  1. WANTED: YJ gauge cluster
  2. WANTED: YJ gauge cluster
  3. WANTED: Chrome front grille for YJ
  4. EGT/Boost gauge
  5. Jeep ZJ adjustable control arms and track bars
  6. Engineering Job wanted?
  7. pair of 16.5x14 rims and a pair of 15x14 rims both 8 on 6.5 lug
  8. wtt yj for tj
  9. cheap truck
  10. Ford Superduty F250 bed topper Cap 8 ft bed
  11. engine mounts for a V8 CJ
  12. glass
  13. WTB 8 lug ford ttb front axle
  14. WTB 76-83 CJ5 Best top supertop
  15. WTB-grand cherokee lift parts and other stuff
  16. WTB, 4 15x8 Steel wheels!
  17. WTB: JK D44 Front
  18. XJ hatch
  19. Dodge parts wanted
  20. TJ : Blower Motor wanted
  21. 99 xj rear tail lights
  22. 97 TJ parts needed
  23. Wtb line lock
  24. 91-95 xj front driveshaft
  25. 2000 chevy t-case
  26. 99-2000 wj 4.0
  27. ford 4.9 300 I6 motor mount plates
  28. 16 or 17 inch rims - 8 on 6.5
  29. YJ Parts NEEDED
  30. 89 yj dana 35 3.73 gears
  31. radius arm/coil sprung dana 44
  32. wanted xj
  33. late 80's early 90's xj
  34. looking for a bumper and roof rack parts for my zj
  35. s-10 10 bolt gu6
  36. jeep yj transfercase linkage
  37. Pre 97 XJ Badges
  38. YJ clutch line or assembly, and a radiator
  39. ZJ hood and 4.0 motor
  40. Jeep Cherokee for a 1st vehicle
  41. xj lift parts, radio, cb, towpoints, cig lighter...
  42. Wanted 265/75R16 or 285/75R16 tires
  43. junk 33
  44. wtt Z71 diesel ext cab for 4 door pickup
  45. bronco/f150 parts
  46. Jeep Wrangler Radio
  47. WTT rims
  48. WTB Ford 4x4 shifter
  49. Wanted: Transfercase for a 1997 Jeep Wrangler
  50. Long arm crossmember for XJ
  51. 15x10 5on 5.5 Steelies
  52. Something heavy and steel (old wheel, 14b brake drum...)
  53. looking for a yj lift kit
  54. Looking for Red ZJ Door!!!
  55. Red/Burgandy XJ Seats.
  56. wtb f350
  57. looking for zj front coil springs will pay cash
  58. WTB: 88-98 chevy parts
  59. s-10 tailgate
  60. ARB locker for front D44
  61. Cj D30 Housing & GM Ft. 10-bolt Shafts & Knuckles (11/15/10 D44 hardware instead)
  62. Ford Ranger Trans
  63. CJ or Yj cowl
  64. trade for cherokee
  65. looking for 8.8 and 44 gears
  66. Need a heater core replaced
  67. shed
  68. WJ tires
  69. 4.0l motor
  70. sled parts
  71. 4.88's for yj 30
  72. TJ Parts needed...
  73. Wanted... YJ Jeep Hood
  74. cheap set of 15" jeep rims
  75. Pass front window motor for '88 XJ
  76. dodge ram 3500 transfer case
  77. Shorty headers for 96-99 chevy truck.
  78. yj rear wiper wires
  79. f150 parts
  80. Pop up camper wanted
  81. H2 rims
  82. 99 xj reciever hitch
  83. 4.0/AX-15 Block Plate / Spacer
  84. Pass side 1/2 door for tj
  85. 89 yj leaf spring needed
  86. 1999 cherokee computer 4.0 auto
  87. Cherokee SBC 350 Swap Parts
  88. Lathe, drill press
  89. ZJ front double cardon joint
  90. 92-95 f150 parts
  91. dana 30 front cj axel( two )
  92. XJ Steering aluminum spacer
  93. 17 rim for spare tire
  94. zj front lights
  95. cheap transportation, good mpg's
  96. TJ wiper motor
  97. wtb 7.3 powerstroke
  98. 6" stove pipe
  99. TJ D30 locker
  100. Need TJ front bumper, driveshaft
  101. WTB ford explorer rims
  102. 8.8 disc brakes
  103. chevy rear lift springs
  104. 95-98 Full size GMC Grill OR Chevy Air Bag
  105. NICE and CLEAN Seats for my '88 XJ
  106. TJ full driver side door
  107. wtb/wtt for ranger explorer or jeep rims
  108. WTB: 33" or 32" Tires for a 15" Rim
  109. Anybody have a powerstroke alternator?
  110. torpedo heater
  111. 02 Monte carlo rims. 16 inch
  112. Trade muzzle loader for wheel and tires
  113. 1987 F250 brake caliper and a spare f250 steel wheel for a spare
  114. Tapered reamer for gm tre's
  115. Looking for 96-02 Dodge Cummins 4X4
  116. YJ wiring harness
  117. 20 inch tires
  118. truck needed asap
  119. 1980's or early 90's style ranger 4x4
  120. transmission
  121. 14" car tires
  122. wtb xj D30
  123. TJ Factory Soft Top Hardware
  124. bumper jack or farm jack
  125. xj parts
  126. Dana 30 with 4:10's for an XJ, TJ, etc.
  127. Pick up topper wanted to fit a `08 Dodge short box
  128. WTB 38x11.00x15 BOGGERS
  129. WTB 16X10 6 o 5.5 Chevy Rims
  130. 98 Blazer 4 door lift
  131. cheap wheels for 98 grand cherokee
  132. Media Blasting/Powder Coating
  133. Wanted NT CJ dana 44 rear axle shaft or whole axle
  134. Wanted 700R4 to D20 adapter
  135. 4.0 xj auto flywheel/flexplate
  136. Corporate 14 Bolt Axle srw 67" wms
  137. steel wheels
  138. 2001 ford 5.4L 2 valve
  139. 30x9.50 or 31x10.5x15
  140. WTB Lund Visor for 73-87 chevy
  141. toyota body parts
  142. Xj rear leaf springs *DO NOT NEED*
  143. WTT late 70's F150/Bronco 6.5" lift coils for shorter
  144. 1/2inch osb
  145. NEED Rear axle ASAP - or will pay to have it fixed
  146. Upgrades for my 96 Cherokee
  147. rear dana 44 spider gears 2000 tj limited slip
  148. Need a Distributor Accel or MSD for a 304/360
  149. Jeep CJ Fiberglass front fenders and hood.
  150. Jeep CJ Steel fender Driver side or both sides.
  151. WTT tires/wheels for 60/14 axles
  152. sterling 10.25 bearing races or install kit
  153. WANTED: NP242 Transfer Case
  154. 5/16 hardned push rods 7.150 length
  155. wtb snomobile!
  156. 72 chevy doors
  157. Wanted 5 point harnesses and seats
  158. K5 blazer
  159. Ford Super Duty parts
  160. 12" Steel Disk
  161. 2001 Tj mirrors
  162. 98 x plorer mirror
  163. 91 - 94. Ford explorer parts wanted!!!
  164. 4.88's for a dana 30
  165. 99 XJ Front Driveshaft!
  166. sterling 10.25 center section
  167. Radiator TJ
  168. complete steering column
  169. 31"x 10.5 x 15"
  170. Stock rear TJ springs
  171. American racing rims- Cheaper is better
  172. 96 XJ rear hatch lock wanted
  173. Ford 8.8
  174. WTB, front axle and more for 06 wrangler
  175. WTB: 08 dodge ram head and tail lights
  176. Looking for a Ford Dana 44
  177. 235 tires
  178. cherokee manual trans shifter boot
  179. tires 33-35 for 15 inch rim... Near muskegon....
  180. meyer blade
  181. WTB 03-06 Wrangler soft top windows
  182. aw4 dipstick tube
  183. want to rent a towbar for a day.
  184. Need fab help... have brand new bumpers for trade
  185. Wanted tires
  186. Needed URGENT
  187. looking for 1999+ tj **pics**
  188. Cheap AX-15
  189. rpm gadge
  190. turbo 350 to 205 adapter
  191. 6.2 diesel truck
  192. steel S10 wheels
  193. plexiglass (acrylic, etc) cheap or free
  194. Wanted Dana 44 or bigger rear axle TJ
  195. WTB: driver's front black textured fender flare for 97-01 XJ and/or complete set
  196. ford 4.0 wanted
  197. looking for parts for a 2003 TJ auto, ECM, ignition.
  198. Non-A/C Heater Box for a Ranger
  199. Ugly/Damaged/Rusted TJ parts
  200. 2.5" .250 wall DOM
  201. NP203 adapter to a turbo 350 and a doubler
  202. dana 30 (problem solved)
  203. 79 to early 84 Toyota 4x4 power steering box
  204. 1978-79 ford truck
  205. need 98 grand cherokee transfer case
  206. 4.10 ring and pinion 10bolt
  207. kid i know wants a truck.. heres the craigslist post of that he has to trade for one
  208. wtb topper for chevy
  209. wtb visor for chevy
  210. Looking for some Mud Terrains!!!
  211. 1996 or newer S10 5 speed needed
  212. Wanted ax5
  213. 30-9.50-15 Tires
  214. I'm looking for a wide range of project vehicles! -Have $600 cash
  215. Wanted chevy Dana 60 complete srw
  216. HO Valve cover
  217. Floor board
  218. Reamer for JCR 1-ton steering
  219. Lookin For a 125 or a Warrior-ish quad
  220. rifle barell
  221. 97-99 Rust free XJ body/shell
  222. nut and bolt bins
  223. nice 2 stage snowblower
  224. WTT 18' car trailer+ cash for 25' Gooseneck.
  225. call of duty black ops RC car
  226. J truck cab
  227. 78-ish CJ-5 (FIVE) tailgate and side-mounted tire carrier
  228. WTB YJ or XJ
  229. light bar, and or offroad lights
  230. Dish Network HD reciever and dish
  231. 15x10 8 Lug Wheels and Rotors
  232. Needed 6 bolt front spindle for Dana 60
  233. WTB: MANUAL SHIFT BW 1350 or 1354 Ranger, Bronco II or Explorer Transfer Case
  234. Winch Plate for 95 YJ
  235. WTB model 20 tailshaft
  236. WTB ipod touch 8gb
  237. autometer gauges set
  238. yj shocks for a 4 inch lift
  239. looking for a spare tire and XJ roof basket
  240. Explorer Lockout Conversion
  241. TJ windshield
  242. 35x??x16 or bigger tires
  243. WTB: (1) Goodyear GSA's 30x9.50x15
  244. Ford Front axle Wedges, c-bushing mounts
  245. 4.10 or 4.56 TJ D44 gears (and possibly carrier)
  246. AX15 needed
  247. Hole saw to drill out for rear led's
  248. 93 Ranger steering gear box.
  249. XJ 8.25 axle Yoke..
  250. Wanted - TJ Rear Seat Belts/Hardware
