  1. WTB/WTT: Off Road Explorer for DD/weekend XJ
  2. tracker rims
  3. '89 YJ Vacuum Disconnect Assembly
  4. Wanted 99 Tj Ax15 ???
  5. looking for a beater jeep
  6. need parts for 01 xj
  7. set of 30-32" tires
  8. yj lift springs
  9. after market xj bumpers
  10. 97+ 2 Door XJ Window Switch
  11. smaller car that gets good gas mileage and is relatively close to petoskey,michigan
  12. Cargo Trailer
  13. WTB Spring plates for Dana 44
  14. 460 and install wanted
  15. Wanted 33" spare!
  16. Kegerator
  17. Grille guard for Explorer
  18. Wood stove pipe.
  19. stock pitman arm
  20. ford v10 or 5.4 running
  21. 14 Bolt SF Drum Brake Backing Plates and drums
  22. Need 4 XJ wheel spacers. 1 Inch or better.
  23. wanted: 03 ford f350 tailgate
  24. Spare tire,rim and carrier wanted
  25. Xj fender Trim
  26. portable garage thing
  27. ***Wanted***95 chevy 4x4 4L60E tranny
  28. wasr-10/akm/ak-47
  29. tonneau cover
  30. 1 33x12.50x15 bfg MT no longer need
  31. Looking for a lifted xj or other lifted suv!
  32. 1962 Willys
  33. 4.3 v6
  34. YJ floor pamns
  35. TJ PArts and 31 or 32's
  36. 4L80e Trans for 6.5L 4x4
  37. Tires!! 235-75-15
  38. 72-75 steel CJ5 tub needed
  39. WTT 2000 Sierra PICS UP!
  40. 4.0L manual trans and manual t-case needed
  41. 95 wrangler 4" lift
  42. 36-38 inch tires
  43. Rover V8 wanted - Trade for Samurai
  44. Tubing roll former
  45. Looking for 5 x 5.5 to 5 x 4.5 wheel adapters
  46. wtb tires for winter
  47. T-Case bracket
  48. 20 Gal CJ Skid Plate
  49. yj bumpers
  50. PC Memory PC-3200/DDR-400
  51. 14 Bolt Rear
  52. Dana 44 drivers axle shaft
  53. Trade For My Custom Car
  54. Jeep Cherokee Leaf Springs
  55. transfer case
  56. Wanted - 17" steel wheels for 05 super duty
  57. Looking for a 1991-1994 ranger cab!!
  58. Air compressor.
  59. chevy vortec 350 starter
  60. WTB 20" or larger computer monitor
  61. NP231 Transfercase for S10
  62. gm tech 2 scanner.
  63. need 1/2 or better thich tough rubber
  64. Tool chest
  65. Steel 6 lug rims for Toyota/Chevy
  66. cheap front steel bumper for 79 f150
  67. WTB: Dana 30 or HP 30 TJ or XJ with 4.10's
  68. f-series doors
  69. Need XJ parts...
  70. YJ t-case skid plate
  71. 89 wrangler ignition coil
  72. YJ Wrangler parts
  73. WJ class 3 trailer hitch
  74. WTB 33"s
  75. front trac-bar for xj
  76. 2001 GMC Sonoma 16" rim ZQ8
  77. want to trade Dana 44
  78. B&M Shifter Northern mi
  79. GM Dana 60 Ring and Pinion
  80. 99 XJ Passenger Mirror * electric *
  81. Need a dd 4x4 around $3000 or less
  82. WTB: 5x5.5 15" rims
  83. WANTED: CJ7 Tilt steering column
  84. CJ7 Tub and 350 Conversion Parts
  85. Jeep Transfer Case
  86. free scrap metal wanted
  87. Trade Hot Rod
  88. WTT: 87 XJ D30 - drives side axle shafts
  89. Need TV Antenna
  90. 4.10 gears for 8.8
  91. 73-87 Fleetside Shortbed
  92. WTT 44s
  93. Desktop Computer parts
  94. tail gate
  95. windshield frame tj
  96. remington 870 or mossburg 500 or similar
  97. 8 lug D44 spindle on out
  98. ford shafts
  99. car hauling trailer NEEDED/TRADE
  100. Wanted: original Goodyear MT
  101. 16 inch rims
  102. small .38 or .357
  103. 1968 Suzuki Motorcycle
  104. TJ Front Flares Wanted
  105. tj grill
  106. Wanted: 304 Harmonic balancer
  107. Tube Frame
  108. WANTED 91 yj glass
  109. BFG dealers on here?
  110. Ford truck bench seat
  111. Intake manifold for Cadillac big block
  112. Pit bull growler tires
  113. 355 or 383
  114. 275/60/15 street tires
  115. WTB Tires 235/70/15 need at least 2
  116. 97+xj carpet
  117. looking for 6cyl yj frame
  118. wanted: tailgate for 1996 dodge ram 1500
  119. Hitch for a 1994 grand cherokee
  120. 1980 bronco frame
  121. 205 Rear U-Joint Yoke
  122. Ford Explorer 8.8 and 35 gears
  123. 315/70/17s all terrains
  124. Shocks
  125. Trade 89 Wrangler and 91 honda civic hatchback (NEW PICS)
  126. 1994 cummins parts needed
  127. Winch Mount
  128. 285-75 R16 truck tires
  129. Good set of tires for 99 dodge 3/4 ton
  130. LP waggy 44
  131. 93 tracker passanger side tail light
  132. Ramcharger PCM
  133. cj radiator needed
  134. 265/75/16 or 285/75/16 tires wanted
  135. WTB 15x8 steel rims, 5x4.5 around 4" backspacing
  136. CJ tilt steering column
  137. 2000 Grand Cherokee Drivers side headlight ass'y
  138. Tire siping.
  139. Snow plow
  140. C-4 trans and transfer case
  141. Bearing
  142. "wanted" Dodge Ram Front Doors
  143. wanted botte caps
  144. WTB: 32RH w/ torque converter
  145. Tire Discount Wanted
  146. vortec 5.7
  147. wtt early bronco chassis for anything
  148. WTB steel I beam
  149. WTT: XJ Brush guard
  150. th400 case or good working th400
  151. Bulk coal supplier.
  152. TJ Extended Bump Stops
  153. dodge neon rims
  154. '92-'96 Bronco interior pieces
  155. 84 chevy front Driveshaft ASAP
  156. ZJ Floor Mats(Charcoal)
  157. 2.2 isuzu deisel OIL pan
  158. Wheels & (or) Tires
  159. 31-32 ish tires for 16.5 rims
  160. Fence materials for a horse
  161. wtt for a runninf yj or tj
  162. AW4 transmisson XJ trans
  163. 11HP Tecumseh horizontal shaft
  164. 35 inch tires for 16 or 17 inch wheels
  165. want a XJ dana 30 strong aftermarket diff cover.
  166. Need 215-75-R15 Michelin LTX MS tire
  167. H2 hummer wheels set of 4
  168. ozone generator to rent/borrow near Howell
  169. 1999 TJ Doors....
  170. wanted asap AMC TF727
  171. H1 INSERTS/Dana 60 HIGH STEER ARMS
  172. 89ish xj
  173. CJ7 or YJ doors
  174. super duty tonneau cover
  175. Cheap but big fish tank
  176. magnetic block heater
  177. 235/75/15 snow tires lots of tread $125.00
  178. 13" MacBook
  179. 255/70/16 Tires or close
  180. D30 for Xj
  181. WTB: I need various YJ Jeep parts; license plate bracket, center console,mirror...
  182. Leaf Cleanup Job
  183. WTB: Cheap Jeep/Truck/Whatever - 4x4
  184. 3/4 ton dodge leaf springs
  185. 5.2 magnum
  186. Dana 60 and 14FF
  187. 37"+ tires, 16 or 17" rims
  188. 4.0 for a tj
  189. 15 inch s-10 rims
  190. 88 Ford Ranger door latch
  191. 32x11.5-15 Bfg at's
  192. CJ7 Drag Link and Tie Rod
  193. Wtt Trade Tires
  194. 95 YJ carpet
  195. mud truck
  196. wtt my rust free 1/2 doors for fulls
  197. 78-79 ford bronco crossmember
  198. wtb toyota solid front axle!
  199. Wanted 4-5 cheap jeep wheels 5x4.5
  200. wanted t-350 to dana 18 adapter
  201. Plow Service needed in Ortonville!!!!
  202. SR4 Shifter Assy needed for active military man
  203. shift cable for '96 s10 zr2
  204. snow blower
  205. WTB - Drivers door for 98-05 s10 Blazer
  206. SM-420 To Dana 300 Adapter
  207. 350 tbi
  208. CV drive shaft
  209. I Need Spider Gears
  210. Transfer Case NV 241DHD out of a Dodge Ram
  211. 69 chevy truck cab 4x4
  212. 33-35 tires for 17-18in wheels.
  213. open carrier for 14 bolt
  214. 52 and 62cm bicycle/frame
  215. 94 wrangler pcm
  216. cheap 6" lift kit
  217. 96 XJ Key Fob/Transmitter
  218. WANTED: Vortec chevy 350 5.7L 96-99
  219. go cart frame
  220. Looking for Expert Mechanic for lift job...
  221. WTT mini quad for go cart
  222. lookin for a fullsize 4x4 extended cab or crewcab
  223. 93 ZJ parts needed, front fenders, Dr side rear door, and rear bumper,swaybars
  224. 2001 F150 spare tire needed 17 inch tire
  225. XJ parts needed!
  226. 4.0l H.O. head
  227. cheap rubber bed mat
  228. 2 door or 4 door jeep jk body
  229. amc crank
  230. Ford super duty front driveshaft
  231. WTB: 35" or bigger ATs
  232. looking for a snowmobole
  233. No longer needed. WTB Head for toyota 22re
  234. Throttle Body
  235. Not needed
  236. BroncoII/Ranger/Explorer lift kit WANTED
  237. WTB: XJ Traction adders - Or factory Trac Lok
  238. turbo 350 to dana 300 adapter
  239. car for young driver
  240. '98 S10 Front Air Dam
  241. 94 grand cherokee
  242. Bushwhacker cutout's for a Fullsize ford ?
  243. 2000 4.0 for grand cherokee
  244. 36 x 12.5 x 15 SuperSwamper
  245. CO2 tank
  246. 37" TSL 15" rim
  247. salt spreader
  248. need passenger half door tj
  249. 2003 f350 stock springs needed NOW
  250. 97 tj auto trans
