Wanted [Archive] - Page 80 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. XJ lift kit
  2. WTB - Jeep TJ Automatic Shifter
  3. Jeep TJ Rear Coil Spring Isolator
  4. 01 tj. header?
  5. cheap DD car, $1200-$1500
  6. WTB Rims
  7. ax 15 trans
  8. Rear bumper for cj rock crawler style not tube
  9. ford ranger 2wd rear drive shaft
  10. 36x12.5 x 15 5 on 4.5
  11. mig welder
  12. Looking for rear lift glass for ZJ
  13. Someone to pick up scrap...
  14. s10 bushwacker cut out flares
  15. 40+ tires.
  16. Air horns truck/train
  17. 35x12.5/15 spare tire
  18. RE 1444's
  19. Needed DANA 30 3.73 from 96-98 ZJ
  20. cj7 auto-trans
  21. s-10 blazer lift
  22. Dana 44 & Chrysler 9.25 Gears
  23. Front Drive shaft 04' TJ Rubicon
  24. Ps3
  25. 39.5 iroks
  26. 15X8 TJ Canyon Rim
  27. Dana 44 High Pinion and 14 Bolt Gears
  28. 80-86 f150 or f250 parts
  29. WANTED: Looking for a TJ
  30. Wanted: 38" - 42" spare on 8 lug.
  31. 1979 Ford F150 reese hitch
  32. Glock 22 or 23 wanted. *gun purchased*
  33. Jeep xj- front driveshaft!
  34. T18
  35. wanted 6000lb + working winch
  36. Wanted: 93-97 Ford Ranger Parts
  37. 35x12.5x15 Mickey Thompson Baja Claw Bias Ply
  38. Waggy Dana 44
  39. suzuki or kawasaki z400 quad
  40. $2000 in hand, looking for a dd jeep or truck!
  41. Toyota 8" & 7.5" 5.71 's
  42. Lookin for a 2.5 4 banger
  43. meyers plow bracket for xj
  44. 3-4'' ZJ lift shocks
  45. Tilt steering column for cj7
  46. 1 BF Goodrich A/T Tire 31/ 10.5/ 15
  47. drive shaft with 1350 joints
  48. 35 inch tires for 16 or 17 inch wheel
  49. Rear Seat for a CJ5 - No longer need one.
  50. old cheap field bomber sled
  51. Good 81-86 CJ7 or YJ Frame
  52. 4L60-E for 2002 Suburban 5.3l
  53. WTB Streetable Tires for 94 ZJ & Drivers Door
  54. Your old 9" gears (3.55 or worse)
  55. chevy truck w/olds 350 diesel parts
  56. looking for boggers
  57. Cheep 3'' body lift
  58. cross rails
  59. Lease-end Minivan (American only) *NO LONGER NEEDED*
  60. Ruger 10/22
  61. amc 727 now
  62. Chevy D44 shaft
  63. cheap / free 8 lug rollers
  64. 4.7 for a 1999 Grand Cherokee
  65. jeep I6 4.2l Intake manifold
  66. WTB Locker for D30
  67. WTB 4" or 4.5" RE Springs
  68. dana 30 short side axle shaft
  69. wanted jeep cherokee
  70. 10/14 bolt lockers
  71. lookin for a pair of quads for a good price
  72. wanted 33Inch tires
  73. 3/4 ton chevy axles and 36 or 37 inch tires
  74. xj parts
  75. XJ Front drive shaft
  76. wanted ltb
  77. YJ Skidplate/crossmember
  78. 83 yota front drive shaft needed
  79. york v belt pulley
  80. Hitch for TJ
  81. want zr2
  82. W.t.b lift and 35/12.50/16 for 2001 dodge ram 3500
  83. Wanted: roll pan, 8 ft tonneau, clear corners, cowl hood....
  84. D30 3.73+ up carrier
  85. Timing cover for 2000 4.0L
  86. CLOSE wtb: ext cab 4x4 mini... 2500 CLOSE
  87. WTB disconects for tj
  88. WTB cut out flares for 80-86 F-150/Bronco
  89. 1965ish chevy 4x4
  90. Big Block Chevy Intake
  91. no longer needed* 8.8 rear axle* cash in hand!*
  92. WTB Dodge engine
  93. LOCKER for a rear dana 60
  94. 40's and up tires
  95. 2006 dodge megacab fender flares
  96. 3 window slider 1998 chevy.
  97. WTT NV-3550 for a automatic
  98. 2000 TJ heater control wire
  99. 79 f250 trim
  100. 33 or 35's with rim's
  101. wtb 14ff or 60ff
  102. Suspension parts
  103. meyer plow blade
  104. belt tensoner for 95 yj
  105. WTB Ford Dana 60
  106. Looking for Lift leaf springs
  107. WTB Chevy 6 lug rollers
  108. wtb dana 44
  109. FS: 2002 YZ 125. Need Dodge parts
  110. 41-42 inch drive shaft
  111. Tires for winter
  112. wtb--98 xj snorkel (new or used)
  113. dana 44 spiders
  114. Chop Saw, welding clamps, angle finder...
  115. Need 36" to 38" tires
  116. sunfire gt
  117. 4 in front leafs for 96 F-350
  118. Cheap project
  119. RE 1.5" SOA Leaf Spring
  120. xj kickdown cable
  121. slider windows
  122. wanted: 33/12.5/r15
  123. Wtb ford ttb parts (stock)
  124. small truck or car
  125. D30 3.73 or bigger carrier
  126. looking for tires ??????????????????
  127. wonted 8 lug front axle chevy truck look
  128. Laptop
  129. 350, 400 or 327 SBC.
  130. XJ Rear Bumper 1998
  131. viser for my ranger....
  132. Ruger 10/22
  133. TJ Front Bumper Rubbers + Rear Seatbelts
  134. brake lines, for lifted vehicle etc....
  135. wanted! ford hp d44
  136. WTB Silver 1 oz Coins
  137. Body lift
  138. wtb pickup, ext cab, 4wd
  139. wtb 36"-38.5" tires
  140. need 8.8 diff cover
  141. 91 to 99 HP Dana 30 from XJ
  142. D30 yj wheel stub shaft
  143. Good cheap trans rebuild th350
  144. Lt1 v8
  145. Wanted front drive shaft
  146. WTB adjustable control arms
  147. Front D44 Spindle Nut's and Lock washers
  148. Need inner shaft for passenger side YJ D30
  149. HPd30 4.88 ring and pinion
  150. yj front fenders
  151. double ended steering ram
  152. 258 fuel injection
  153. four barrel intake for amc 360
  154. 8lug dodge center caps
  155. 231 transfer case
  156. Trade??? 03 VW Jetta Turbo
  157. want 4 tj rear flares
  158. 77 ford f150 housing
  159. WTB 4 door 4x4 truck 96+ chevy full size
  160. cj 5 parts
  161. dana 44
  162. WTB: SBC Conversion Kit for XJ
  163. 2 35" x 12.5 x 15 any conditon and under $50 ?
  164. GMC Sonoma/Jimmy headlight assembly passanger side.
  165. front prop shaft for 04 grand cherokee
  166. gm dana 44 3/4 ton spindle and nuts
  167. steering gear box
  168. cut out flares 92 gmc truck
  169. chevy flat top
  170. drive shaft's
  171. AMC Intake
  172. xj mj 8 inch front coils
  173. WTB D44 Flat-Top Knuckles
  174. 650sx
  175. Wheel and Tire Trade
  176. 48" or bigger snowblower that was gave away last year?
  177. Popup Tent Trailer Camper Pop Up - Wanted
  178. Dishwasher *Wanted*
  179. Looking for XJ 3"-4.5" lift w/rear leafs
  180. toyota axles &lockers
  181. WANTED! is there anyone that has a BFG 35/12.50 /16.5
  182. Looking and Encoder Motor For 99 Blazer
  183. suckYJunk Needs Parts for a YJ
  184. 265/75/16 tire
  185. 36 14.50 r15 i need some tires
  186. WTB: SYE for '98 XJ
  187. 8.8 stud girdle
  188. 97-2000 xj parts
  189. cheap 15X8 or wider, 5 on 4.5?
  190. lund visor, or whatever you have
  191. TJ door and window hinges in dark blue metallic
  192. Dana 60, Passenger drop.... And rear?
  193. 92-96 Ford Parts needed
  194. Looking for TJ driver side front fender
  195. Looking for tj drivers side front fender lamps
  196. xj mj trac bar
  197. Need good front an rear TJ control arms Adjustable preferred Never mind went new
  198. Looking for free Kitten
  199. I need a nextel phone asap.
  200. looking for a $5000-ish commuter car
  201. Wanted Dana 44 Spool or Dana 30 Locker
  202. 4x4 Ranger rear driveshaft
  203. gone
  204. race motor
  205. xj lift springs
  206. Wanted: YJ headlight bezels
  207. np 231 27 spline, 91 4.0 xj
  208. >=36" Tractor Rim
  209. NOT NEEDED chevy 10 bolt OPEN CARRIER
  210. cb for the jeep
  211. WTB:F-150 5.0 fuel rail
  212. wtb: Jeep w/ 4.0
  213. Toyota rims 15" or 16"
  214. Dana 30 297 u-joint axle shafts
  215. trade my 01 wrangler
  216. chevy 6.0 motor and atlas 3.8
  217. free or cheap 15" or 16"rim jeep
  218. 30/35 gear set
  219. wtb bw1354 man shift tcase
  220. wtb d35 ford gears and locker
  221. need a set of rims and tire for a tj
  222. 33x12.5x15/Jeep yj parts
  223. Need Daily Driver
  224. WTB: ford ttb lift coils, 4 or 6 inch
  225. wtb or trade
  226. Yj half door just need one door any side
  227. T-176 or T-5
  228. Im looking for some BFG All terrian TA 32x11.50R15 tires
  229. powder coating
  230. Need 89 XJ driver door glass (4 door)
  231. sand rail
  232. 32-34" tires
  233. Lower mounting bracket for 78cj steering column
  234. looking for 33x12.50x15
  235. 4.10 gears for dana 30 & 35
  236. q jet carb
  237. 4 stroke quad 350cc+
  238. WTB 32x11.50-15 tires
  239. wanted tires
  240. Agressive 35's
  241. looking for used lift kit
  242. wtb: 33 12.5 15
  243. 2000 cherokee class III hitch
  244. wtb bucket seats for...
  245. front tow hooks for a zj
  246. rear cv driveshaft for cj
  247. WTB: Project Wrangler or CJ
  248. Harley Davidson Dyna custom, FXDC gas tank 90-95
  249. need axles
  250. 37-44 tires
