Axle Tech [Archive] - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
View Full Version : Axle Tech
Pages : 1 2 3 4 [5] 6
  1. 8.8 drive line angles
  2. Need help swapping D30 Pinion Yokes
  3. gear ratio finder???
  4. axle swap....chev axles to yj
  5. dana 30
  6. 8.8 vs 8.25
  7. Gear Pattern
  8. Traction Bars
  9. ubolt question
  10. :sonicjay:HELP with my rearend in TC:sonicjay:
  11. Lock rite locker
  12. D30 heim tie rods
  13. 5x5.5 to 8lug adapters?
  14. axel seal help
  15. Gear change
  16. chevy 60 DRW front
  17. Axle Help
  18. 99 z71 axle question.
  19. Wheel Spacers
  20. 8.8
  21. D35 locker question
  22. d44 question
  23. Front 85 Chevy 60 drw, what rear should i run
  24. What would be the correct angle to set the front pinion on a XJ D30
  25. Hybrid Samurai Front Axle???
  26. What axels would a 92 4x4 ford f350 srw have in it
  27. D30 Question
  28. Crossover steering!
  29. Breaking rear ujoints at rear yoke.
  30. Axle joint size
  31. need a rearend asap
  32. Tie Rods Vs Heims
  33. Dana 44
  34. Place Southeast Mi to do gear change?
  35. e-locker for a boat anchor?
  36. front 60 truss options
  37. 14Bolt SF Locker install?
  38. Weld diff or Ford Posi in stergling 10.25
  39. Excessive shaft play
  40. ARB Pump?
  41. 5 lug to 8 lug conversion Dana 44
  42. Tired of my hybrid axle!
  43. Spindle nut size
  44. 8.8 loose pinion nut
  45. "GOLD SEAL" tom woods u joints?
  46. proper way to replace yoke...
  47. axle interchange
  48. D44 vs Corp 10 bolt
  49. What is this axle shaft?
  50. Locker Identification
  51. dana 80 pinion nut socket size?
  52. how much trans fluid for drive shaft balancing?
  53. YJ On Dana 60's
  54. 1985 chevy D-60 drw front kingpin ubolt size.
  55. Welding axles
  56. 79 f250 d60 question
  57. axle identification
  58. Dynatrac kit?
  59. d60 and d44 question
  60. Dana 30 and 4.10's
  61. Ford 9"
  62. 5:13 gears for a Ford 9"???
  63. Best locker for a 9"
  64. Dana 70 front end questions
  65. Locker?
  66. What Front Axle Do I Have
  67. 1998 Ranger
  68. yj d-30 lockouts?
  69. 10 bolt front clicky hub
  70. Dana 30 and 35 carriers from 3.07 to 4.56
  71. 69 chevy 4x4 drum to disk conversion
  72. automatic locking hubs
  73. Appropriate axle temps?
  74. Lunch Box Locker
  75. Dana 60 help
  76. Which gears?
  77. D60 stub questions
  78. mini spool ?
  79. D44 flat top question
  80. Cast high steer knuckles from ORU
  81. D44 Diff/axle question
  82. Axle lock light won't stop flashing
  83. !!Need Mechanic in Canton Area!!
  84. Bronco2 D35 to D44 swap questions
  85. i need some axla swap info please ttb28 to dana44
  86. dana 60 hub info
  87. D30 Alloy Shaft Experience
  88. Welding Spiders for Jeeps
  89. how to disconnect passenger TTB axle shaft??
  90. this seem legit?
  91. 35 spline Ford 9" locker options..
  92. 92 ford dana 60
  93. How good are stock 60 shafts?
  94. CAD Delete?
  95. straight or ttd?
  96. 15" wheels on a front 60?
  97. D44 questions
  98. From 7.5 to 8.5??
  99. 4.09 gears in a D44?
  100. D44: Is this normal? and Look at these shafts
  101. Rear streer on the street .........
  102. Info on "609" axle
  103. Noisy Aussie locker
  104. Lug conversion questions.
  105. gm 10 bolt front posi?
  106. jeep axel
  107. D60 35 spline stub questions
  108. I need Help on front axle upgrade/decision 94 YJ
  109. 1997 Dodge 2500 D60 question
  110. D60 ujoints ?
  111. posi track.
  112. Beam axles.
  113. WJ/XJ unit bearings on a D30
  114. Rear end clunk?
  115. Spool in YJ
  116. dana 60 ford kingpin race issues
  117. Spicer / Dana 20 Rear End Fill Plug Stuck
  118. ford 9.75 cross pin
  119. ford 8.8 carrier
  120. Changed springs axles shifted
  121. dana 60 4.88
  122. Dana 30 ???
  123. dana 44 brake upgrade
  124. d30 3 piece shaft swap to 2 piece
  125. gearing help
  126. lockrite lockers in yj front stock axle
  127. 95yj upgrade heavy duty axles
  128. disconnect 44 ?
  129. Pinion bearing went out
  130. aussie-lockers are these a good deal?
  131. Half ton chevy in a Yj? Any help
  132. Who can do a complete axle retube near southern MI?
  133. 10 bolt singin the blues
  134. front yj vaccuum disconnect alternatives
  135. want to buy gears but where?
  136. Axle combo question
  137. burn outs
  138. can someone tell me this gearing?
  139. bearings
  140. Caster/ Pinion Angle?
  141. Van Axle Width
  142. Anyone run a welded 7.5?
  143. Ford Bronco HP44s with 'cast' wedges
  144. Dana 35 Locked
  145. 14 Bolt welding question
  146. Dana 35
  147. Detroit locker question
  148. Differential fluid question for Dana 30/35 (2006 TJ)
  149. Could anyone explain me what full spool and mini spool is?
  150. Dana 61
  151. D44 TJ Rubicon Axle
  152. Dana 30
  153. lock out hub questions
  154. Mixed Gear ratio question
  155. '99+ Silverado 1500 Axle in a 88-98?
  156. dicision between 44 or 60
  157. isuzu dana 44
  158. Dually to single rear wheel
  159. 8.8 with 3.55's and ls?
  160. my 4x4 acutator
  161. D44 Stub shaft lengths
  162. trailer axle questions
  163. dana 35 LSD problem
  164. rear axle angle?
  165. yj yoke question?
  166. D44 Warn hub removal?
  167. 92 Chevy 1500 Front axle Breakdown?
  168. cutting splines
  169. Explorer 8.8...spring Over Or Under???
  170. 1/2ton5lug to 3/4ton8lug nuckel swap?
  171. D44 and D60 inner spindle bearings
  172. dana 44 and dana 60 inner spindle bearings
  173. 8.8 Disc brakes on a 9 inch
  174. HP Ford axle project questions
  175. sterling 10.5 front axle, Now a Build Thread!
  176. torque capacities
  177. 75' hp dana 44 drum to disc
  178. What 1-ton truck should I pick up for axles?
  179. Mopar 8.25 axle for XJ- any differences?
  180. Dana 80
  181. dana 44 U bolts
  182. dana 44 cv's
  183. Spartans Lunchbox Locker
  184. Popping bearings off my crapo D35 carrier
  185. 8 lug to 5 lug??????????
  186. Need an 8.8 rebuild and 9" ends installed
  187. What will 4.10's do to my gas?
  188. Ford D30 vs. Jeep D30
  189. Advice with waggy 44
  190. Beware 4wd hardware
  191. Next generation Dana axles
  192. Playing with my 9 inch.
  193. 14 Bolt question
  194. dana 44 cutting to make fit in xj
  195. needed axle repair shop
  196. Fondling my axle.
  197. Gear man?
  198. l/f d44 ranger set up
  199. Blewup dana 60 on the road?
  200. D30 Wheel bearing issue?
  201. dana 35 "c" switch to bolt in?
  202. Questions about high steer arms
  203. Full size UBE or standard U-bolt?
  204. what lockers for my 97 cherokee
  205. any one running dynalock hubs
  206. Corp 14 questions and gov-loc
  207. what axles do i have???
  208. Dana 35 broken spider gears
  209. 8.8 tech
  210. ford 10.5 gear setup ?'s
  211. Where are you guys buying your dana 60 custom length axle shafts?
  212. tera flex locker
  213. 1980 j10 d44 delete delete
  214. 8.25 Axle Whine
  215. best gears for my setup
  216. bigger axles on xj
  217. Dana 60
  218. U joints?
  219. Dodge Dana 60 CAD question
  220. Do I need a seal?
  221. toyota vs D44
  222. 4 x 4 didn't work
  223. factory limited slip?
  224. Question for guys with 9 inches....
  225. Cherokee and Corp 10 bolts?
  226. what could the gears be in an 89 dodge w/ cummings
  227. Lunchbox or spool for an 8.8 in a TJ?
  228. Diff fluid through overflow vent
  229. Free Selectable locker for a full float axle
  230. auburn lsd?
  231. I bought too small of Dana 44 Gears??
  232. 85-88/88.5-98 D60 inner shaft difference
  233. Pitman arm question
  234. options to make Ex8.8 5x5.5bp?
  235. are front and rear gears the same in an axle?
  236. Ford Dana 44 carrier the same as Chevy 44's??
  237. High Steer Arm
  238. 3.55 carrier housing 4.10 gears
  239. Rear Axle - Difference between TJ and ZJ mounts?
  240. Recommendations for one ton steering supplier?
  241. Lube required for carrier bearings?
  242. how do i find out what gears are in my d30???
  243. 10 bolt and dana 44?
  244. replace ring gear bolts?
  245. fullsize or not.
  246. converting to toy DS?
  247. What would I need to re-gear?
  248. Dana 60 lockout hitting the spindle.
  249. ford d44
  250. ford high pinion dana 44
