- TJ rear upper adjustable arms
- yj fender
- leaf springs
- TJ Sending Unit
- TJ Black upper door skins
- Front bolt-on bumper with winch mounting plate for YJ
- Need a chevy bellhousing
- Flatfender
- YJ Soft Top
- dana 44 lockers
- full doors need for a 91 wrangler
- full doors needed
- dana 60
- Transfer case drop kit for XJ
- pass side headlight bezel 95 XJ
- Trail Rig to trade for my truck
- Yoke for a willys
- Comanche rear driveshaft
- Wtb New Body Style S 10
- XJ Roof Rack
- Rear Pinion yoke
- Friend wants a CJ
- Dropped Pitman Arm and Soft Top for CJ7
- T-176
- FINDER's FEE: Jeep CJs/FSJs/YJs/XJs to part out
- Scout Dana 300
- YJ soft top hardware... No top needed..
- Need Chain Link Fence
- Truck bed for 96 f250
- rear springs
- one 32x11.50R15 BFG ALL-TERRAIN ko
- Looking for a 21 spline NP231 Xfer case
- YJ rear yoke
- stock foglight /lens
- d44
- CJ wide-track tie rod (to borrow...Allendale area)
- toy 22RE or chevy 4.3kit
- Wanted: Phazer, Phazer II, Exciter.
- 35x12.5x16's what do ya got in that size??
- B&M shifter cable
- 35x12.5x15 Mud Terrians
- high steer
- Center council
- WANTED Rubicon Express extreme duty 2 ½” lift springs for a YJ
- Stock TJ bumper and floats
- Ford Dana 20 Rear Yoke
- ONE Tire - 32" to 35" for 15" Wheel
- TJ Bumper
- new front axle, that can handle 37"
- need spot to drop those old Snowmobiles?
- YJ shackles
- TJ Passenger Seat Belt Reciver
- YJ Family RollBar
- zj pitman arm
- lift kit
- d300
- Tj flairs....
- TJ Hardtop
- TJ sway bar links
- wtb Jimmy blazer or truck
- Teraflex S/T sway bar
- What axle for 32"
- 4" lift parts for 97 TJ
- TJ driver side window
- TJ receiver hitch
- WTB: Cheap running 4x4 Toyota
- L.F. fender for 97+ Xj
- YJ lift kit
- FJ-40 jump seats
- Wanted: cheap/Free Snowmobile
- Wanted 6.5' Snow Plow for S-10 Blazer
- Narrow Track Axles
- need some 3/4 ton ford 44 parts
- Taillight gaurds
- ARB Bumper
- old 35-36" tire for a trail spare (15" rim)
- yj main leaf
- CJ chrome grill
- ZJ Front Sway Bar
- Jeep xj radiator...
- Need a cj7 drverside fender
- 2.5l engine
- Computer for '94 F150/Bronco
- natural gas furnace
- Scout Dana 44 rear axle (3.54 gearing)
- 5 speed trans needed
- 904 trans torque converter
- 15x8 jeep canyon rims
- 04ish driving light (fog)
- Wanted
- 2.5 ton rockwell axles
- air compressor
- TJ Hard doors wanted CASH
- yj front clip
- Go cart frame...must have suspension.
- Master Clylinder for Cj
- Stock coils and control arms for an XJ/WJ/TJ?
- 2000 TJ Heater Controls
- pickup cap
- Needed GOOD!!! 700R4
- wanted list!!
- 9" Housing
- fire emergency lights
- TV stand
- Tj front axle
- Chevy Big Block Harmonic balancer
- D30 for 95 XJ
- plow truck jeep
- XJ stuff
- snowmobile trailer
- 3" Coils-XJ 31" tires
- Need shocks
- free truck
- Stock TJ taillights
- need front seats for Grand Cherokee
- D44, 8 lug.
- yj axle shaft
- XJ front drive shaft
- Multifunction switch for TJ
- complete factory tj jack setup
- looking for TJ for a friend
- CB Radio Set Up
- semi trailer
- Back Window for Soft Top
- a xj
- Drop Pittman Arm
- need 2 bb spacers asap/wheels
- need hood hold downs for tj
- Dana 60 Parts
- axle shafts for 9 inch 76 77
- wtb 6 lug wheel's
- One 225/75R15 goodyear wrangler RT/S
- H2 rims
- 235/75/15
- CJ Spring Lift
- good set of 33's
- 245/75/16
- My kid has put in a request, he wants me to find an Argo
- 55 Willys petal assembly
- cheap quad
- Pioneer headunit
- Lightbar and Lights
- parking brake
- Logitech z-640 computer speakrs
- Driver's side front fender flare '99XJ
- 31-32 r 15 tire
- TPS for a 95 4.0
- Spacers
- 98 xj parts, driver door, hatch
- Snorkle for a 95 Dodge Ram
- YJ full doors
- Old quad...no need for motor or stuff
- I'm in need of an older like early 2000's to late 1990's Dell Tower
- Jeep Comanche fuel tank
- Front XJ Springs needed
- CJ chrome grill
- TBI intake
- '82-'86 CJ-7 parts vehicle (4-cyl. 4-speed)
- 4.5" to 5" rear lift blocks
- 4 inch YJ leafs
- 38" tires
- Rear Leaf Springs for an XJ
- 700r4 to np208 adapter
- Temp sensor and Oil Pres. Sensor
- Wide track Dana 30 shafts for a 86 CJ7
- Need 1 stock CJ rim and 1 35" tire
- 700r4 and tcase from s10, s15, s-blazer, etc.
- cheap lift 77-87 chevy straight axle
- TJ Carpet Light or dark gray/black
- cheap cj7 or 8
- 2 31" BFG A/Ts
- dana 300 t case
- Complete tailgate for full size Jimmy
- full soft doors, rounded corners
- 98xj rear bumper w/ends
- 5" lift parts 98' dodge ram 1500
- YJ air cleaner holder
- o2 sensor
- Old 2 speed TH350
- Front swaybar disco
- Set of 15x10" 5 on 5.5" wheels
- 97 grand stuff...
- R&p
- dodge headlight
- dodge bumper
- Demountable trailer wheel/tire
- `99 Ford Ranger fornt end sheet metal
- some stock size tires
- d60 rear
- Mastercraft, Bestop or similar seats
- Car CD Player/Stereo W/REMOTE
- Stock TJ flares
- Wanted radiator for a 86 Cj w/258
- D44 Flat tops
- Failed or broken Harbor Freight Winch
- stock tj control arms
- Cheorkee Tires
- Chevy Vega wagon
- Ax15
- wtb: small starter
- 16" aluminum wheels 5 x 51/2
- rowing machine wanted
- Portable Ext. hard Drive
- reliable vehicle for parents
- Wanted: Chevy/GMC parts
- Help replacing steering column bearing
- Cj Tilt Steering Column
- wantin to trade 4- 40x13.5x17 MTRs
- 35" MTR Spare
- Winch
- jeep wanted xj zj or tj 98 or newer
- waggy front leafs
- front diff for 89 s10
- Output Shaft For A Np231
- Need a outputsaft for a np231
- GM 12bolt shaft
- TJ flare turn signal lights
- 35's
- dirt bike
- Carborator
- wanted: TJ rear dana 44
- Body Or Body W/Frame
- Dana 44 flat tops
- DriverDrop D44
- TJ front flares
- coil springs
- Rear Dana 44 TJ
- '91+ Flywheel (for 4.0L H.O. motor)
- WTB: LJ Soft Top
- Living Room Furniture....
- Dauntless II Buick 350. Cheap
- '95 YJ 297x D30 shafts
- 87-95 wrangler rear crossmember
- 30x9.50 or smaller aggressive tires
- Front Drive Shaft
- Rebuilt/used Chevy 350 engine
- 304 flywheel and brake parts.
- I want your beat up YJ fenders
- Rubicon springs
- 3.73 gears for a Scout D44 front
- Driveshaft Stuff
- 2'' lift shackles!!!
- 79-85 rear cadillac eldorado, riviera, or seville calipers
- WTB: Full Width Axles
- YJ windshield frame
- Wiper motor (front) for 99 TJ
- CJ 7 tub
- TJ carpet and seats
- 6 lug wheels...
- yj project in the detroit area
