  1. Scrambler full soft top WANTED
  2. scrambler top wanted
  3. 91 Ford Explorer Front Left Fender
  4. ifs toyota steering box
  5. Want small engine 20-75 hp
  6. 35x12.5x18 tires
  7. 80-96 bronco tailgate
  8. WTB Manual lock out hubs for 93 explorer ?
  9. Wanted: 1994 F350 8' dually bed
  10. xj flares
  11. Wanted: Automatic Transmission for a '97 Jeep Wrangler
  12. Grand Am Wheels
  13. Newspaper Vending Machines or Honor Boxes
  14. WTT 16.5X12 589 alloys for 16.5x8 or 10 steel
  15. 93 YJ stock belly pan.
  16. 4.0 for a xj
  17. Wanted zj front coil springs
  18. 31x10.5R15 tires
  19. yj hard doors
  20. k5
  21. arm rest cover/AT/winter tries
  22. jeep yj, meyer plow hardware
  23. 39.5x18x16.5 Boggers
  24. Wrangler Rear Seatbelt
  25. 15" chevy 8 lug rims wanted
  26. 4bt
  27. Early CJ5/6 windshield frame
  28. Rear TJ flares/drive shaft
  29. Need some cheap rear shocks for yj
  30. looking for a set of newer ford metric bolt pattern rims
  31. looking for a cheep lifted xj or zj
  32. alternator for 86 Toyota truck 22R
  33. Lower control arms for 00 XJ
  34. Drop Pitman arm for 00 XJ
  35. WTB Jeep/dodge 4.7 engine
  36. WTB: lift shocks 2-4 inch chevy truck
  37. XJ 2wd dummy axle
  38. 91-95 2wd XJ
  39. Briggs & Stratton 7HP Vertical Shaft small engine
  40. 36x14.5x16.5 super swamper STS's no longer need
  41. 241c, front axle, and leaf springs
  42. TJ Hardtop or Rear Window
  43. want to trade my 93 xj with 5.5 lift for wrangler
  44. Looking for a set of 33's
  45. ranger bed
  46. Need a 35x12.50 R17 Spare
  47. XJ parts for a 1996
  48. Johnny/Cartridge joints
  49. Mechanic work in Battle Creek area - Pontiac G6, bearins and Ball Joints
  50. D35 with 4.10 gears
  51. wtb 31'' mt or at tires
  52. need a chevy 350
  53. 1984 to 1991 f-series Steering Column
  54. Chevy Turbo 400 from a 208 or 241 t-case
  55. 5 horse horizonal shaft engine
  56. Wide track tie rod and drag link
  57. trade my 42 irocs for a set of 37 inch tires 17 inch rim.
  58. K5
  59. 19.5" rims
  60. Need asap! Yj parts
  61. YJ Shackle Mounts
  62. tj front axle
  63. Stock or 2" lift Chevy springs
  64. 77 cj trans
  65. cheap 33x12.5x15 (~25% tread?) and 15x8 5x4.5" wheels
  66. T5
  67. WTB: Dodge Ram 2500 sport hub cap '00-'02
  68. front drive shaft for a 94' YJ
  69. Anyone have one of these seats they wanna sell?
  70. wtb Clean 98-01 XJ Jeep Cherokee bought one!
  71. 4.2L Crank and Rods
  72. 700r4
  73. B&M Shifter for a c6
  74. Mid 90's Chevy 2wd driveshaft
  75. need trannys for 2.8 S-10 auto
  76. trade wide swampers for skinny
  77. 89-95 f series diesel parts
  78. WTB: 33x15" tires
  79. Chevy truck lift
  80. Wanted: Front spindle, hub, lockout and broken axleshaft
  81. Need any set of 16" 5 lug aluminum wheels for cheap
  82. 98 zj d35
  83. WTT LAR AR15 for jeep wrangler.
  84. WTB project Jet Ski
  85. 2000 explorer hitch
  86. Shotgun case
  87. cj tub
  88. trade for 84 truck looking for jeep or k5
  89. Ltb a xj
  90. 285/75R16s
  91. box steel for a front bumper ...
  92. Transfer Case for a 2001 Chevy Suburban
  93. looking for a 6.7 cummins
  94. Someone to part out a ZJ in Oakland County
  95. toyota trans-transfer case parts
  96. chevy bench seat
  97. Early Bronco Fenders (66-77)
  98. 33x12.5x15 spare tire
  99. need some zj parts (added more parts)
  100. need axle, springs, misc. for '95 Ranger (parting out, nevermid)
  101. scout dana 44 Stub shafts
  102. Plastic Shield 1999 Wrangler TJ
  103. Jeep 2.5 or 4.0
  104. WTB willys body or complete jeep.
  105. 4.5 inch lift for a xj
  106. Blazer/Jimmy Spindles
  107. WTB Dana 300 Transfercase
  108. Wtb front axle 06 dodge dakota
  109. 9.50R16.5 tires
  110. Need pitman arm
  111. WTB Black TJ Stock Floor Mats, 2-3 inch budget lift and newer 31x10.5R15 tires
  112. WTB dana 44 driverside drop for a yj jeep wrangler conversion
  113. wtb 35x12.5xr15 Trxus MT
  114. newer (99+) tracker 4 door coil springs
  115. Does anybody have a tj besttop supertop frame for sale
  116. Cheap 8 lug wheels and tires
  117. 88-98 Chevy Full Size Doors
  118. tires 235 75/70 r 15
  119. early 90s f-series diesel harness and computer
  120. ranger tail gate
  121. tj upper half doors
  122. need trans for 97 dakota 4x4 auto
  123. trade 86 TPI intake for 12' boat and trailer
  124. XJ parts wanted Downriver
  125. 1.9 TDI VW Diesel complete car or engine
  126. 15x10 8 lug rims
  127. list of 1999-2006 chevy parts
  128. Yj/tj wanted
  129. yj family style cage
  130. WTB: OEM radio with aux input
  131. shackles
  132. WTB 6 ft Chevy Short Box
  133. (2) 15" tires or (2) 13"-14" 6 lug Wheels
  134. 81-87 body parts
  135. wanted 2002 Chevy Driver Seat
  136. Decent K5 or Bronco 73-86
  137. NEED dana 35
  138. 265-75-16 or 285 75 16
  139. Sterling parts, and cheap 3/4 chevy front caliper cores.
  140. OEM CB Radio
  141. 2.5 ton gmc transfer case
  142. LJ Rear Driveshaft (non-Rubicon)
  143. WTB your unused JK Spare
  144. Wtb: Cherokee
  145. Ford 77~79 F150 SuperCab pass sd flat top Knuckle...
  146. wtb TJ flat fenders
  147. Wtt harley heritage softail
  148. feeler wtt 14 bolt lsd for open carrier
  149. WTB Factory Fog Lights for 97 - 01 Cherokee
  150. zj (4.0)exhuast manifold (in good shape not cracked)
  151. WTB: XJ Transfer case and AW4 torque converter
  152. Wanted Tow Strap
  153. WTB Project CJ
  154. ford 5x5.5 rims for 95 f150 2wd
  155. A/C hoses for 97 XJ 4.0
  156. XJ lift coils 6.5"-8.5"
  157. Superduty front axle
  158. f-350 vacuume reservior
  159. jeep tj stock front fender flares
  160. wtb/ wtt d44 ford for chevy 10b stubs
  161. WTB Scrambler or 66-77 Bronco
  162. Trade: Ford 8.8 LS carrier for an open carrier
  163. sbf automatic trans for mock up
  164. 5 on 5.5 rollers
  165. GM 12 bolt truck carrier
  166. Xj Bumper
  167. Need TJ hood, in white, drivers side fender, upper control arms for a lift
  168. Early Bronco tie rods
  169. ford dana 44 and chevy lift springs sas chevy.
  170. XJ Receiver 2"
  171. Wanted: Large Cable spool
  172. WTB/WTT YJ hardtop passenger side window.
  173. WTB 31x10.5X15
  174. WTB (1) 35" tire for a spare
  175. 94 f-350 8' bed and tail gate
  176. WTT 38.5" Four Wheel RVT for good 36"
  177. cheap to free chevy 6 lug rollers
  178. junk hp30 gear seat and carrier.
  179. 10 hp or larger 3 phase motor wanted.
  180. Wanted: Helping Hand
  181. need a tow bar for a m1008
  182. looking for GM nv4500 4wd
  183. '96-'99 Chevy Truck Bucket Seats - Grey Cloth
  184. FJ60-62 front axle complete
  185. Wanted good rear springs for cj7 stock
  186. Bell housing for TJ, 4.0 with NV3550
  187. 17 x 10....8 lug rims.
  188. Used Chevy or GMC truck
  189. looking for a cheap jeep!
  190. stock ford underhood jack
  191. Set of 36x12.50x15 TSL radials
  192. XJ Parts
  193. YJ ECU/Computer 94 4.0L 5 Speed
  194. 16x10 8 lug Wheels
  195. fullsize ford leafs or leaf pack
  196. Wanted 1999 to 2001 z71 silverado 1500 rolling chassis
  197. 96 F150 Parts Needed
  198. Wanted cj7 Frame
  199. 1354M Transfercase
  200. ford springs.
  201. cheap truck
  202. trade my 2000 Buick Park Ave Ultra for a cherokee
  203. WTB: snorkel
  204. Waggy Trim
  205. Dana 44 and chrysler 9.25 gears
  206. XJ Transmission
  207. YJ top
  208. ford 203 t-case
  209. welder/someone to weld something
  210. Looking for cheap xj cat back or bolt in test pipe and hella light
  211. super swamper iroc
  212. Black CJ-5 Soft doors wanted
  213. 1987 Nissan Pathfinder 4 cyl engine
  214. Want Miller Mig Welder
  215. Jeep Wrangler Snow plow or plow truck
  216. 3/16" hot or cold rolled
  217. WTB 33x12.5x15 BFG M/T
  218. D30 Axle Shafts 00 Tj **NOT NEEDED ANYMORE**
  219. WTB Wrangler - $3k budget
  220. Cheap Golf cart
  221. wtb yj jeep tail gate
  222. WTB 6 lug Chevy/Toyota 15x8 rims
  223. 97-01 XJ Cruise control module
  224. 235/75/15's kind of agressive
  225. TJ front side marker light
  226. 15x10 Wheels needed
  227. 15x8 wheels needed too!
  228. i need some control arm bushings for my jeep
  229. a good source for stainless steel bolts
  230. JEEP YJ Wrangler 4" or 6" Leaf Spring Lift
  231. 17" GM Fullsize 6 lug wheels
  232. 02 Superduty Leveling Kit
  233. 76-79 CJ Caliper Brackets
  234. fan shroud for my bronco
  235. TJ Driver side Fender
  236. Stock lug nuts for 99-02 F250
  237. Seatbelt Buckle 95-2000 Old Body Style
  238. WTB: TJ/YJ/XJ w/4.0L and 5spd
  239. wanted 134 f head
  240. Ford 8.8 Full width
  241. Hella 500's and Horns
  242. 35" or 36" mud tires
  243. cheap car or truck
  244. scout 2 dana 44 front axle or axle shafts
  245. Dodge 360 Flex Plate needed tody!
  246. WTB 97 4.0 Jeep Oil Pan
  247. Chevy Chevette Parts
  248. tires and wheels fs/ft
  249. wtb gooseneck
  250. wanted: 4.56 or 4.88 gears for my yj.
