Wanted [Archive] - Page 76 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. Jeep Tire cover
  2. Plasma Cutter
  3. WTB 35-37" tires
  4. used tow strap
  5. Xj door locks
  6. Upright Freezer
  7. Ford Leafs
  8. Need 37/20x13.50 Tire (1)
  9. WTB-jeep cherokee rear wiper motor!
  10. Gears for my zj
  11. Wtb Ram 2" Dually Spacers And 315 75 16 Tires
  12. Need a 44 front - passenger drop
  13. tonneau cover
  14. Wanted: Dana 44 Carrier
  15. Wanted: Mandrel Tube bender
  16. Jeep 2.5L motor
  17. 94-95 Dodge Dakota steering column.
  18. wheel spacers
  19. drop pitman arm 1994 Chevy c 1500
  20. who can make a good bumper? I want suggestions also
  21. WTB Rollbar Pads and Carpet
  22. WTB CHEVY TRUCK chaep!!!!
  23. dana 44 10 bolt
  24. Set of tires for 92 Chevy S10
  25. looking for 31x10.5x15 GOT TIRES THANKS
  26. Junk (ZJ) DANA 35
  27. wtb 78-79 hp 60
  28. 15x8ish wheels w/ 5x4.5 bp
  29. 99 tj transfer case
  30. Trade 91 s10 blazer lifted for full size chevy lift ang more...
  31. Willys Pickup!!!
  32. Windshield for a Honda
  33. Dana 60 High Steer Arm
  34. 13" Snow tires!
  35. Looking for decent set of 4 315/75R16 Tires
  36. 1999 Dodge Ram 2500 V-10- Trade for Silverado/Grand Cherokee
  37. video card
  38. broken water heater or 2
  39. Headers for a Bronco II (not needed anymore)
  40. 13" tire
  41. d44 hubs
  42. for sale 95 jeep cherokee $2000 for a fast sale
  43. YJ Computer
  44. AMC 360 flexplate
  45. Used pro-fab or scs
  46. 04 jeep liberty gas tank
  47. 93 Zj Lift Springs
  48. YJ Safari Top
  49. WANTED grand cherokee V8 coils or polly spacers
  50. WANTED cheap or free Grand cherokee V8coils or poly spacers
  51. 3.73 8.8 gears
  52. Heat/ac Control 99 Tj With Plugs ???
  53. Wanted - heater box and duct work for a 78/79 Bronco
  54. torch
  55. WTB: Dodge Ram 1500 Drivers Door and body lift bumper brackets
  56. std. cab short box 2wd or muscle car project
  57. Need to borrow: Two dana 60 kingpin rebuild kits
  58. Wanted Dana 28,from ranger,with 456 gear
  59. Wanted Nissan Hard body project
  60. need a t-case for a 2002 chevy 2500 3 buttom.
  61. YJ Door Uppers
  62. 35's!
  63. 91+ 4.0L head Jeep and passenger side D30 shaft
  64. WTB: WJ Overland Springs
  65. ford big block
  66. W.T.B. YJ Springs
  67. Wanted Jeep YJ heater box
  68. WTB: Boss OC-3 Octave
  69. wtt 16.5" rims
  70. ZR 600 Cylinder & Piston -Arctic Cat-
  71. 93 xj 4.0L header
  72. Wanted np242 and 31-10.5
  73. Wtb Jeep Rubicon Front Locker
  74. wtb, front driveshaft for liberty
  75. WTB ZJ Trans
  76. 454 Bbc
  77. Good used quality shop equipment
  78. garage fridge
  79. feeler d60 and 14 bolt carrier
  80. no longer needed WTB Shank style lug nuts for explorer/mountaineer
  81. WTB engine stand
  82. anyone wanna get rid of a excursion
  83. Yamaha 3-wheeler parts
  84. one jeep wheel
  85. danna 44 axle parts
  86. 4" x 5" Vinyl Tiger Butterfly Sticker
  87. 33 tires rims with 5 on 4.5
  88. !!Wanted; mustang parts!!!!
  89. 1350 slip yoke
  90. WTB: Comanche/MJ parts
  91. Dodge Ram Front Sway Bar
  92. 19lb per hour injectors and zz502 cam
  93. Turbo 2001 7.3
  94. 14 bolt 4.56
  95. Air compressor
  96. WTT 96 Dodge Ram Longbed Ext cab Cummins 4x4
  97. Np 231
  98. I want a 351w
  99. Need 1994 Chevy 5.7 Throttle Body.
  100. LOCK Wtb 850 4bbl
  101. exhaust shop downriver.
  102. I want a Rig!
  103. wtb: Ford duraspark II pre 78
  104. WTB: Lift for 1994 Chevy truck full size.
  105. Pest Removal
  106. Dana 60 flanges/slugs
  107. Lift for 1989 Bronco
  108. 33 boggers on 8 lug rims for a weekend
  109. Black kitchen appliances
  110. WTB: 2 15" Echo wheels
  111. cd player for a car
  112. hitch for 02 dodge 1/2 ton van
  113. Carpet installer around Ypsi area?
  114. in need of 315,305,35in tires
  115. dana 30
  116. Miller Welder or rockwell 2.5 ft trade for my 6.0
  117. Drill Press
  118. B&W gooseneck hitch for 06 chevy 2500
  119. 1989-2000 Ranger
  120. 235/85/16 or 285/75/16
  121. need 8.8 axle
  122. Wanted Chevy Turbo 350 cores
  123. 4.2l I6
  124. Np 231 for dodge.
  125. WTB truck snowplow
  126. Chevy Gas Tank
  127. 91 ford ranger fender flares
  128. FORD F-350 Diesel Starter
  129. forced air woodstove to heat house and garage
  130. WTB. 1996+ Reg Cab 4X4 Ram
  131. 4.56 and 4.10s gears for 8.8
  132. Front drive shaft
  133. looking for a 3.0 5spd tranns for a 2wd
  134. dodge posi lock
  135. WTB: Original XBOX
  136. 17'' 8 lug wheels
  137. Ford 150 4x4 supercab $2500 or less
  138. Stock steel XJ/YJ wheels trade
  139. rubicon wheels 16"
  140. trans fill tube and neutral safety
  141. CJ 7 Tub
  142. 2000 Chevy BB Headers
  143. Chevy 4.3l motor
  144. -please close-$1500 cash in hand, looking for a new ride!
  145. Want an XJ YJ TJ ZJ?? DD
  146. Jeep Liberty Tailgate
  147. Leaf Springs.
  148. two post lift
  149. In need of a 3.0 5 spd tranny
  150. ruger 10 22
  151. S&W 357 to trade for 35"+ mud tires for 16" rim
  152. wtb 88-98 chevy k1500 shortbox
  153. 2003 Chevy 2.2l motor
  154. WTB WJ tie rod and pitman arm.
  155. ecm
  156. ford np435
  157. 1
  158. want dune buggy project
  159. Slip Yoke Eliminator
  160. Wanted 37 or 38s,
  161. wtb 4x4 durango or ramcharger
  162. xj 4 door floor pans
  163. casino cash
  164. Western plow mount and wiring
  165. Wanted: Dana 20 eight lug hub with hub lock
  166. 42RH Tranny for 93 - 95 Grand Cherokee
  167. 2.5
  168. WTB 2" lift full length XJ add a leafs
  169. Wanted - 38.5 or 37 or 36 swampers for 15" rims
  170. looking for chevy axle
  171. Need '74 CJ5 Wiring harness
  172. WTB 285/75-16's
  173. old snatch straps
  174. 97-2000 AW4 trans
  175. wtb 355 or 383
  176. ford radiator
  177. Super Duty front driveshaft
  178. WTB Cheap PosiLok.
  179. tj soft top frame
  180. YJ Fuel Rail-4.0L
  181. looking for a xj front drive shaft
  182. Locker, LS or Selectable for 35 spline D60
  183. wtt 79 bronco mud truck on 40" boggers pic link is up
  184. Looking
  185. WTB 35X12.50X15 MTRs
  186. Any GL Vendors Spicer ditributor's?
  187. Looking for F2/350..show me the listings puhleaseee
  188. Who has a good TJ back window cheap?
  189. TJ Transfer Case Linkage and shifter
  190. looking for surco roof rack and brushguard
  191. 5 speed aspire trans
  192. WTB used SS tube steps for 83 CJ 3"
  193. WTB used SS or Chrome tube steps for 04 LJ 3"
  194. broken d60 shaft
  195. WTB: XJ Dana 44 rear (87-89)
  196. WTB Passenger Side Tail Light for 2000 Chrysler Town and Country
  197. 77F150 d44 or F250 leaf sprung d44
  198. BBC Asseccory Drive
  199. Xj parts
  200. Wtb Xj
  201. 350 tbi
  202. WANTED: General Grabber ST
  203. Junk leaf spring, and scrap steel.
  204. wanted: 29" or 31" mud tires 50% or better
  205. looking for np231 t.case
  206. Wanted: ECJ5 Lift Springs.
  207. Old snowmobile track
  208. sterling side gears
  209. wtb dana 60's
  210. GM 10 bolt gears 4.88 or lower
  211. Snow plow
  212. Wanted CJ7 Project
  213. pcm for 96 tracker
  214. CJ7 Tilt steering colum
  215. Dana 30 w/3.73
  216. 97 Jeep Grand cherokee book
  217. Dana 30 3.73 NEEDED ASAP!!!
  218. puppy wanted, prefer lab or beagle, consider others
  219. WTB: XJ hatch lock
  220. need 1987 5 speed sammy tranny
  221. looking for 1 bfg at 35/12.50/r15
  222. CJ or J truck Ps box
  223. Dana 44 pass.drop
  224. looking for tj hard top
  225. YJ Soft Doors
  226. YJ Fenders, TJ Flares and YJ Family Style Roll Bars
  227. 98 TJ hard doors
  228. Rims
  229. tires & rims wanted
  230. Ford 5.4l for a f250
  231. wtt yj clip for cj clip
  232. wtb: xj front end parts
  233. No longer needed-Ford small block 4x4 5 speed trans
  234. WTB 35x1250x15 spare.
  235. Need 36" or up to 38" but NEEDs to be 16" rims
  236. 99-03 3/4 or 1 ton Ford stock steel wheels
  237. WTB Hack n Tap SYE flange
  238. 93-95 zj front bumper
  239. cheap lift for a early 90's fs broco
  240. Tail light guards
  241. WTB: 1- 35x12.5x15 BFG All Terrain
  242. 87 to 95 Wrangler Tub Wanted
  243. np242 for 94 xj w/4.0
  244. family syle roll bar for 83 cj7
  245. 8-Lug Rollers
  246. Chevy Suburban
  247. wtt my xj for a fuel efficent vechile
  248. d60 REAR OPEN CARRIER
  249. need manual trany for a 4cyl. wrangler 1994
  250. lift springs
