  1. Looking for Wide Track Axles CJ7
  2. 33-35" ?? r15 tires, trade for my 37"
  3. Explorer 8.8 disc brake
  4. WTB: 4x4 4L60E for 96 chevy Pickup
  5. looking for a divorce transfer case
  6. looking for a deal on some tires 265 or 275 on 17"s
  7. Wanted ***YJ front bumper***
  8. Yj half door latch assembly
  9. chevy 8 lug dana 44
  10. Wanted: Junk Soft Top or Bikini Top
  11. need driver/truck/trailer
  12. Quadra Trac Wanted
  13. yj armor
  14. Looking for a CJ5 Tub
  15. WTB 32 x 11.5 x 15's 1-2-4 what u got?
  16. 1991 yj drip guards
  17. XJ Double Cardan Driveshaft **No longer needed**
  18. Looking for XJ Bushwackers
  19. Running Jeep 2.5 4 banger (4 cylinder)
  20. 97 tj rim
  21. TPS for RENIX Cherokee
  22. car dolly
  23. YJ D35 4.10 ring and pinion set
  24. looking for some 33x12.5x15 tires
  25. Someone to cut my fenders
  26. 15x10; 5x5.5 Aluminum rims
  27. *WANTED* 4.56 gear set for GM 14 Bolt 10.5 ring gear
  28. WTB: Manual Door 97-01 XJ parts
  29. looking for a plow for a cj7
  30. 89-91 Chevy truck/van with tbi350 (running or not) for efi conversion
  31. Lift Blocks and Add a leafs
  32. Screw in tree steps
  33. TJ heater fan knob, hood catch
  34. WTB chevy front dana44 8lug
  35. 30 9.5 15 tires
  36. steel 15 inch xj wheels
  37. XJ Radiator
  38. short 32 spline np205 input shaft
  39. 1500 for your ext cab ford
  40. WTB flex plate 4 Geo Tracker
  41. cpu 95yj 2.5L
  42. Early Bronco windshield frame and window if poss.
  43. Wtb lt1
  44. looking for med to heavy truck tires
  45. 4:56 gears for a dana 60 rear
  46. steering column for a 89 YJ
  47. 15 inch rims
  48. swamper STS
  49. tire groover
  50. trade np205 for np 205
  51. 9/16 lug nuts
  52. sbc to ax15
  53. fx50 or bronco ecm
  54. Cherokee 3" Lift Coils
  55. 6" and 8" front springs 73-87 chevy
  56. Wanted:mud tires
  57. XJ Doors
  58. Dodge Lift Springs
  59. High pinion Dana 30
  60. Radiator for s10 2.8
  61. Bondo
  62. Trade Custom machining,anodizing,hardcoating,polishing etc for xj parts
  63. U joint strap bolt for D30
  64. Mud tires 38.5" or bigger for 15 inch rims
  65. 1
  66. WTB-SYE kit and CV driveshaft
  67. wanted: Verizon phone - ENV3 or ENV Touch
  68. 33 12.50 15 mud king xt
  69. Trade yj soft top for cj7 top
  70. Wagoneer/ Full Size Cherokee Front Springs
  71. Need a set of 35's
  72. 235 75 15 tires
  73. XJ Project
  74. looking for a big block chevy
  75. wanted - Free or cheap house windows
  76. WTB 4 barrel intake & carb
  77. '02-'06 TJ 4.0L engine accessory brackets
  78. Wanted - 4 bald tires
  79. Bronco/Blazer/Ramcharger Roll Bar
  80. CJ wiper control knob
  81. Trade 35x13.50x15 bfg krawlers for 36-37"
  82. flat top knuckles
  83. 31-33'' 2000 jeep wrangler tires and rims
  84. 325-60-15 BF Goodrich or close to size
  85. 285 75 16's also 3rd gen 4runner suspension
  86. need some cheap rims
  87. d30 locker for 410 gears
  88. In need of Muddin TIRES !!!
  89. looking for auto trans for 85 cj7
  90. wtb 35s
  91. help straightening a Rusty's steering tie rod
  92. need 8.8 with 3.73 ratio out of '98 explorer
  93. WTB: Jeep
  94. Dana 30 axle shaft nuts & washers
  95. Needed 14.5x15 swamper TSL
  96. wtb 5 on 4.5 x10x15 wheels YJ
  97. Cheap Mud Tires
  98. TJ Soft Top
  99. 73-79 F-series 8ft bed.
  100. also need tj soft top.
  101. WTB 32x11.5 bfg AT and/or 15x8 soft 8
  102. wanted NP 243 3/4 ton
  103. tj front d30, 3.07----front fenders too!
  104. Wanted TH400 (GM)
  105. '97-'04 Dakota Leafs
  106. Stock lower control arms TJ/XJ
  107. wanted: 80-86 front bumper for a ford truck
  108. dana 35
  109. boat trailer for 14ft boat
  110. An engine!
  111. shock mounting hardware
  112. wanted - DD
  113. Looking for 4x4 vehicle
  114. wtb rims and tires for a s10
  115. np231 mainshaft or whole tcase
  116. WTB Bestop Sunrider for '89 YJ
  117. 98 zj v-8 trans
  118. Th400 style np205
  119. 10 spline dana 44 lockright
  120. 225/60R16 tires
  121. Driver's side fender 56 chevy p/u
  122. 85 cj 2.5 inch lift springs
  123. wanted: stock air filter box for 88 F250 460
  124. * wanted chevy 8 lug rollers *
  125. 8.8 w/3.73 gears for '95 Ranger
  126. Chevy or Gmc Truck
  127. I need 195x75x15 tires in good shape
  128. need a pair of 225 50 r16
  129. 6ft bed needed
  130. Wanted: YJ Seats
  131. yj hard top & doors & bikini top
  132. Need YJ Steering Shaft
  133. 8 lug wheel (17") + 40" - 44" tire for spare
  134. locker
  135. 55 gallon plastic barrels
  136. Wanted: 6 lug wheel with tire for trailer spare
  137. stock airbox for 91 yj
  138. WANTED: Terra Tires!!
  139. full width d44
  140. 265/75/16
  141. need a transmisson for my 87 k5 blazer
  142. Dodge/Chevy Dana 60
  143. Diverter valve ?
  144. chevy lift kit
  145. 2 inch lift blocks
  146. 55 Gallon drums - Muskegon area
  147. Wanted Jeep TJ or LJ frame
  148. looking for a reasonably priced outboard.
  149. iPod touch
  150. Front marker lts for 94 2wd Yota P'up
  151. pinion yoke for tj wrangler
  152. stock radio 95 zj
  153. 32-11.50 spare??
  154. Looking to buy.
  155. Wtt 15x8 5x4.5 with 265/75 tires
  156. looking for the back seat for a 95 chevy k2500 extended cab
  157. Vent tube for a NP208/219/228/229AM
  158. fox body mustang rear hatch near muskegon
  159. random stuff and ford/bronco
  160. close... bought one....I want to buy a motorcycle...
  161. looking for stolden ford truck
  162. ext cab or quad cab truck
  163. knobs 4 TJ soft top
  164. Looking for 3/4tn 10bolt fr-ax and 8lug wheel spacers
  165. Ranger wheel
  166. WTT. Long arm xj on 36's for tj.
  167. 97-01 XJ w/ chry. 8.25 rear drive shaft
  168. wtt 33" tsl's
  169. 2 tires for a yamaha warrior
  170. stolden ford truck
  171. seat belts and seat covers cj high back blk
  172. 1972 gmc jimmy project
  173. stock s-10 rims...5 on 4.75
  174. Need soft top and doors for cj7.
  175. Dodge Ram Mirrors
  176. geo tracker
  177. wtb rear fender flairs
  178. Grand Cherokee alternator
  179. tires wanted 235/70/16 - 265/75/16.
  180. YJ Shocks
  181. 2.5 for a yj
  182. Dana 60 Carrier
  183. Dodge Parts
  184. in need of ford truck parts
  185. 4 Lenghts of 1.5 .250 wall DOM
  186. WTB: 6in ford ranger TTB lift coils
  187. WTB 42-re zj trans
  188. BOGGER TIRES NEEDED...trades only
  189. Ford 5.4L engine
  190. yj front drive shaft 2.5/ax-5
  191. seat for a chevy
  192. 33s for a 15 inch rim
  193. Need a 14' boat trailer
  194. '79 Bronco
  195. 78 - 79 ford f 150 9 in lift coils
  196. Samurai Parts
  197. dana 30
  198. 2001 jeep tj soft top
  199. WJ - Tail Light - Drivers Side
  200. 88-98 Chevy fender flairs wanted
  201. j10 parts to convert to manual
  202. Recumbent Bicycle
  203. Radiator for CJ with V8
  204. i need a 302 or 351 efi please
  205. 99 wrangler radiator
  206. 1997 4l60e
  207. Case spreader to borrow, or spec sheet so I can make my own
  208. XJ axles / steering / wheels & tires 31,32 or 33's .....
  209. WTB '99 Cherokee Hatch
  210. Pathfinder/D21/Hardbody Doors
  211. Jeep Winsheild frame and good glass 87-95
  212. WTB: Silver grand cherokee laredo rear hatch
  213. 4wd 700r4
  214. need CJ hood
  215. WTB: SBF C6 lower dust shield
  216. Yamaha golfcart engine
  217. super swampers
  218. Trade for car
  219. WTB 33" MT's with wheels, TJ lift, offroad lights
  220. grill and hood for tj
  221. Wanted:Dana 60 short side shaft for chevy
  222. Scout dana 44 stubs
  223. Ford 351m Zoomies - Upright Headers
  224. 3 LH johnny joints
  225. E-range, 16" AT or MT tires - 32"-33" dia.
  226. wtb front springs 1995 f150 4x4
  227. Trade my 33's for 35's
  228. Wanted- trade chevy truck for jeep
  229. D30 for 96 cherokee
  230. wanted f-150 rims
  231. Amc 360 and possible tf999
  232. carb
  233. rear window hinges
  234. Need ONE 15X10 Aluminum Wheel
  235. tj hood and fenders
  236. Freezer
  237. wtb wagoneer pitman arm
  238. WTB: JK Wrangler rubicon unlimited, automatic.
  239. chevy truck rollers
  240. 2001 Grand Cherokee Laredo Rear Bumper cover
  241. Need a unibody frame straightened
  242. "6x25" Structural I-beam
  243. XJ Stuff! (stock leaf springs, lift parts, etc.)
  244. 95 ish 8.8 explorer rear end 4:10 gears or
  245. WTB Ford Wheels
  246. 1 single BFG 35x12.5x15 All terrain 40% or LESS tread left
  247. 5 point harnesses
  248. Need xj stuff!!!
  249. I need 1 BFG KM2
  250. need xj rear end
