4runner efi swap
- FJ 40 wiring
- 22r distributor...What if vaccum advance goes out????? FIGURED IT OUT...
- Help With New Head Gasket Install
- 87 yota 22r speedo off due to tires, by how much?
- Pinion angle whats ideal
- what to use for rear bumper
- dual cases
- 7mgte 4runner
- '88 FJ60 Land Cruiser
- 22re head
- 85 FJ60 for sale
- FJ40 (looks rough) on Ebay (parts cars)
- 1987 4runner 31inch tires = bad gas milelage?
- 1987 4runner 4 wheel drive not engaging. Help.
- What factory rims will fit on my 87 4runner?
- EFI swap onto 87 22r
- delete
- WHose Gonna Buy This "Badazz" Toy?
- New toy
- Toyota Turbo Diesel
- What set ups are you guys running?
- Yota truck maintenance.
- Toy front axles
- Seen a fj40 for sale.
- Some bling for my junk....
- gas mileage?
- Wiring questions
- please delete
- 3.0 v6 info
- lower tcase gears
- Wheel spacers?
- Getting spindle off
- Any Lifted Tacos Here?
- need a R150F 5 speed manual tranny
- birfs
- waggy spring lift
- Spotted A 89-95 4Runner
- wich one of you guys bought that 4 runner in the bargin corner?
- my Toy log: 6/2/2007
- Owosso Toyota Guys?
- Aftermarket birfs- What ones ?
- Help! Converting Auto hubs to manual 1987 4runner
- 22re Quit running
- Half doors ?
- stripped hole in head :(
- Anyone need a new body?
- Which trans?
- need advice on cam.
- this would probably be worth the trip to get.
- Parts for the 'Yota people
- Rear disk brake conversion
- Drag Link rebuild
- Wheres Ron
- motor mounts
- because $500 in motor work and some stolen 33's never looked so good.
- New bling
- 22r to re swap
- How much clearance do you need between your radiator and fan?
- Solid axle reseal
- doesn't like to idle
- how do i know if i need a new tps?
- engine swapping 4cyl Yotas
- Starting to upgrade the trail truck....
- *grumble* fuel pump *grumble*
- clutch ?
- toy 8" rear
- High pinion front?
- Some thoughts on fixing my starting problem (Now fixed)
- Quick clutch question
- 22R oem part question
- how much pressure is the fuel pump putting out?
- WTF? 1 ton 4 cylinder?
- Abester's Yota lives on...
- Torque converter loose ?
- burning oil now.. damnit
- Key goes in ignition but won't turn
- Rear disc breaks on the Cheap
- 2007 TLC Icon - $100k brand new FJ40?
- offset rear axle
- EFI or propane??
- Would you buy this?
- doors question
- fenders
- 3.0l V6
- EFI swap question.
- O2 sensor compatibility
- Anyone Here's 4Runner?
- Drowned 4Runner
- motor siezed today :( anyone have a spare they want to sell?
- Motor Mounts and Dual Cases
- quick question about 22R motor generations
- Replaced the starter contacts in 97 4runner today
- 77 landcruiser radiator?
- 22RE Swap
- Wanted
- Seized Smog Pump
- Gas problem in Toyota
- Question on Rings and Timing Chain...
- So Important I Asked Twice-Hi Steer
- Snorkeling a 1987 extended cab
- Toy front/rear axle interchange
- Just a shout out Spartan Toyota
- Toyota Traction Bar
- 93? Anygood?
- Funny-acting acceleration.
- 95 Tacoma Needs some love
- opions on birfield eliminator
- 04 Taco tow rating
- Spring swap?
- 4WD Toyota Owner Mag
- 4cyl/6cyl diff differences
- 22RE running rough.
- sup boys
- Tacoma Takeover Anyone?
- SE Wisconsin
- Taking out a body lift.
- Widening toy axles
- who bought my truck?
- New Guy
- 89 Yota Pickup Questions....
- rear disc brake
- new 4x4 shop in southwestern Michigan!!!
- 1972 FJ40 Clutch master cylinder
- u joint converstion?
- Marlincrawler/rear bumper??
- Checking codes on pickup?
- anybody have a cam sensor? Nevermind tested mine
- Guy witha Rainjuh with some yota parts Questions....
- Dash Brake light flickering.
- Tundra Question. Fourwheel drive not working.
- Newbie needs help!!!!!
- Toyota engine transplant
- Tailgate repair 89 4Skinner
- new toyota FJ crusier
- 97 4Runner info
- Help with old toyota
- any 86-94 toyota guys, i've got some 25mm torsion bars
- Engine swap
- Front main seal.
- New For '09 4Runner Package
- 22RE header install
- HELP wiring gremlin on 85'
- Toyota meet
- if anyone wants newer landcruiser axles...
- toyota bogging
- Oil pan problems....
- Brake Problem
- trans slipping
- wheel spacers
- as much as i'd like to have this, i dont' have any money right now
- Front spring opions ??
- 89 Toyota Starting issues
- New Marlin Crawler site & products...
- engine swap troubles
- NEED YOUR IMPUT tacoma speedo making noise
- 22RE running rich.
- Need Help New to working on yotas
- anyone have some rear springs laying around?
- FJ40 info/opinions
- 88 yota question
- Toyota conversion flange
- 85 22R not running right...
- Seats in a yota
- trail gears dirty 30 birfeilds
- 88 chevota suspension mods?
- soft top for 1st gen 4runner
- F@#$ the 22RE!
- How to build a new front axle.....
- sell all my toyota stuff
- SE Michigan Yota's
- Gears vs. tires
- RTI Ramp plans
- 8" toy front axle tube thickness
- question about birfields
- 1990 4runner blower motor
- snorkel
- RAV4 Trans problem
