Axle Tech [Archive] - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
View Full Version : Axle Tech
Pages : 1 2 3 4 5 6 7 [8] 9
  1. Front pinion bearing 04 rubicon
  2. 70 scout800 a
  3. Welding a d44
  4. gear identification
  5. Good Source for Gear Setup Specs.
  6. 8.8 gear help
  7. Which Rear Differential 1997 Tj
  8. CJ axle choices
  9. new rear axle for my yj?!? whats my options
  10. waggy D44 knuckle interchange
  11. welded front diff?
  12. Odd 8.8" locker question.
  13. D44 Lockouts
  14. Ring and Pinions...Oh My...
  15. xj dana 44 rear?
  16. axle choice
  17. dana 60 drw-srw. conversion
  18. Ford 9 inch axle bearing
  19. Help !! Need dana 44 tech !
  20. 8.8 in yj help
  21. 4 wheel steer kit
  22. u joint problems
  23. dana 44 ball joint adjustment ????
  24. Axle gearing importance in manual trans
  25. hp dana 30 ?
  26. Convert Dana 60 8 on 6.5" to 5 on 5.5"...without spending a ton
  27. Ez Locker question
  28. spartan lockers?
  29. Deciding on a d44 front (hp44,dodge,waggy)
  30. Sterling 10.25 inside a D60 front
  31. new to full width... picked up a 44.
  32. Yukon Super U-joints for Dana 44
  33. 14 Bolt Gurus, strength ?
  34. Ford vs Chevy Dana 44 Parts
  35. What locker is this?
  36. Dana 44 Front in a One Ton?
  37. dana 35 trac loc
  38. Axle tube help
  39. *SOLVED* bent 9" axle housing?
  40. ** solved** 14 bolt & Dana 60 hubs
  41. Dana 44 (99 Dodge Ram 1500)
  42. 9" axle shaft seal, moser 31 spline tapper bearing
  43. Welding 9" truss. *got it, now questions.....
  44. XJ front HP D44
  45. D44 & 9.25
  46. Waggy 44
  47. Gear Pattern
  48. Dana 44 lockers
  49. help IDing 10 bolt axles and t-case
  50. Looking for help setting up a rear end.
  51. 10 bolt gear questions
  52. D60 balljoint - upper balljoint coming loose in knuckle/C
  53. 10 bolt diff help please!
  54. Locker and Axle Q
  55. Dodge D60 to manual hubs
  56. dana 35 axle noise question
  57. C clip in D35 with locker
  58. I need axle help!
  59. Aluminum Hub Adapter Durability.
  60. D44a pinion bearings question
  61. WJ Dana 30 question
  62. is this a dana 44 or 10 bolt
  63. D30 clicking..?
  64. Ford 60 changed to chevy drop
  65. dana 30 to dana 44 interchange
  66. Gm 14 bolt wheel studs???
  67. ID these axles
  68. Gears/locker
  69. return to stock gearing
  70. Question on running a rear spool
  71. Axle ID Needed: 5 x 4.5 disc braked dana 60 rear axle exist stock???
  72. how to set pinion bearing preload
  73. weldinto a diff
  74. 97 Grand rear axle
  75. Narrow vs wide
  76. what would you do
  77. axle selection
  78. dana30 help
  79. Dana 44 on xj help
  80. Leaky TJ Dana 30 (seals or u-joint?)
  81. What kind and size shox
  82. machining h2 rims
  83. 60 shaft interchange
  84. Measurments from backing plates
  85. axle joint fazing
  86. I get lost in axles. ***UPDATED***
  87. putting disc on a 9in...?
  88. Dana 30 gear install question
  89. 8.8 Flange Bolts What size???
  90. J10 axles under an XJ
  91. Dana 60 and Dana 70 in a TJ
  92. School me. D60 brakes.
  93. Ford 9" Gears
  94. 8.8 gears
  95. Ford vs. Chevy Dana 60 SRW Hubs
  96. Axle help/info
  97. Gearing running 44s
  98. What gears should I use?
  99. Name that hub!
  100. rear pinion angle
  101. What to paint axle with?
  102. cherokee d30 &ch 8.25 fluid
  103. good way to pull the axles out of a dana 44
  104. 14 bolt shaft differences
  105. outer axle tube seals?
  106. Need some help
  107. Identify this bearing and seal! Solved!
  108. Eaton E-locker questions
  109. Longfield abuse
  110. eBay Dana 60 Spool
  111. d44 experts....
  112. Explorer Axle Pinion Lateral Movement
  113. 97 Xj D30 Outer Shaft - Rust Spot Okay?
  114. dana 44 ball joints
  115. 97 Xj/C8.25: Axle Seal Depth?
  116. dana 60 front axle swap questiones
  117. Dana 35 new R&P setup help needed! BAD!!!
  118. Snow fighter
  119. CJ Springs (height)
  120. unit berrings
  121. 8.8 paint pattern
  122. Dana 60 sealing spindle
  123. Re gearing my duty.
  124. 14 bolt axle shaft swap, 8 lug to 6 lug
  125. Bent my axle, suggestions?
  126. what kind of axles am i looking at?
  127. YJ steering damper bolt broke off. Also have bad death wobble.
  128. 2/1 ratio
  129. Offset Pinion
  130. weird driveline noise
  131. Possibly bent inner C's
  132. whats the right torque specs for pinion nut on a chrysler 8.25
  133. dana 44 help
  134. Track bar, getting axle centered. Help
  135. Teraflex diff cover?
  136. welding chromo shafts
  137. Shackles
  138. 241C to Dana 30 & 8.8
  139. Welding a rear end?
  140. yj axle lengths
  141. cherokee hp dana30
  142. if tj had abs on dana30, does new axle need it?
  143. Does anyone make a C 8.25 mini spool?
  144. pinion pin/ center pin won't come out with 4:56s in my 8.25
  145. Power lok in dana 70
  146. Ring & Pinion Dana 44s
  147. gm 10 bolt pinion bearing replacement
  148. 14 bolt ff hub bearings... Help!!!
  149. Gm 10 bolt front axle
  150. 14 bolt disc conversion...rotors
  151. 14ff vs 60?
  152. In a little bind....
  153. ZJ D30 in a TJ
  154. Need a good source for Dana parts in the Detroit area
  155. 14 ff e brake
  156. Dana 60 caliper removal
  157. dodge axle compatibility
  158. Welding on axle, pinion seal explodes out.
  159. dana 30 advice
  160. 1999 TJ rear yoke replacement
  161. pinion seal
  162. 2.5 ton axle shaft question
  163. 91 YJ trying to replace front axle u-joints
  164. Draglink end ID
  165. Dana 30 Carrier Measurment
  166. 92 f250 axle
  167. grand cherokee Welding front axle
  168. axle id help
  169. Anyone run these Spindle bearings?
  170. 14 ff pinion angle
  171. locker issue
  172. Ford 9 " disk swap wheel studs
  173. Zr2 sfa swap?? Need in depth advice
  174. Best place to buy carrier shim kits
  175. What Year and Model Jeeps Came With a HP30
  176. Axel swap
  177. 9 inch traction
  178. F-150 or Bronco Stub Shaft Question.
  179. 8.8 question
  180. RCV Greasing ??
  181. 68 d30 carrier in a tj
  182. Axle ID
  183. Flat Top Knuckle Machining
  184. 14 bolt gear setup pattern
  185. dana 30 build
  186. blazer sas questions
  187. Run it or not?
  188. Place to regear in Oakland or Genesee County
  189. What do I need to know when looking for a replaement axle for my TJ?
  190. Setting caster and pinion angle on a hp60
  191. Full Width Dodge axles in a JK?
  192. lj rubicon 44's with 5.89 gears
  193. Brand new G2 front 44, should it be sleeved?
  194. 77 Chevy Front Axle Identification?
  195. 419 unimog axles???
  196. hp D44 truss
  197. D70 hub bolts backing out. Please help
  198. sterling 10.25
  199. Rubber brake lines for my rear axle
  200. Dana 44 replacement
  201. Dana 44 Shafts
  202. Quick rockwell air locker question.
  203. ford 9" flange vs yoke
  204. Locker Comparisson
  205. Dana 44 locker identification
  206. D44 fucked?
  207. 9" Moser shaft seals
  208. Ram assist
  209. 8.8 bearing/seal
  210. Quick D60 front question
  211. Ramcharger Dana 44 help
  212. Bent Shaft Fix?
  213. best locker?
  214. axle and locker help
  215. front dana 60 drum to disc conversion
  216. Help! I need Chevy 12-bolt tech support
  217. D44 to D60
  218. Does running a 60 front/9" rear make sense?
  219. hp dana 60 locker
  220. 1999 Tj Rear Dana 44 Wheel Bearing Issue
  221. Locking hubs in/out play
  222. Measure for shocks
  223. 14 bolt 2.5 ton hybrid
  224. 14 Bolt Rebuild?
  225. 98 Silverado 1500 sas
  226. 1/2 ton axle swap
  227. Need HELP swapping lockers
  228. What gears are these?
  229. Chevy Dana 44 Cut & Turn For Scout
  230. advice ?
  231. Broke Another Shaft, RCV Dealers?
  232. Jeep D30 tube seals????
  233. What drive shafts?
  234. Chevy/FSJ 44 front 1/2" studs
  235. Shocks
  236. why not a ring gear spacer?
  237. Whats next?
  238. Ford 8.8 axle truss
  239. Need info/help regearing axles
  240. Rubicon axles/What's the best year?
  241. Welded or spooled front axle
  242. 8.25 with factory lsd locker options
  243. NV245 Tcase - Worn Clutch?
  244. whats my dana 44 worth
  245. Axles+tires=gears
  246. grand to xj d30
  247. Scout Axle Upgrade Questions
  248. Need help identifying drive slugs from my Dana 44
  249. Spare tire size smaller than tires
  250. 7/8 18tpi heim joints impossible to find???
