Axle Tech [Archive] - Page 2 - Great Lakes 4x4
View Full Version : Axle Tech
Pages : 1 [2] 3 4
  1. 8.25 lsd install????
  2. Two ?'s on what I found in an AMC 20
  3. this time, a ford 8.8 question
  4. d35 and gm 10 bolt?
  5. Yes a Dana 30 question
  6. Jeep axle ID?
  7. Strength of 5.13's in Rubi D44
  8. Dana 60 disk brake swap
  9. 60 knuckles on a 44?
  10. 1968 dana 70's
  11. Were to buy gears (new info 8-26-07)
  12. D44 seals
  13. what 44 for a tj build?
  14. Dana 30 carrier from a YJ in a CJ
  15. How do these compare in strength ....
  16. Ford axel question
  17. Axle ID
  18. Ball joint pref?
  19. lincoln locker
  20. Dana 44 carrier break
  21. Alloy Shafts
  22. tierod reamers?
  23. what does the 2L or 2H mean at the end of the #s stanped on the ring gear mean?
  24. 8.8 crush sleeve or not?
  25. 8.8 Trac-Lok issue or not?
  26. Dana 44 break down help new questions 9-04-07
  27. should i rtv my pinion seal or not?
  28. Scout axle width
  29. d35
  30. D30 Shafts - TJ / XJ
  31. D44 driver's drop?
  32. Tj dana 30 pinion slop/play at yoke
  33. Chevy Axle Swap Questions
  34. Superdut Dana 60 questions...
  35. Scout stub shaft
  36. POrTaL AxLeS
  37. Rubicon D44
  38. d60 carrier
  39. Warn Hub Conversion For Dana 30's
  40. Follow up ? to "Warn Hub Conversion For Dana 30's"
  41. mini spool install
  42. d-30 disco....
  43. Axle Info
  44. CV shaft
  45. How strong?
  46. dana 44 specs
  47. spider trax 9 inchs
  48. dana44 hub bearing torque???
  49. old rockwells
  50. Dana Spare Parts?
  51. Is this a D60?
  52. 14 Bolt torque specs
  53. D30 Axle seal questions...
  54. Early Bronco D44 Specs?
  55. d30 width?
  56. D30 axle seal removal
  57. Couple axle questions...
  58. amc 20 bearing info needed
  59. how do i know what gearing i need
  60. D44 Locker & Axle Upgrade...
  61. Switching 9" carriers for DD - insanity?
  62. D44 XJ Info
  63. D30 max tire size...
  64. zj dana 35
  65. Time to regear the LJ?
  66. amc 20
  67. Are my gears Standard Cut (LP) or Reverse Cut (HP)?
  68. what rearend is this
  69. Respline shafts ?
  70. re-gearing
  71. D44 Axle Upgrade...
  72. ARB air v. Detroit Lock
  73. Dana 35 Axle Shaft
  74. D44 Splines....
  75. Dana 60 -- sterling 10.25
  76. another xj 8.8 question
  77. 5x5.5 stock tj rear shafts?
  78. Suggestions for axles?
  79. D30 steering idea
  80. Custom hubs?
  81. CJ Dana 44
  82. rubicon axles on 99tj
  83. dana 44 manual lockouts
  84. Were to get 35spline outter dana 60
  85. D44 hi steer in XJ no worky
  86. gearing dana 30 hp
  87. D60 in a YJ
  88. Welding axles....streetable?
  89. standard or reverse rotation
  90. Welding on the Center chunk ?
  91. Diff Fluid
  92. D44 Hub question
  93. WTF...Dana 61?
  94. Auburn Locker
  95. Axle & Stering Questions for Jeep
  96. Ring and Pinion Brands
  97. verifying gears
  98. Best aftermarket axle shafts?
  99. How do you take spindles off a Dana 30
  100. Dealer pricing fyi
  101. How to: Tj/Xj 30 with 44 knuckles
  102. Dana 60 high steer arm dimensions
  103. Dana 30 gear change
  104. Waggy axle gear ratio
  105. cut and turn ttb dana 44
  106. cj-7 axle upgrade
  107. Axle option for this winters project
  108. D44 Axle Housing
  109. limited slip instal help needed.
  110. Dodge vs Chevy Dana 60
  111. What axle do I have
  112. Warn 5 on 5.5 conversion kit
  113. Good Front Yj swap, suggestions?
  114. ex 8.8 vs f150 8.8 vs 9"
  115. dana 30 Shafts...
  116. HP 44 leaf sprung
  117. XJ - year they got rid of Vac Disco?
  118. rubi arb in scout d44
  119. 1989 Grand Wagoneer Axles?
  120. Im stuck.... Shafts?
  121. why are these so big?
  122. HP 44 in an XJ
  123. dana 44. 5 lug to 8 lug?
  124. 94 YJ W 35s slows down up hills.
  125. TJ brackets
  126. remove axle shafts?
  127. d-30 question
  128. D44 Outer question
  129. How to install a spool?
  130. pick n pull amc20 disk brakes...
  131. Dana 44 and r&p questions.
  132. D44 question
  133. ARB shim pack question
  134. R and P install kit
  135. Need to borow a puller
  136. dana 60 =dana 61
  137. "Overfilled" Diffs
  138. ARB Bulkhead fitting question
  139. AXLE HELP!!! very important
  140. Adjustable ball joint
  141. yj front lift leaf and steering box questions
  142. spindle hub wrench
  143. Vacum disc.. question
  144. Welding the rear axle??
  145. Somebody School Me On U-Joints
  146. rear trac bar questions
  147. Install question
  148. brake question...
  149. more yj to tj axle conversion questions
  150. chromoly axle questions
  151. Scout 44's trade for Wageneer 44front 44/20 rear
  152. Chevy Dana 44 front - 6lug to 8lug?
  153. Dana 44 axle drop swap question
  154. front axle from a 2000 wrangler on a yj?
  155. Eaton E-Locker fluid?
  156. D44a
  157. Wahoo
  158. Geo -Spools, Lockers, or what?
  159. Rubi air locker?
  160. D60 kingpin H1 arms and cap print
  161. caliper bolt: 79 f250 d60
  162. Jig for setting TJ brackets?
  163. Ford 9 or 8.8
  164. Machined Dana 60 Drw Hub
  165. Dana 30 regear instructional write ups ?
  166. Dana 35 - how much play
  167. HP Ford Dana 44
  168. dana 35
  169. reuseing ring gear bolts
  170. Sterling 10.25 and D70
  171. dana 30 spool?
  172. Where is that part?
  173. Contact pattern check round 5 and final
  174. Amc 20 install question
  175. Another Dana 30 ??
  176. 8.8 in place of D35... ride heigth problem....
  177. hp d44 question
  178. 07 Dodge rear lp AAM 9.25
  179. Locker question
  180. 8.8 question????
  181. 4wd isn't working
  182. D44 high steer arms, corrected for H1 offset
  183. Gearing Question
  184. 9" detroit locker big bang??
  185. dana 44 front hub swap
  186. E.z. Locker Problems
  187. Crazy thought. ever been done?
  188. weld it or buy a spool
  189. chevy 10 bolt vs D44
  190. Gear ???
  191. tj 44 rear disc conversion
  192. D60 question
  193. reuse ring gear bolts on 14b?
  194. Need Dana 44 Work: Best West Mi Shops?
  195. No love for the 10.5 sterling
  196. 78-79 hp dana 60
  197. rubicon d 44
  198. The poop on Front Dana 60 Axle Tech
  199. what axles options are there?
  200. welded rear end on DD
  201. Looking for cheap locker
  202. Anyone do 99 f350 superduty axles in a yj yet...need help
  203. number of splines on 1972 Ford dana 60 Camper Special
  204. Pinion Angle
  205. 14 bolt width
  206. chevy 10 bolt front axle!
  207. Its SOLVED stripped D60 kingpin
  208. quick d44 question
  209. which ford 8.8???
  210. which gears to use?
  211. Gearing Question
  212. amc20 pinion bolt size
  213. Axle shop near Grand Rapids
  214. what vehicle did this come from. **Now with pics**
  215. Shops that can narrow hp 44?
  216. Sterling 10.25 ???
  217. LockRight Interchangeability?
  218. quick quesetion
  219. Narrowed axle?
  220. lookin for information on axles
  221. drivers drop axles
  222. What are my options?
  223. D 30 in a ZJ
  224. DJ5 knuckles
  225. 77.5 hp dana 44 from a f-250
  226. Whats different between a XJ and YJ D30
  227. 86 CJ Dana 44 parts lookup ?
  228. question on 1 ton dodge rear end...
  229. 10 bolt upgrades?
  230. 4.56's and 32" tires?
  231. d30 gears
  232. ARB locker o-rings
  233. gears
  234. What gears to run?
  235. Rubicon Owners--Axle Lock Q?
  236. axle shortend
  237. Dana 60 rear question
  238. 14 bolt Disc Brake Bracket spacer length
  239. Dodge 44 & 9 3/4
  240. Reviews on LSD's
  241. Ford 9 inch disc brakes
  242. d-30 nut size??
  243. OK, Ford 9" guys, bearing preload
  244. carrier in cj dana 30
  245. dana 30 swap question
  246. Closed knuckle vs. open???
  247. 8 lug rear 9 inch conversion?
  248. tj d30 axleshaft in yj d30 axle.
  249. "c" material question
  250. 14 Bolt
