Axle Tech [Archive] - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
View Full Version : Axle Tech
Pages : 1 2 3 4 5 6 [7] 8 9
  1. hi-steer help!
  2. good write up on installing gears?
  3. Chevy Axle replacement Problems
  4. Narrowed 9" Question
  5. Chrysler 8.25-Center pin removal tips....
  6. axle building jig
  7. Full Width Ford 8.8
  8. blown locker-advice needed
  9. Minumum axle to carrier clearnace question.
  10. Fj 60 axles and a dana 18
  11. wj dana 30
  12. 14 bolt ff questions
  13. Driver Drop Chevy Axle?
  14. Front axle suggestions pls
  15. Is this axle a boat anchor?
  16. diff covers
  17. Ford 8.8 Question.
  18. stupid question on friction mondifier
  19. axle upgrade
  20. 01 f550 ?
  21. Halo Warthog Rear Steer
  22. 8.8 swap brake line Question
  23. What axle is this?
  24. 14 bolt question
  25. D44 & GM 12 Bolt in a YJ?
  26. blown seal?
  27. Ford Rear DANA 60 Wheel Studs
  28. Are these axles worth anything?
  29. i'm so confused on what to build.
  30. Installing ARB RD30
  31. JK Rubicon Locker Connectors
  32. tj jk axle swap
  33. Dodge 3/4 axles
  34. 60 Chromo shafts?
  35. Diff covers for dana 44 and dana 25
  36. Mile Marker hubs
  37. 9 in stear axle
  38. Spider Gear questions
  39. 4.10 to 3.42 for better fuel mileage?
  40. D60 King Pin Thread - Help
  41. Hp d30 + cj d30 + 35ttb = ?
  42. ford dana 60 front diff cover
  43. D60 high steer
  44. Some one please help me axle troubles!!!!
  45. s-10 blazer sas help! *new user*
  46. Small Ford 8.8 brake line problem...
  47. Welding on Axle Tubes...Issues/Concerns?
  48. Best place for a steering arm for dana 60
  49. E-brake Caliper on D60
  50. Anti Wrap bar
  51. Durasolid Spools
  52. Jeep Axle swap question w/arb locker
  53. chevy dana 44 and corporate 10
  54. TJ front axle build
  55. Floater 9"
  56. Selectable lockers !
  57. D70 drw - disk brake help
  58. ?? on a dana
  59. chevy d44 and d60
  60. Dana 44 and Dana 60 question
  61. chevy K1500 axle interchange?
  62. D 44 Outer stub Axle
  63. One ton dually front axle.
  64. help with vac disc on XJ axle swap
  65. c-clip removal with locker
  66. '78 CJ Dana 44....steepest gears you can get?
  67. AAM 1150 Ring gear bolt torque
  68. 14 bolt carrier break difference
  69. sterling 10.25 pin through diff cover
  70. F150 axle compatability question(s)
  71. What axles do I want?
  72. Axle swap question?
  73. Wms
  74. 78-79 ford drw/srw question????
  75. Dana 44 Adjusting sleeve Tool
  76. Mid-Michigan Axle Shop
  77. How much is my axle worth?
  78. spider gears interchangeable?
  79. Dana 30 Posi Lock System
  80. 14 bolt disc conversion
  81. Building a Front Narrowed D60 for a TJ
  82. dana 60 High steer Questions
  83. Axle swap options on a Grand Cherokee
  84. whos running 35 spline in rear 60
  85. 70 R&P in a 60 housing
  86. Dana 60 axle repair
  87. dana 70 front axle.
  88. Dana 44 C's
  89. 01 Grand Wheel Bearings and CV 1/2 shafts
  90. Aussie Locker worn springs/pins?
  91. hi pinion d30 &low pinion 30
  92. Gear ratio for 37"s ?
  93. disc brake question on ford 8.8
  94. what amc 20 do I have?
  95. warn rear hub conversion??????
  96. dana's on a durango
  97. Who here can weld my rear diif and do a great job?
  98. ? Dana 44 outers
  99. 10 bolt rear question
  100. lunchbox lockers
  101. Whats this D44 setup worth?
  102. Dana 44 Carrier
  103. Dana 30 ford 8.8
  104. compare the 8.25 to the 8.8
  105. 8.8 swap question
  106. Powertrax for Dana 30 Questions
  107. D35 with Lock Rite lunchbox question
  108. Write up for Powertrax LockRite for Dana 30
  109. how to read the numbers on a chevy ring gear what do they mean
  110. mini spool
  111. Spider gear ?
  112. 8.8 question / d35 question
  113. Dana 60 tj build
  114. D35 aussie in a D30
  115. Write up for PowerTrax No-Slip for Chry 8.25
  116. Warn Standard Hubs
  117. 9 inch spool/locker question
  118. D30/Yukon axles strength
  119. Rear D60 disc brake swap question (regarding wheel studs)
  120. TH 400 Rebuild
  121. Problem with the 14bolt sf. Help!
  122. Info Wanted on True Tracs Older Version VS Newer
  123. V8 TJ Build - Axle selection feedback
  124. dana 44 front rh steering arm
  125. Dana 60 high steer arms
  126. What all do I need to re-gear my axles?
  127. U-Bolt supplier
  128. D30 problems/questions
  129. Any Shop or Anyone Local Flint/ Fenton Narrow 10 bolt axle
  130. 2.5 ton rockwell vs ford dana 60
  131. Arb locker
  132. gear ratio close enuff ?
  133. Dana 44 steering knuckle swap
  134. chrysler 8.25 locker question, please help!
  135. High steer arm studs
  136. Remove 10bolt G80 axle?
  137. Importance of changing axle bearings...
  138. 8.8 swap measurements
  139. 89 YJ steering tune up
  140. D-60 Detroit.
  141. dodge rear dana 60 Qs
  142. dodge dana 60 vs dana 60hd
  143. 8-lug Dana 44 custom build questions/options...need input
  144. HP D30 spool or lock right.....What to do
  145. Teraflex Dana 30 High-Steer System
  146. Pretty much fucked, need some advice
  147. Choices
  148. Dana 44 knuckle swap info please
  149. Axle measurements, bent tubes?
  150. Axle Values.
  151. drive flanges or lockouts
  152. pressing a rear D60 inner hub bearing.
  153. Need to replace seals and axle joints in 10 bolt front
  154. Need a New Axle Shaft, Any Suggestions?
  155. Question about Jeep Axel Differential Fluid Changes
  156. Confirming D60 shaft length
  157. 8.8 cross pin
  158. 8.5 factory pinion shim???????
  159. D30 axle tube seals
  160. AMC 20 With one piece shafts
  161. Info on pinion depth gauges
  162. Brake Lines
  163. D44 CAD question.
  164. noise coming from lock out
  165. Dana 60 Rear on a CJ
  166. 8.8 lockrite install issues
  167. What caster angle?
  168. Wagoneer D44 Bolt Pattern Conversion
  169. D44 swap in a Ranger
  170. welded dana 30
  171. ???60 in a 2500 dodge????
  172. d44 cast wedges
  173. what is the minimum tube ID for a dana 60 front axle
  174. CJ D30 info/help needed plz
  175. DANA 60 lockers
  176. ZJ shaft in a TJ
  177. DRW or SRW front d60 hubs
  178. Need help identifying 14 bolt axle with disc brakes
  179. Gear Ratio/Tire/Rpm - Graph-chart.
  180. drw to srw conversion dana 80
  181. '03 Dodge Ram 1500 Axle Spline repair
  182. Dana 30 axle seal?
  183. lucas, amsoil,mobile, royal
  184. WJ knuckles on a YJ dana 30 Ball joint question
  185. Whats this locker for?
  186. YJ rear driveshaft question...
  187. dana 60 rear spindle reamer
  188. Local U-Joints
  189. CV style axle shafts for the D30's
  190. Dana 27 disc conversion
  191. Gearing help
  192. where to get for best price?
  193. Is this a dana 60 front axle?????
  194. Bolt pattern Issues..
  195. 4.88 R&P DiffCase Question
  196. Unimog axles in a tj
  197. 14 bolt odd question??
  198. Gear Install
  199. Differential Cover Drip - Gasket vs. RTV (or both)
  200. Help identifying axle pics up
  201. front and rear for 67 CJ5 mudd-er and rock climber
  202. What's It worth?
  203. Pinion bearing replacement on F150
  204. Ox Adjustment
  205. D30 wheel hub
  206. D44 Rubicon Axle
  207. locking a 14 bolt ff axle
  208. xj shafts in tj
  209. dana 60 ?
  210. Ford D60?
  211. stock 79 Ford HP60 tube lengths
  212. cj7
  213. More dana 60 locker talk, opinions?
  214. opinions on 35 spline drive flanges for D60
  215. 10 bolt lockers?
  216. XJ dana issue
  217. Dodge vs. ford dana 60
  218. redrill ford 8.8 to 5x4.75 bp
  219. scout front axle disc brake conversion
  220. Anybody do a home build unit bearing to cup and cone?
  221. 10 Bolt Dana 44 Front ?'s
  222. Ford 8.8 LSD vs locker?
  223. Xj axle upgrade options and opinions
  224. Spartan Locker
  225. Need 2 pins for my D30 Detroit EZ locker
  226. Rear locker
  227. Help me w/ id of Warn hubs
  228. 98 xj axle swap
  229. Toss up between gears
  230. ZJ axle upgrade question
  231. Math Geeks and Engineers
  232. Ford 9 truss.
  233. Chrysler 8.25 help
  234. 8.25 in a TJ??
  235. Broderson Axles?
  236. Different Gear Ratio Front and Rear
  237. Front VS rear trutrac's
  238. Auburn Gear LSD (Now With Pics)
  239. Looking for some help
  240. How To Remove Detroit Lockers from D30/35?
  241. cutting a late model 60 housing.
  242. Pinion Breaing or Gear whine?
  243. Best budget U joint
  244. Dana 50
  245. HELP! - D50/60 Axle Advice Needed
  246. Which shafts Yukon/Superior???
  247. rear axle leaking after seal change
  248. Cut the knuckle or dont cut the knuckle.
  249. wagoneer dana44 disco delete
  250. U-bolts
