- need a 350
- i need a lift kit 1992 ford ranger 4x4
- Looking for a quad
- dana 44 carrier
- chevy 3.73 gears, 10 bolt
- jeep cherokee
- cherokee leafs
- stock yj front bumper
- Class C Motorhome
- steel
- 1985ish Jeep CJ7 windshield and frame
- 19lb per hour injectors
- need a yj frame
- auto shifter
- Dana 44
- Rubicon stock springs needed
- 2001 4.7 motor
- need rollers
- Vortec 5.7 96 -99 truck
- WTT 84 k5 Blazer
- 4.0l items
- Wanted 3.5" or 4" TJ Coils and OME Shocks
- NEED D44 4.10 gears for a dodge front end!
- tj parts
- Fabtech Steering Box Skid Plate
- Mono block car amp wanted
- Rubicon locker Air Pump
- Golf cart or side by side.
- xj leaf springs
- queen storage bed.
- 2inch 1/8 wall dom tubing
- tj rear lift springs
- YJ door striker
- YJ V8 Conversion Radiator
- wtb truck or suv Under $1000
- Dj-5
- 31 thornbirds for 15in. rim
- axle shaft
- 16.5x14 8 lug
- WTB: AX-15 w/ matched NP231
- wtb: 32x12.5x15
- wanted: Free TJ Front Bumper 97 - 04 will do
- Differentials [the book]
- heater system for cj7 77 or later
- 285/75/16 Mud tire
- Zj front bumper cover
- trans. dipstick tube for 4L80E
- 35x16x15 boggers
- toolbox for small truck
- Need calipers for cores - or good 1/2T Chvy Calipers
- large lava rock pieces
- Dana 44 30 Spline Detrot Locker Wanted
- chevy fuel regulator spring
- sahara backseat
- WTD Bender
- Scrap
- 1980's Toyota Pickup 22re Ignitor/Ignition Control Module
- *NO LONGER NEEDED* TJ/XJ/YJ/MJ D35 or D44 rear axle
- Wtb front bumper light bar
- Cheap 16.5 tires 37" or bigger
- 73-87 gm truck steering box brace
- need casino monies
- 1979 hp Dana 60 caliper brackets
- dash,plastic instrument bezel, mirrors for 89ish xj
- np 231 for 94 cherokee
- need 8 lug 15in rims
- wagoneer pitman arm
- Turbo 350
- 01 dodge ram sport front bumper/cover
- looking for diesel K2500
- 9" and d44
- wtb: wrecked vehicles
- cj7 soft top
- Paddle tires
- S-10 drivers door
- Looking for nice ZJ with v8
- someone to plow
- Need 30x9.50 or 31x10.50 on 15in wheels
- 90ish mustang 5.0 headers
- 1998 Jeep Cherokee 4x4 tires (NEED 4)
- 8.8 Disk brake set up.
- WTB Boggers/Super Swampers
- wtb: 32 11.50 15
- Wtb: Ba-10/5
- 03 and up WJ knuckles and brakes
- want a jeeep
- 7/8" keyed shaft
- stock jeep XJ leaf spring
- looking for a job
- Paddle tires
- s-10 blazer or jimmy body
- Wanted or WTT 15x10 wheels for 15X8
- car transport
- 16 Alloy jeep rims
- Warn winch controller
- Used Roof Top Tent
- (2) 5 on 5.5 wheels with tires
- Wanted 1976 F250 longer pitman arm
- YJ Brake Master Cylinder
- wtt 4 swampers tsl bias ply 18.5x44 16.5
- wtb set of tires 31s and also 265-285 LT's
- need front bumper 95 chevy
- 1999 artic cat ZL drive shaft
- 35x1050 ssr's
- 36x12.50 Swamper SX's
- WANTED: Tachometer
- WTB rebuilt NP208 for TH400/SM465
- WTB Throtle cable bracket for sb350
- WTB: URGENT. Wheel Bearing D30 4WD
- wanted bronco buckets
- Cj7 dash and wiring harness
- want: ps3
- ?need a 85 ranger rear end got any???
- Fuel meter body assembly
- Tahoe/blazer/yukon
- HP Dana 44
- 8.8 solid diff cover
- Gooseneck Trailer
- s-10
- somebody that can lay linoleum
- open carrier
- I Need A Cheap Running Car Or Truck
- 315/75/16 Tires or tires and wheels
- verizon phone
- jk control arms
- Dodge 2wd 47RH trans (1994-95 ) ??
- WTB: OEM JK shocks and 31" tires
- Verizon cellphone!!
- Looking for a Jeep Wrangler
- Ford Windshield Wiper Motor
- 31x10.50 MT's and locker for a dana 35 zj
- Wanted 265/75R16 tires (2)
- 3/4 ton PU
- I need a rear D shaft for an LJ
- need front end liberty parts
- Dash for CJ or Scrambler
- xj rear hitch
- WTB tailgate & rims 89 4runner
- TJ or Clean YJ 5k-6k
- Toyota pickup
- CB antenna...
- Dana 44 limited slip or locker 3.92 up
- need 275 65 18 tires
- locker or??? for amc 20
- WTB 37 or 38 inch tires
- WTB HP dana 44
- 6 lugdriver drop
- wtb Rockwell air locker
- 2.5L inertia ring
- Antenna for 98XJ
- good running 360 longblock (la or magnum)
- IH scout
- 5x5.5 bolt pattern beadlocks
- land to shot skeet or trap......near port huron
- WTB: Cheap LCD With RCA In
- 95 dodge ram grill
- Soft jeep doors
- Excavator, Bulldozer or Backhoe service,land clearing
- Looking for ARB Bumper 88-98 Chevy New or Used
- Front seats for YJ.
- few feet of square tubing
- Trailer Hitch XJ
- iroks or boggers
- bfg m/t
- 33" 12.50x 15 BFGoodrich A/T
- WTB N/A Diesel truck
- Ford 9"
- 1 32x11.5x15 BFG M/T KM
- wtb d30 w/3.55s in working order for a 99 xj
- anyone have a couple crotch rockets for sale
- NP 242 Transfer case 1996 - 1998 Jeep Grand Cherokee
- tractor tires
- Wanted Ford 8.8
- WTB Durango Rear Hatch 2002 model
- WTB:dd wrangler
- looking for a truck and a few IQ points
- wtb sbc pullin headers/zoomies
- 3/4 Ton Dana 44 short-inner shaft
- 1" or so 5 on 5.5 Wheel Spacers**No longer needed**
- Builder/Contractor in N Oakland County
- 4 banger dd
- Wanted xj long arm kit
- Wanted Dodge Voltage Regulator
- tj axles 44/30
- 99-04 Grand Cherokee Rear Sway Bar Links
- Hydro Steering
- th350
- mountain bike shock
- 351w 5.8 headers
- wtb: tire changer
- 1997 to 2000 dodge ram ext cab
- SBC Roller Rockers
- 4l60e rebuildable core 98+
- Flowmaster 40 or 44 series
- 231 transfer case
- sbchev-cj headers
- front cage
- Dodge Ram Diesel
- 97+ Cherokee grille insert
- 88-98 chevy/gmc 1/2 ton leaf springs
- WTB Vortec 4200
- Winch Soleniod Pack
- Rear xj Dana 44 shafts
- Anyone have any 42-44s they want to get rid of
- XJ parts needed asap!
- 4wd C6
- 99 chevy silverador bumper
- F150 4x4 drive shaft, rear.
- pitbull
- TJ rolling chassis wanted
- 1997-01 XJ 2dr drivers seat!
- WTB: good used already geared Zuk T-case
- 1/2 ton axles with lock outs in the front
- looking for SYE 05 tj
- ZJ 93 231 tc
- Hitch for Explorer
- Wanted!!! Cheep 16" wheels for chevy truck 6 x 5.5"
- '92-'96 cherokee steering shaft
- 22re Distributor
- rear amc 20
- Looking for 4x4 chevy z-71 ext. cab
- windshield mounted light brackets for a TJ
- WTB YJ Full Hard Doors
- 2003-07 Superduty with blown/no engine
- Wanted Windshield frame and hard doors
- TJ D35 & D30 lockright or other lockers
- WTB: Old JP, Petersen's, or 4WDOR mags
- i need tires for decently cheap
- yj front fenders wanted
- NEED lift Shocks ASAP 1-4inch....
- wtb:39" spare
- Blasting cabinet - Bigger the better
- TJ Fenders and other body parts
- 275/60R20 Tires
- Ranger Brake parts
- Toyota windshield trim
- Seat belts 94 YJ
- wtb lombardini diesel parts
- Tj core support
- SBF Intake and Carb
- Ih pickup wheels
- xj or zj
- 2000 Chevy 1/2 ton P/u rear axle
- Need a bed for 79 scottsdale
- 4.3 Vortec
- Trade Brand New 3ft Wilson Cb antenna for Bigger..
- Steel Rims - 15" or 16" - 5x5.5"
- Cheep 31's
- Stock XJ leaf springs ....
- amc v8 aluminum valve covers
