- 97-01 doors from a 2dr model XJ
- 33x12.5x15 mud terrains
- 235/75/15 Bfg
- Wtb 285/75/16 305/70/16
- tj hardtop rear window
- 67-71 chevy nova
- wtb 6 inch lift 92-97 bronco/f150
- Help Need House Asap
- B&M shifter part
- FF14 Bolt Rear Yoke
- 97+ chevy/gmc k-series truck
- D35 LSD parts and axles shafts
- Looking for a lift and other misc items....
- wtb cherokee brush guard
- ORU Solid Axle kit
- looking for a old style western plow mount
- Rear Glass 99-up Chevy Fullsize.
- Cheap 4x4 truck to put a plow on
- 1978 Bronco Parts
- Trade for a Jeep
- EB d44 {1st gen bronco}
- 351W and ford axles neeede
- YJ hood!
- 31-33 tires for 17inch rim
- steel rims
- Need a set of rims for a YJ
- driveshaft
- WTB 4.0L used aftermarket header
- WTB: yj license plate frame
- 5 x 4.5 wheels 15's or 16's
- NO LONGER NEEDED 1/2 ton chevy truck axles
- Wanted, clean 93-01 XJ
- cj powersteering box
- chevy 6 lug 10 bolt
- 98 XJ track bar
- old tractor or skid steer
- grand cherokee
- 235/75r15 tires
- 8.8 Locker
- Need some 93 xj body parts fender bumper header panel
- 2" lift blocks
- Need 4.0 for 99 TJ
- Pair of 35" Boggers
- xj mirrors plates
- Flexplate for a 7.3 diesel
- Need 31/10.5/r15
- XJ Clutch Pedal Assembly & AX15 Bell Housing w/External Slave Mount
- ford trans output shaft
- Tires wanted
- wtb car hauler trailer
- WTB Samruai header
- wtb jeep tj wheel spacers
- WaNted XJ or WJ
- needed stock rims and tires for grand
- TRADE? 99 Grand cherokee 4.0 4x4 selec trac
- WTB 4in lift for a 95 gmc pickup
- 94 xj parts needed (its green)
- xj front tow hooks
- 02 Ford 5.4
- CJ / YJ Tub + (4) YJ Rear Leaf Springs
- Floor Jack
- Need a 4.2 header
- Wanted:JL Audio Sleath Box for my XJ
- 4 door diesel truck
- someone who can cut splines
- broken or damm near free d44 pinion gear
- Hard top drivers side rubber corner piece for a YJ
- 4.7 Jeep Grand V8 engine, Motor
- 79 f150 ignition harness, need it bad
- 36" military OZ tires
- 31x10.5 R15s
- XJ HP D30 around Muskegon?
- 35" tires or bigger
- WTB/Jeep/S10/4X4/cheap
- Coil buckets.
- Corporate 10 Bolt 4.10 Ring & Pinion
- Beretta 391
- Pro Comp 35-12.5-17 All Terrain
- WTB dana 30 pass. front axle shaft
- 25 or 27" TV for garage
- Yj Bumpers
- Ford 9.75 with 3.55 ratio
- machinist w/ cnc mill
- WTB: hard top and full doors for YJ
- not needed-steel doors -cj
- 2000 xj t-case
- Scrap Engine Block
- 20-22x10x9 atv tires
- No longer needed. WTB AX15 23 spline
- 2008+ Ford super duty Stock 20s or 18s wanted.....
- Crew Cab Chevy Extra Short bed Topper
- stock yj pitman arm
- 265-75-16 tires EDIT
- WANT Dana 44 or Ford 8.8 set up for TJ with 4.10 or higher gearing
- MI - D44 4.10s/carriers/tru-track?
- Need a set of mud tires.
- Wanted RANCHO 44044 springs
- trade a HP front 60 for GM front 60
- complete comanche
- chevy steering arm
- 35x12.5R16 tsl Thornbird
- WTB dodge 2.5L to ax15 bellhousing
- WANTED: XJ Cherokee Power Steering Gearbox
- 97 or newer wrangler wanted
- 88-95 chevy blazer
- 94 xj 4.0 engine wanted
- driveshaft
- set of scout II dana 44s
- MB GPW or CJ2A windshield frame
- WANTED: ABS Sensor -ZJ Grand Cherokee
- '94 Ford Drivers door Glass
- wtt: 15x10s
- e4od to tcase adapter
- WTB: Side window for Glasstite Raven cap - just broke mine
- 97+ XJ Parts
- Explorer Leaf springs
- 20" long coil springs.
- Dana 30 and Dana 35 carriers
- WTB backhoe or loader tractor
- ford 24# injectors blue tops
- lookin for a winch
- cj7 tub wanted bad.
- WTB some 33's on 5x4.5
- yj hard doors
- dana 44
- CJ speedometer
- dana 60 front
- WTB: 5.13 Gears and Locker for ford 8.8
- gas tank for 89 chevy stepside
- No longer need rear axle for 2001 Dodge sport 1500 3.55 gear
- '89 YJ Vacuum Disconnect or Posi-lok
- XJ Steel Tailgate
- Good running 4.0
- XJ Grill
- WTB: TJ Swaybar w/ Bushings
- WANTED REMINTON Model .410
- 6" front springs and dual exhaust for a 78 f150
- 15x10 chevy steel wheels 6 bolt
- Jeep Tj Tcase skid, MML, Wider Flares, D30 D44 locker
- 73-87 Chevy 1/2 ton 2wd parts
- 1966 C10 truck parts
- SBC - 377 to 400+ c.i.
- d60 balljoint knuckles
- roll bar for yj
- Complete 8.8 4.10gear set up for a yj
- Wanted XJ!
- 96 gmc parts
- dodge ram tires
- 14 bolt detroit/35 spline lockouts
- piece of sheetmetal - 20ga
- Anyone live near toledo and want to make a quick buck?
- TJ Parts
- seats
- 98 4.3 Vortec
- 15"x7" or 8" - Used Rims - 5 on 4.5"
- Power Inverter
- WTB 4.56 14 bolt
- Xj Long arms
- Need a battery
- Need 80-92 waggy front dana 44 inner shafts
- 4" or 6" lift for 1996 Chevrolet 1500 4x4
- WK: looking for leather seats
- XJ or TJ Dana 30 WANTED
- Front seats 1974 cj5
- 7 degree reamer wanted to buy or barrow.
- 235-85-16
- need used vehicles with plow.
- Wanted - Excellent shape and low mileage XJ, 98-01
- Wireing harness
- need headers
- Axles!
- Gm rear end
- 390 carbs
- boss plow mount for 95-98 mount chevy or 99 dodge
- Dana 30 Axle Shafts
- 30x9.50X15 BFG A/Ts
- grand am 3100 v6
- 305-70-16 nitto terra grapler
- Stock TJ tierod and frnt lower control arms
- wanted subwoofers
- Need 4X4 parts PLEASE
- Wtb Offset Rims 5 4.5
- 35 spline d60 outers Ford HP
- Jeep tj Rock Rails or Sliders
- 15X8 or 15X10 Black steel D-window
- 15x10 AR Outlaw II style wheel
- wanted mud tires 38 to 40" X16.5
- Hydro steering setup
- WTB Ford 8.8 set up for TJ
- AMC 360 intake
- sidekick hard top
- 315/75/16 yokohama geolander MT
- WTB Fuel Tank with Pump and Sender 1993 Sidekick 4 dr
- WTB H2 Rims or H1 rims Re-centered
- wtb wheels 8 luge 15in tire 12wide
- Shotguns
- 1980-1996 Ford Dually Rear Axle
- 1980-87 Chevy 2500 truck emblems
- WTB Ford 8.8 setup for TJ
- wanted: Johnny Joints good or bad for mock up project
- Verizon phone. Would like a full keyboard phone. My screen died
- Wtb Used 33-10.50-17
- Wanted 79 ford f150 part
- YJ Upper door windows
- A Place To Hunt
- wtb: tj or xj front dana 30 w/ 4.10s
- PT cruiser rims
- dana 60 front parts 31/10.5 t-case
- 235/65r17
- Rims needed.
- Plow for 04 Dodge 2500
- Powder coat gun and electric oven
- WTB T-176, Bell, flywheel
- WTT 36 13.5 15 IROKS and Rims
- Dana 35 Yoke
- 4"x3" steel or aluminum rectangular tube
- looking to trade my 33's for 35's or 37's
- YJ Hardtop rear window...
- 203 to th 350 adapter
- WTB: Explorer or Wrangler
- Pugs
- Wanted: XJ Drop Pitman Arm
- WTB Drive Shaft 4 a '94 Ford 52.5"- 53.5"ish
- raccoon pelts
- Ford transmission
- TJ or XJ or MJ
- WTB Nice UNMOLESTED 97+ XJ Cherokee under $4500
- front tj rubicon axle shafts
- WTB: Steel XJ bumper
- Oldsmobile small block motor 307/350/403- must run
- Wanted: 97-01 XJ Rear hatch window
- dark red (sienna?) XJ hood
- 35" m/t
- Gas Cap Cover
- Flowmasters
- ISO another spinner bike - prefer name brand ex-Gym type - Lifecycle etc.
- WJ roof rails wanted
- Wanted: TJ rear adjustable upper control arms
- 40"+ Tractor Tire Rim
- WTB: Winch - at least 8k or bigger
- Looking for a plow truck
- Chevy truck doors
- lawyer
- gl4x4 hi-res logo
- amc 401 heads
- 31/10.5/15 all terrain/ mud terrain
- Right front fender flare for 98 XJ
- Wanted: Milk Crate
- ford 8.8 out of 95-01 explorer 3.55 gears
- Need one 31x10.5/15 for a spare
