Wanted [Archive] - Page 65 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. Childs full face helmet
  2. Tire swing tire(large rim size)
  3. Wanted: 750 cfm Eldelbrok Carb
  4. Long arm suspension kit for 2000 TJ
  5. Slip yoke eliminator kit for 231
  6. wanted cj radiator for V-8
  7. YJ rear hub
  8. tj lift kit around 3" tall
  9. looking for a complete running 454
  10. Ford 9"Rear Dana44 Front
  11. 8 lug trailer axle
  12. cheap 33" spare
  13. 302 intake
  14. Jeep Starter
  15. tj green and tan rear seat
  16. Ruger 10/22
  17. YJ full hard doors
  18. Dodge and Jeep parts wanted
  19. 5th wheel hitch rails
  20. NEED dana 44 rear axle ASAP!!!
  21. some YJ stuff I need...
  22. Gooseneck car trailer 30ft or longer
  23. YJ front bumper
  24. need maual tranny peddle and linkage
  25. 4.0 Drive train wanted for CJy Build
  26. 231J Tail Housing
  27. e4od diesel trans
  28. ax15 trans for a yj
  29. WTB: D30 4.10 R&P and carrier or 4cyl TJ D30
  30. WTB,C.B. antenna mount for an xj
  31. Door Mirrors for TJ
  32. chevy drivetrain
  33. D44 TTB axle shaft
  34. Razor MX350 Dirtbike
  35. wtb lockright locker
  36. low boy (mobile home) trailer wheel and tire
  37. YJ lift shackles
  38. 8 1/4 or dana 44 rear, wheel spacers
  39. 89 cj parts HELP??
  40. Ford T18 needle bearings
  41. Chevy Truck Fender
  42. WTB Walther P22
  43. one 39.5 TSL spare for 16.5 rim and one H1 8 bolt
  44. wtb 1st gen dodge crew cab
  45. FF 14blt shafts
  46. Diesel engine stand. Will buy or rent !!!
  47. 97-01 xj carpet
  48. WANTED 15x8 5 on 5.5 wheels
  49. TJ Drivers Seat
  50. Need 258 Engine
  51. D60, 70 or 14 bolt side gears for Detroit locker
  52. horizontal shaft engine
  53. 97+ xj front body parts
  54. somone who can weld headers
  55. 97 TJ 4Cyl
  56. Axles for a TJ (prefer 44's) NO LONGER NEED
  57. Ranger parts wanted
  58. Lookin for a set of 31's or a set of 265/75r/15's
  59. 96-99 Chevy Vortec A/C Compressor
  60. Machine work near Sadinaw
  61. rear glass for a bronco
  62. Dana 60 shafts needed
  63. TJ comp corners and rocker guards.
  64. Chevy Grille / Body Lift / 4wd Actuator
  65. wtb 2.5 Jeep engine
  66. ranger tube bumpers
  67. XJ Stock Trac Bar and Mount
  68. AMC V8 Rocker Bridge
  69. Wanted: Stock TJ tail lights
  70. Coffee Cans near Flint
  71. Mass air
  72. wtb a jeep
  73. WTB 86 or older chevy 4x4
  74. 350 or 4.3 block
  75. 93-98 grand cheorkee steering box
  76. 15x10 8 bolt wheels
  77. wanted spare 40x17x15
  78. Mud Toy. Project.
  79. Rubicon Flares
  80. axles or gears 4:10's for TJ
  81. atv paddle tires
  82. cheap machanic in T.C.
  83. scissor lift for rent???
  84. 95 z71 parts
  85. Stepside Truck Tool Box
  86. CJ7 windshield frame preferably w/ glass
  87. 225/75R15 tires on steel 5x4.5 bp wheels
  88. Need back driver side window
  89. 1998 grand cherokee trans
  90. motorhome to rent
  91. stock jk control arms
  92. Wrangler Springs
  93. Need 4 or 5 tires
  94. info on WARN 8274
  95. wanted magnum 318
  96. WTB 1 1/2" mild steel tubing
  97. wanted: rear yj springs
  98. D44 gears/carrier
  99. axle shaft wanted
  100. dana 35 gears 3:08
  101. CJ7 radiator w/ v8
  102. wheel bearing hubs dana 30
  103. TJ metal half doors
  104. Silverado 2500 HD Air bags / Suspension
  105. Dana 30 Dana 35
  106. 16-18' Catamaran
  107. 15x10 8 lug rims
  108. Honda 400EX
  109. Looking for Kayaks
  110. trade my crf450 or duramax for tj
  111. Great Dane Stud
  112. Cj steering linkage
  113. Rubicon Express 5.5 springs
  114. TJ Dana 30
  115. Factory Ford Super Duty Molded Runing Board
  116. need a AC pump for a 4.0 XJ motor.
  117. Someone to build an offroad unicycle ?
  118. Blink 182 Ticket
  119. TJ stock track bar
  120. WTB pre92 YJ Pass Seat Riser
  121. Ford 9 inch
  122. tj computer
  123. CJ Speedo
  124. ZJ radiator for a 4.0l
  125. Early 90's erra Ford 1/4 ton drivers seat wanted...
  126. lock outs
  127. Rust free Yj tub needed!
  128. YJ parts
  129. YJ family roll bar
  130. CJ/YJ Supertop Rear Windows
  131. Wanted: LSx Engine 5.3 or 6.0L
  132. need parts bad and cheap
  133. Jeep tow bar???
  134. looking for 4-- 8 lug on 6.5 wheels
  135. Cherokee Regular or Bastard Leafs and stuff needed
  136. 15X10 inch aluminum rim for a Cherokee.
  137. Shotgun or AK-47
  138. WTB: ASAP XJ rear driveshaft
  139. Dodge Manual Tranny
  140. Need Someone To Run A Carfax!
  141. Ax 15
  142. WTB: AR15 upper
  143. 4.56 rings and pinions for dana 30 and 35
  144. wtb chevy tilt steering column
  145. wtb rims and tires
  146. wtb rolling chassis tj or yj
  147. bumper with wench inlay
  148. Someone With A Table Saw To Make 4 Cut's For Me (Clarkston Area)
  149. looking for 4.10 gears
  150. dana 44 ubolt yokes
  151. Sunroof style soft top hardware for a yj!!!
  152. Trailer wheel and tire (205/75R15)
  153. TH350 to 205 Adapter
  154. Need 2 Jeep motors: 97' 6cylinder, 99' 4cylinder
  155. WTB: XJ rear leaf spring - factory height
  156. Electric fan wanted
  157. t-case for durango
  158. wanted tj lift spring spacers
  159. adjustable upper TJ control arms
  160. long box cap
  161. 31x10.50-15's
  162. WARN 8274 parts
  163. zj front seats
  164. diesel gauges
  165. 4:11 to 4:88's for a hp 30 and 8.25
  166. WTB: XJ lift shackles
  167. c6 trans
  168. Loader bucket wanted (project on hold)
  169. 88-98 chevy driver's door and short box
  170. Wrangler mirrors
  171. 1 or 2 -- 305 Goodyear Wrangler 16" rim
  172. amc 360 cam gear today!
  173. Chevy 57" or 64" springs
  174. YJ Tailgate
  175. VW aircooled motor / engine ??? Anyone??/
  176. Center Console
  177. 30in Tire
  178. XJ rear leaf springs
  179. Winch Wanted
  180. YJ back seat
  181. Looking for Ford 8.8 rear axle
  182. Winch Wanted
  183. TJ Tailgate Hinges
  184. Lookin for 4x4 vehical
  185. Dana 35 w/3.73 gears that would fit a 99 wrangler.
  186. Black wagon wheels
  187. 5.0 or 5.8 injectors FORD
  188. WTB 2 truck beds or floors
  189. 36x14.5 r15 tsl radial
  190. Explorer body parts
  191. 16" Wheels for XJ
  192. 91 Vaccum motor axle disconnect for dana 30
  193. WTB: 33 or 35 inch tires
  194. 2 Flowmasters
  195. WTB: 78 ford bronco tailgate
  196. Lathe/welding work - threaded shaft (THANKS St. Pierre Inc.!!! 2486202755)
  197. need dimensions for front long arm kit
  198. Need tailgate parts for k5
  199. Need a 44RE for a 98 Grand Cherokee
  200. 265/70-17 tires
  201. ***need A Wrangler Tub, Doors, Windshield, Tailgate****
  202. 20" 8lug rims for old fords ???
  203. 235.75.15's
  204. 2 or more tickets Toby Keith DTE 7/19/09
  205. RE 1.5" SOA Springs
  206. 2 or 4 235/70r16's
  207. 38x?x15 spare
  208. 100% working ba/10 Transmission
  209. YJ carpet
  210. WTB 22WMR Rifle
  211. Ford leaf spring
  212. 92 cherokee doors and misc.
  213. Set of 35 or bigger mud tires on 15" rim
  214. (1) Single 33" spare tire
  215. 16.5x14 wheels
  216. CD Player
  217. rod ends / heim joints
  218. dodge np208
  219. YJ Frame Repair
  220. Jeep CJ Radiator
  221. Jeep XJ Cherokee Lift Kit Lift parts
  222. Blown 46re trans. for a 97 4x4 Ram
  223. 700 remington
  224. WTB: Stock rear ZJ coils (93-98)
  225. need spare tire 35/ 12.5/15 and bench seat
  226. f78-15 or 205/75/15 trailer tires
  227. magnesium runflat for h1 rim
  228. Cheap Welder
  229. greaseable bolts?
  230. 2006-2009 Chevy/GMC 2500HD/3500HD Duramax CrewCab 4x4
  231. gen 2 dodge lift kit
  232. chevy calipers for cores - any year etc
  233. Looking for a 460 block
  234. rubicon front drive shaft.
  235. Need an AX-5 for a 91 Wrangler
  236. Full Traction SLEEVE!!!
  237. Lookin for a $500 or less beater near Alpena-please close
  238. Full hard doors for YJ
  239. Clutch disc trade?
  240. Crankshaft positioning sensor
  241. YJ leaf springs wanted
  242. 1999-2003 Front Bench Seat
  243. 17" Chevrolet 6 Lug Wheels
  244. 4.88 gears for a Toyota 8"
  245. looking for late 70's f series 4x4
  246. Need rear half of a TJ tub
  247. AUTO TRANS FROM 86 or older XJ with 2.8
  248. mech fan for 460
  249. gas tank
  250. tires
