View Full Version : Jeep Tech
- 92 xj computer question
- Okay I am STUMPED! Engine chokes at 2k
- blower no worky
- wont fill up
- Jeep CJ-7 Chassis
- 4.0L Engine electronics
- XJ Not Taking Gas?
- Two loud back fires and motor stalled
- 304 to a t-5 (5 speed)
- Distributor wiring question... swap connectors?
- XJ rattling noise
- Cherokee A/C Questions??
- 1994 Grand Cherokee 5.2L belt Diagram
- XJ Fender Flares
- Knock Knock
- power steering pump
- 10.5 or 12.5 wide tires?
- amc starter problem!
- seat release~99 wrangler sport
- gas gage sending unit
- DIY posi lock system
- another yj gas gauge question
- 727 to NP231 Help needed!!!!
- Flexplate Questions
- cj7 wheeling problems
- '98 XJ ABS light on (now with check engine)
- Body mount question (Daystar 1" BL install)
- "Whirring" Noise 94 YJ
- windshield wiper assembly 1986 cj7
- Lift for a ZJ ???
- '06 Wrangler not going into 2wd
- ZJ Question
- 91 YJ Power Surges
- Starter??
- UPDATE - Ignition Problems - starting 98 XJ
- cj 7 clutch rod hole location
- TPS? Transmission issues...
- removing steering wheel from column
- Stupid 94 yj w/4.0 belt tensioner question.
- need help with lift and stuff
- 304/727 combo
- i need soft top help
- brake pads slipping off
- best brake pads for a wrangler
- heater fan again
- Running Weird!!!!!!.
- SYE question
- winch mount hole stripped...help
- Fuse Help
- who the hell did this
- Ignition load, whats going on here?
- XJ Transfer Case Drop Brackets????
- What Head for my I6 Stroker
- Blower Question
- cj dash removal
- Eating U-joints for dinner...
- hard top over soft top
- Can someone put this in laymans terms?
- how to bleed power steering for a 91 yj?
- Transfer case, not fully disengaging?
- XJ rear spring prech and angle
- 4.0 rear main swap
- What are the body mount difs between YJs & TJs?
- Trans leak??
- 4.2L to 4.0L Swap
- Cold Air Intake...
- 93 xj rear axle
- stupid CJ5 ?
- throttle position sensor
- 4 wheel drive indicator sensor
- Cherokee v8 swap help (need info on tranny and tcase stuff)
- Runs like crap and a check engine light
- please help!!!!
- SOA YJ kit
- Mother F-ing steering box bolt size.
- My jeep needs exhaust including a new header
- XJ interior
- xj axle swap
- XJ lift/driveshaft length Q?
- How do you set ignition timing????
- 90 2.5 to 94 2.5
- 95 2.5 rough idle
- 2001 XJ "NO BUS" OBD Code?
- 4.0 exhaust manifold cracked - weld or replace?
- Front Crank Seal 4.7L
- Adjustable ball joints part number needed for Dana 30.
- control arm skids?
- 99 cherokee sport
- Zj questions
- 96 ZJ Skid Plate Dimensions
- Small block with stock drivetrain?
- XJ Dash
- AX-15 Interchangeability
- 1991 2.5 to 4.0 swap any info???
- high pitched whistling..
- is Teraflex 4:1 the only option?
- Jeep grand cherokee
- shock legnth 00 xj
- CJ/YJ compatibility questions
- jeep no heat
- wireing
- 2.5L, 3.73's and 35's
- Need help soon
- Worth Restoring??
- NP231 to NP242
- Sold It To Save Me The Work!
- amc th400 output shaft question
- SOA Anti-wrap bar
- where can i get studs for a dana 300??
- 98 cherokee rear wiper arm question
- Replacement engine
- ax-15 swap
- Gas leaking on a YJ ?
- Dana 30 gear and carrier question
- 258 Radiator for 2.5
- CJ D60 disc brake question
- Transmission bolt patterns
- Flexplate shim?
- adjusting door strikers
- What would a shop charge to...
- ? on a changing a stat.
- 97 xj check engine light on
- YJ steering column horn ring
- cj7 fenders on cj5?
- XJ radiator suggestions
- Crusher Corners on Fiberglass Tub
- 99 xj no gauges no odometer
- jeep wireing
- Extended Warranty
- Replacing Body Mounts
- Fiberglass tub trimming
- Need Help Fast - in middle of 4.0 swap - Engine bracket issues? HELP!
- wj or zj??? how to tell?
- blow by?
- What model WJ?
- 2000 wj poooooof of smoke and some...
- MPI fuel fittings
- Stupid XJ Question
- Hard starting XJ
- found a 76 wagoneer what axle anyone?
- 4 speed for CJ?
- Crappo d35
- wireing help
- steering help cj
- ABS to non-ABS
- 1" lift
- Timing question
- speedo doesnt work
- stupid carb
- What lift springs YJ SOA - SUA
- aluminum radiators
- Axle Question - 9" vs 8.8
- Disco waggy 44 tear down
- curious
- Jeep cherokee - Break problem
- Swapping an 8.8 into my 99 XJ
- drivetrain noise
- Will a larger battery fry anything? New issue...
- cj7 SOA steering ??'S
- 1991 cherokee 4.0 died!! "DELETE" problem solved
- 98 TJ door hinge inserts
- TJ Soft Top Pivot Brackets
- 79 CJ7 Project
- cj front clip on a yj
- master cylinder rebuild
- Wide Track Axle Installation Question
- ZJ Flexplate
- need bolt size confirmation (bleeder nipple)
- Turning off ABS?
- Another ABS query.
- Finally Got my Jeep
- TJ Question
- 97 zj for parts, should I buy
- 12.5s on a 8" rim?
- 8 or 10 inch rims
- Airbags - Does anyone disconnect them?
- Please delete
- brake woes in jenison
- d 30 upgrade
- Wrangler Pinion Angle
- 05 Tj Clutch
- half doors vs full hard doors
- WHat to look for to determine granny gear in T18????
- need help ID'ing an AX15!
- Cherokee lift
- Short SYE, VS Super Short SYE
- windshield seal, cowl seal
- Dana 20 shift pattern?
- 255 v6 buick can be swapedm out with ???
- Trans or NSS or T-case problems
- AX15 in a Cherokee (XJ)
- mojave heaters
- Jeep TJ gauge cluster, Radio, Dome light
- Disco Discussion
- TJ Front Driveshaft alternative?
- bad transfer case?
- Wipers Stopped
- XJ springs in rear - CJ, YJ, TJ
- 95' XJ headlight issues...
- 4x4 Light In 2hi (liberty)
- my tj 2.5 liter gas guzzler
- XJ won't stay running (fixed)
- AMC 360 TBI-----Aftermarket or Stock PROM (Chip)
- In the market for SYE/CV
- Call for Help - Blown rear end 98 TJ
- dual zoned heater problems
- tire question
- Lift Kit suggestions
- Throttle Body Spacer
- Light Bar help??!
- Missing in certain RPM range.
- regearing an 01' xj
- XJ Anti rock or any long armed Jeep with one.
- TruTrac Question
- New question Radiators yj-cj
- Rear Main Seal (91 Jeep Cherokee)
- caliper rebuild *86 cj7*
- TJ Auto Trans fluid Questions
- 94 ZJ shifter removal
- 2 questions
- yj wiring diagrams for conversions???
- Fuel line size?
- 08 JK springs on a 97 TJ
- Hard doors cracking
- looking to get new shocks
- Nevermind, found it - TJ LCA Length
- 95 YJ Heater Q ?
- Code 71 ???
- Rock Krawler Suspensions
- 91 yj stalling at first start
- 1" body lift on YJ?? HOW?!
- NP231 disengaging question (4H 'skips' or 'catches') UPDATED
- Transfer Case Problem...Won't budge in 4 wheel.
- Exhaust Advice
- Do you need a rear track bar?
- T-18 to a 304
- Lift kit help!!
- Heater Problem - TJ
- NP242 Fluid for 04 GC
- xj stalling
- YJ-TJ-CJ mirrors?
- Replacement SOFT Top ?
- I drove my new J10 for 50 miles (long post)
- Stalling 99 XJ
- Unlimited Coil Springs on a Reg TJ
- Dana 300 Cable shift???
- 93 xj wont start
- Speedo gear
- stock seat bolts
- fuel dumps out on roll over
