Axle Tech [Archive] - Great Lakes 4x4. The largest offroad forum in the Midwest
View Full Version : Axle Tech
Pages : [1] 2 3 4 5
  1. Dana Axle Info
  2. Looking for an axle... here is a reference for what axle was in what vehicle
  3. Heres some crap I've collected up
  4. identifying an axle from it's diff cover
  5. Dana 60 fronts
  6. Ford 8.8 Info
  7. Axle U-joints On a Yj (most D30's)
  8. Dana 53?
  9. Toyota Solid 8" Axles
  10. Here's another option for axle upgrade
  11. 9"
  12. RockCrusher Dana 60
  13. samuri and sidekick
  14. This looks like a killer dana 60 deal on Ebay..
  15. Photos comparing dana 60 to dana 44
  16. where to buy gears?
  17. Dana 44 strength
  18. Rockwells.... anyone... anyone
  19. So you wanna run a cool front axle?????
  20. Locker or limited slip
  21. Anyone know what axles are in a 2000 F250 Super Duty?
  22. Axle Identification Chart
  23. Holy hardcore axle parts.
  24. Another Dana 30 Question
  25. Best Rear Axle
  26. whats the best kind of Ford axles?
  27. Something gave..
  28. which one would you lock?
  29. Ford 9" Doner Vehicle Data
  30. Dodge front D44
  31. Ford 8.8 question
  32. dana 30/35
  33. read if you know anything about axles and swaps
  34. 14bolt w/ stock brakes will 15" wheels fit?
  35. Why not use the 10.25 sterling
  36. Front waggy 44's.. Changing bolt patterns, do I need new spindles?
  37. Dana 30 questions
  38. how to tell gear ratio with out pulling cover/third member
  39. Dana 44 info
  40. Fun with Axles
  41. D60:Semi Float, 5on5.5, disk brakes
  42. 9 inch pinion angle
  43. Lock right Help
  44. Front GM 10 bolt and dana 44
  45. 14 bolt shortening question... think about this..
  46. D35 or 8.25 or WTF
  47. 8.8 upgrade kit
  48. Axle Puller
  49. Eliminate Dana 30 Vac Disconnect
  50. Front axle Options?
  51. Dana 60 hub question???
  52. axle math
  53. Built 30 vs a dana44
  54. Front GM 10 bolt ???
  55. D60 or 70?
  56. Corp 14 bolt
  57. gearing info
  58. 1 Piece AMC 20 Shafts
  59. lock out conversion for a dodge d44?
  60. 8.25 29 spline
  61. powertrax lockers
  62. dana 60 question
  63. D30 and D35 carriers
  64. D60 needed. Which Vehicle?
  65. D44 in the Grand
  66. Dana 30 disc brakes?
  67. gm 35 spline stub in a ford 60?
  68. Building axle question
  69. Pinion angles
  70. So Hosejockey showed me something funny...
  71. rockcrusher diff cover leaking problem
  72. D44 info needed
  73. Dana 44 flattop knuckles
  74. How strong can a front dana 30 be made?
  75. Various axle shaft strengths, as tested to failure by Bobby Long..
  76. Ford parts interchange ?
  77. Stuck pinion
  78. 86 Dana 44 w/welded spider gears????
  79. Do Gear Brands Matter?
  80. Wheel Spacers
  81. Ford front D60 and wheel compatability
  82. 9" mini spool
  83. zj axle swap
  84. Dana 25/27
  85. DRW D60/70 & 14B questions
  86. welding a d35/30
  87. move me or remove me please.
  88. Front d44 disc brake conversion
  89. 44 vent thread size
  90. d44 and amc20
  91. Newb Axle help needed.....long read.
  92. dana 44 gear question
  93. HP 44 in a Grand
  94. tooth count/gear ratio question
  95. 12 bolt or 14 bolt
  96. Dana 30 stock spline vs 30 spline
  97. full spool vs. detroit locker
  98. 2.5 Ton Vs 3 Ton
  99. D44 axles
  100. locker or weld
  101. Dana 44 of front 10 bolt???
  102. 76 Dana 44
  103. Corp 10 bolt front
  104. Differential Covers
  105. '76 44 for yj
  106. Recommended Gears
  107. Front d44 pinion angle
  108. CJ NT D44 question
  109. Axle shaft Q.
  110. Using Chevy 1/2t backing plates on a 9" or semifloat D60
  111. D50 hub/rotor same as D60?
  112. scout 44 in a cj soa. i need steering ideas
  113. bolt pattern conversion
  114. u bolts
  115. Currie 9"??
  116. axles
  117. d-35 & d-44 brake crossover
  118. Which way should I go?
  119. Mustang 8.8 ?
  120. detroit truetrac and track lock
  121. ford 8.8 or dana 44?
  122. Wheel Spacers
  123. Stock 1980-up Grand Wagoneer axles in a YJ
  124. 8.8 factory posi
  125. auburn lockers f*****g suck........
  126. scout or jeep widetrack??
  127. 8.8 and a dana 44
  128. D44 tech specs?
  129. dana 44 posi
  130. Are alloy shafts really that much stronger?
  131. Dana 60 hubs?
  132. D44a Aussie
  133. 8.8 disc brakes on a scout 44?
  134. chysler 8.25
  135. Curious about lockers.
  136. bracing a Ford 9"
  137. gear ratio question
  138. What vehicles come stock with dana 44's.....
  139. axle tech
  140. ring and pinion shops
  141. How bad is running a lockrite locker in the front?
  142. Amc 20
  143. 91 front waggy 44 to become a tj front 44
  144. Ford Flat top knuckles
  145. Ford Flat top knuckles
  146. Dodge Dana 44 questions
  147. Dana 44- thick or thin? Master instal kit required?
  148. diff fulid
  149. mini spool
  150. Stock D60 outers
  151. Can anyone weld my diff in SE MI?
  152. lock right install help please
  153. Ring and Pinion
  154. D30 carrier, from 3.07-4.56
  155. 14 bolt disc brake.
  156. Tractor Axles
  157. ***hey axle guru's....a little help please***
  158. setup tools
  159. auto lockouts
  160. '76-'86 CJ rear axle swap options
  161. looking for a good axle shop
  162. Read Before Posting!!!!!
  163. Disc brakes for Ford HP44?
  164. Axle rebuilt steps....
  165. CTM vs Yukon vs Spicer vs Longfield..
  166. 8.8 lube question
  167. Ford 8.8 carrier question
  168. where can i get parts for my detroit truetrac
  169. Axle Advice
  170. HP60 spindle removal
  171. HP60 Hi Steer
  172. Noise
  173. Convert Rear Dana 44 offset to Center???
  174. does this really work?
  175. XJ Vibration
  176. Amc 20 Drum
  177. scout dana 44 axles guru's needed
  178. TJ D44 Shaft ?'s
  179. Found a rearend
  180. Another what ratio question
  181. Ford 8.8 w/5.13's and Aussie issues ! ! Question ! !
  182. Looking to have Scout II axles retrofited
  183. so my ramchargers axleshaft isnt long enough...
  184. ford 8.8 pinion gear; won't come out
  185. Detroit lockers
  186. name, that, axle!!!! PICS NOW
  187. Jeep guy w/Chevy question
  188. Identify this axle, or what it is out of
  189. gear lube with lockers
  190. Pinion Angle??
  191. Emergency Gear Question
  192. 3:55 from XJ to TJ
  193. Dana 44 scout axle high steer
  194. aussie locker question
  195. Ok, whats the deal with breaking in gears. Is it necessary?
  196. rubicon 4 low locker bypass
  197. !!new info!! HELP can i drive with NO carrier in the front
  198. Powertrax No slip Vs. Lockright
  199. Dana 70 question
  200. Where would I be that I'd use lockers locally?
  201. can i put my stock spiders (4.11) back in with 4.56 gears?
  202. HP Dana 30 strength
  203. rear dana 60 price
  204. locking and posi axle questions
  205. axle id??
  206. Axle shortening D44
  207. 30 spline dana 60 strength
  208. gear tooth marks on carrier??
  209. 10 bolt or 12 bolt axle?
  210. dana 44 axle shaft 16.75"s long anything cross?
  211. Install kit
  212. yj axle codes
  213. biggest brakes
  214. detroit ez locker trouble.
  215. spline count/gear ratio for 94 xj 8.25
  216. rockwell's for mich wheelin ?
  217. WMS measurements and other
  218. 9" question...
  219. Differential Case Breaks (or, "Do I need a new carrier?")
  220. 99 XJ Axle ????
  221. help me figure out what D44
  222. Need some advice on an axel swap!
  223. Help!! I dont know my gears!!??
  224. Looking for opinions on front diff, now with pic of diff in question
  225. 28 spline 9" strength
  226. I have numbers I still dont know
  227. Need aftermarket axle shaft help
  228. xj coil question
  229. Redline 75w140No Slip gear oil in ford 8.8?
  230. D44 Carrier differences
  231. 8.25 question
  232. axle brake lines
  233. Accelerate- pulls left, Decelerate - pulls right
  234. tj rear d44 disc converstion
  235. V8 or better crawl ratio?
  236. LubeLocker Differential Gaskets
  237. Lets set the record straight...
  238. to add or not to add; that is the question
  239. Stupid compression cone thingys on steering arms. How to remove? dana44/10bolt
  240. gear lube
  241. ford 9
  242. lockers air,cable,electric
  243. JK Gears...
  244. yes, a d35 question
  245. D30 pinion bearings
  246. Anybody here running a ECTED locker?
  247. axle cleaning?
  248. removing minispool
  249. dana 44 front and rear build
  250. Dana 60 spindle boring and alignment tools
