Wanted [Archive] - Page 82 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. WANTED ( 2 ) 35x15.5x15 TSL sx
  2. old tires / wheels
  3. wanted: bowfishing setup
  4. 84/85 toyota solid front axle wanted
  5. 14 bolt full float axle 10.5rg near Fort Wayne, IN
  6. t case
  7. Upper slider windows for 94 YJ in spice
  8. Wantedd dodge ram drivers door
  9. Toyota solid front axle
  10. dana 44 spring plates
  11. drivers side rearview mirror and seatbelt
  12. Bucket seats
  13. Wanted TJ
  14. trade my truck for motorcycle
  15. Dana 30 stub shaft for 297 joint
  16. TJ Fan and clutch ASAP
  17. 10 in wide x 16in rim with chevy 6 lug
  18. Diesel Truck
  19. Wanted: rear seat mounting hardware and seatbelts for 1998n Wrangler TJ
  20. cheap TJ 3.07 axles, front lower control arms (stock) and stock track bars
  21. WTB: 5.9L Magnum for 96 Ram 1500
  22. 4 tires 36" or 37"
  23. Xj Licsense plate bracket
  24. tube bumper or solid rock bumper
  25. Dana 60/14 bolt spindle lock washer
  26. YJ rear bumper with tire carrier
  27. Wanted:Someone to help me rebuild a Auto Transmission
  28. ford ranger- bronco 2 Hubs
  29. gravel for my driveway
  30. wtt truck stuff
  31. 2door L side rear vent window/collum
  32. locker or mini locker
  33. WTB 15x12 chevy 6 lug aluminum wheels
  34. Free camper or boat
  35. Wanted 16.5 rims 5 on 5.5 pattern
  36. WJ hitch
  37. Jeep TJ front and rear bumpers
  38. WTT big tank argon/co2 for smaller one
  39. Locker for a d35
  40. dana44 high pinion locker or carrier
  41. YJ leaf springs
  42. a 3inch body lift for a 78 ford bronco
  43. locker for a d44
  44. small argon cylinder
  45. need 42's or bigger
  46. Ford 9" housing
  47. 2000 cherokee gas tank
  48. Dana 30 Knuckle
  49. 94 Toyota IFS front axle
  50. WTB: 4.0 Exhaust manifold
  51. cj fenders. asap
  52. yj 32rh
  53. Wanted: 4.7l Motor for 99 Grand Cherokee
  54. Nitto mud grapplers trade
  55. wtb cheap 73-87 chevy
  56. 99 tj parts
  57. xj winch bumper, used winch
  58. tracker computer
  59. 4.0 block
  60. 80ish D30 spring plates
  61. wanted Quad
  62. Dana 35 TTB
  63. cj parts wanted
  64. WTT Incredibly clean 1998 5.9L Jeep Grand Cherokee Limited for trade
  65. 10 Bolt Rear with 3.73
  66. TJ - AW4 swap parts
  67. 1995 s10 interior door panels crank window
  68. Tie Rod Assembly/Drag Link for '86 CJ7
  69. 5 on 4.5 16 inch wheels for tj
  70. looking for 5x4.5 16" wheels
  71. 4.0L Jeep Cylinder Head
  72. wheels chevy 3500
  73. 20ga home defense shotgun
  74. Looking for some tires/rims 33's
  75. Wtb- 38.5x15x16.5 ss
  76. stump grinding
  77. 99-04 Grand Cherokee power steering box
  78. Looking for pug
  79. Derby car
  80. 97 tj radio
  81. nice set of wheels and tires for a 05 Ram
  82. c-6 trans shifter bracket
  83. 1 chevy ss rim
  84. 255/70/16 A/T Tires (new)
  85. WTB BCM Lower Receiver + AR Parts
  86. 8 lug wheel spacers
  87. 350 Vortec engine or short block.
  88. np 205
  89. one stock Cj spring
  90. 97 Grand Cherokee lift kit
  91. --->NEW 305/70/R18 tires
  92. 20'' 8 lug rims
  93. 34x9.50x15 boggers or similiar
  94. Wtb- 38.5x15x16.5 ss
  95. Fuel Door for on XJ
  96. fam style rollbar ?
  97. 80's ford dana 60 spindle
  98. Need 3/4 ton Chevy axles or bigger
  99. 30 spline 60 lock outs
  100. xj control arms
  101. Fender TJ Wrangler Driverside ????
  102. Dodge leveling kit, spring spacers
  103. 258 valve cover-1980 and older
  104. Wanted: 15x12 aluminum wheels - 6x5.5 bolt pattern
  105. Injector pump for 24 valve cummins just need a core
  106. 37x12.5-17 BFG AT
  107. WTB: Rubicon coil springs from 03-06
  108. Yj Frame
  109. WTT Dana 300 Short Tailshaft for Dana 300 Long Tailshaft
  110. Yj power steering box
  111. 30-06 rifle
  112. dana 35 spider gears
  113. Inner door handles
  114. cobra 25 classic
  115. YJ Family Style Roll Cage
  116. chevy truck seat
  117. wanted blackberry 8330 $50
  118. 12v battery indicator
  119. 700r4 2WD
  120. chevy dana 60/14 bolt combo
  121. Ranger 6"or 8" lift coils
  122. cj7 soft top
  123. 14 bolt 5.13s
  124. i need Diamond Plate
  125. semi trailers - - or box trucks needed for car parts storage.
  126. vortex 4.3
  127. Need anouther 208 case back half or case
  128. Wanted Pro Comp Mud terrain 33
  129. wtb Ford steel wheels 5x5.5
  130. Chrysler 8.25 yoke
  131. 91 Geo Tracker ECM
  132. T-18 Tranny
  133. WTB 2 35s for a 16 inch rim
  134. wtb 91-03 escort w/o abs
  135. D35 yoke for 93 grand cherokee with v8
  136. AMC 20 Lock-Right or similar type locker
  137. Old Bronco 9 inch setup for jeep yj
  138. 86 ford ranger parts
  139. TJ Black Soft Doors
  140. looking for a motorhome 25'-35 ft. - $5000
  141. cj/yj seats and drivers side riser
  142. WTB Steel wheels 15x10,5-4.5
  143. WTB Old Pick up Project 1972 or older
  144. Looking for a TJ under $7,000
  145. wanted front drive shaft for Jeep Wrangler
  146. WTB K5 blazer or Suburban(have trans am to trade)
  147. Car Hauler Wanted
  148. Wanted: YJ stuff
  149. AW4 - 4.0L Starter locater plate
  150. 8 Groove cummins pully
  151. Any 4.8 5.3 6.0 engine wanted. CHEAP
  152. Belly skid for 95 YJ
  153. bumper
  154. Off Road Saftey Flags
  155. XJ Steering Shaft
  156. jeep 4.0 engine
  157. 4.3L chevy engine
  158. Dodge Ram Door Latches
  159. Want a Jeep
  160. CJ parts wanted
  161. 44 shaft needed
  162. wanted 33in tires
  163. Wtb amc 2.5l
  164. wtb: 15x8 rims 5 on 4.5
  165. WTB 8'-12' ft pine trees ...near lapeer ?
  166. electric carb for a 304
  167. WTB Core 350
  168. 245/75/16 Tires for a grand
  169. TJ Rubicon Rims and or tires
  170. AMC V-8 CJ-5 Stock Air Cleaner
  171. wanted cheap chevy 350
  172. air shocks or coil overs
  173. Bronco II Lift
  174. AX-15 Wanted
  175. Harley Davidson FXDL Gas tank !!!
  176. Bogger
  177. Parts or parts truck for 1997 F150
  178. WTB Car $3,500 Budget
  179. chevy 1/2 ton 6 bolt shafts
  180. 79 CJ5 Parts
  181. WTB YJ Tub
  182. hubs
  183. WTB 31-32" mud tires and lift
  184. RE 4.5 coils for XJ wanted
  185. Lift for grand cherokee
  186. XJ lift
  187. Tires
  188. home or fostor care for pitty mix.
  189. 16.5 rims
  190. Trade New 4.5" YJ lift springs for 1.5" or 2"
  191. WTT Spice soft top for Black soft top
  192. 31-10.5-15's or 32-11.5-15's
  193. fan shroud for 99 xj
  194. Need Stock YJ springs for a Samurai project at Great Lakes Truck Outfitters
  195. i need a transmission for 1997 ford f150 5.4
  196. Steering Box 78 CJ5
  197. Cut40 Plasma Consumables
  198. toyota axles
  199. ZJ Front bumper
  200. 37's on 5x4.5 wheels
  201. BFG Mud Terrain 35x12.50R15 Need 1 Bad
  202. Final 4 tickets
  203. Stock Wheels for 2000 Z71
  204. 1
  205. Flowmaster or somthing close to it.
  206. WTB XJ Parts...
  207. fencing installed
  208. WANTED d 44 moly 30 spline axle kit
  209. free rollers for YJ
  210. Ford Super Duty Rim w/Tire
  211. 99-04 superduty lift.....traditions pursuit ML
  212. sponsor and or parts
  213. tj wiper arms and heat vents
  214. winch cash in hand
  215. WTB Rear bench seat (no longer needed)
  216. Jeep 4.2L Carb
  217. TOYOTA 22RE engine
  218. Locker for a dana 60
  219. Ford explorer Snorkel Wanted
  220. 1 16x8 6 on 5.5 wheel
  221. 9" ford posi
  222. cherokee springs
  223. 4 barrel aluminum intake for ford 390 FE
  224. wtb: xj/tj stock aluminum wheels, have black cragar 15x8 d windows to trade
  225. Wtb XJ Control Arm Drops, D30 locker
  226. WTB (2) 44" Tires
  227. 2" ZJ tow hitch.
  228. K5 tin
  229. 78-79 F250 Dana 44 Hi Pinion
  230. gaining interest for 231/231 set up/ AX-15
  231. trade my YJ soft top for CJ7 top
  232. vw parts
  233. 38/ 15.50/ 16.5 radials
  234. borrow/rent car trailer
  235. Dana 60 Rotor Hub
  236. 89 Cherokee Manual Trans
  237. Need wheels!!!!
  238. yj glass..cj fenders asap!
  239. ford 302 intake
  240. Power Washer
  241. looking for a Factory soft top for tj
  242. Passenger side yj fender
  243. trans
  244. YOUR 35s A/Ts*******FOR MY 35s M/T
  245. trade for 38 or 39 inch super swampers
  246. D50 TTB 3.55:1 gears - in good shape
  247. Sand/media blast cabinet
  248. TJ front axle
  249. Champion 8000 lb winch motor
  250. samurai transfercases
