Wanted [Archive] - Page 64 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. Steering column cover for 96 cherokee
  2. Need 3.1 liter for a 99 Monte carlo
  3. CJ5 Tub
  4. Need rear ranger lift springs and s10 interior
  5. Alternator for 1999 Ford Explorer
  6. 4 good 31's for a 15" rim
  7. Radiator for 89 F-150 4.9 (300 CI) six
  8. dana 30 for xj
  9. Ford 1/2 ton axle Front and rear
  10. Nissan z24i Head
  11. alternator for 89 yj 4.2
  12. WTB: GOOD 700r4 trans.
  13. tail housing
  14. manual vehicle
  15. 9 inch bearing retainer plates
  16. YJ Front Seat Belts
  17. wtb: tractor/mower for cutting large acerage
  18. Nissan SD-33 Diesel
  19. wanted: 3" body lift for 01 Chevy 1500 4wd
  20. Rear seat lap belts
  21. cj yj or xj
  22. NP243 T-Case (GM Push Button)
  23. stock TJ track bar
  24. 2000 Dakota bumpers, grill, more
  25. round corner tops for 1/2 doors
  26. cj yj soft top
  27. CJ 7 Roll Cage
  28. Car Hauler
  29. 3/4 or 1ton coils
  30. wtb: seat belt
  31. 241 c for 92 chevy pick up
  32. Early CJ-5 frt Fenders ('71 and earlier)
  33. Civil Engineers... Pro Bono?
  34. Dodge cummins
  35. AMC 360 wanted
  36. 4.0 liter motor for 89 Cherokee XJ
  37. 33" tires and rims for Range Rover
  38. hitch for 93 xj
  39. tj fan shroud
  40. Im looking for a NP 205 32 spline 6 bolt
  41. Need a 46re trans
  42. Cragar Soft 8's or D window
  43. Ford Superduty RIms 20 inch or anything that fits
  44. wanted- samurai stock front springs
  45. Dodge 8 lug rims 94 or newer
  46. WTB 12 bolt
  47. Remote control
  48. Rear Bumper w/ Swing Out Tire Carrier
  49. 97 tj stearing box
  50. mickey thompson wheels, chevy 6 lug 15x10
  51. Intermediate CJ5 Passenger Seat Mounting Photo
  52. TJ Fender Flares (Rear Only)
  53. 8ft truck cap
  54. WTT furnace/AC repair for Ford parts
  55. Wtb: a clue and yj parts
  56. TJ soft top brackets
  57. WTB Stock Spare Tire Carrier CJ
  58. Drivers Seat CJ7
  59. wtb 2.5l starter
  60. 33" BFG MT/R's; 15 in., 2 Needed prefer New or Like New
  61. CHEVY or GMC truck
  62. GMC 10 bolt 3:73 rear end
  63. XJ DANA 44 drums
  64. Need Ford E350 15 passenger Van
  65. MSD Rev Limiter Chip
  66. YJ Dana30 or shafts
  67. Tj torque converter
  68. 4.10 Ring/pinion and carrier HP 44
  69. XJ 4.0L Alt. bracket
  70. wanted- geo tracker seats
  71. '94 Caravan transmission
  72. Steering Gear Box 98' TJ
  73. 6 Foot 3 point hitch blade wanted
  74. 93 or older Ford/Dodge 1/2 ton 5 bolt wheels*PLEASE REMOVE AD THANKS*
  75. wtb 2 16" cheap 5x5.5 wheels
  76. wtb 2 used 39.5 x 18" boggers
  77. 32"-33" tires
  78. Corner Gaurds & rocker gaurds for a YJ
  79. WTB 2 33x12.50x15 bfg mt
  80. Ford F250 Driver Seat
  81. Upper Control Arms
  82. tow dolly or car hauler to rent/ borrow
  83. WANTED: Art Carr shifter - TH350
  84. Wanted-WTB Chevy dip stick
  85. Lower Steering Shaft 97 Wrangler
  86. F Head oil filter
  87. Driveshaft lengthening
  88. pro comp wheels, 15x10
  89. Wanted Tig Welder
  90. need quick!! Trans XJ/MJ 4cyl/2.8
  91. zj adjustable track bar or track bar bracket.
  92. 36'' super swampers
  93. YJ Body lift
  94. lift blocks
  95. floor shifter***got one***
  96. toyota wiring guru
  97. TJ front driveshaft - 4.0 + AX15
  98. WTB: 36-38" tires and/or rims 6x5.5
  99. CJ7 Stock Pitman Arm
  100. Looking For Some Stock Tj Front And Rear Bumpers
  101. Topper / Cap for 99-06 short bed full size GM truck
  102. TJ Fenders
  103. Tools!
  104. need a dana60 front axle
  105. 39 to 44 inch tires
  106. 4.0L Shortblock
  107. YJ Half Hard door parts needed...
  108. Coil Spacers
  109. Hard Top and Tires
  110. Someone who can bend 1.25 tube
  111. XJ / MJ Carpet
  112. '87 XJ Interior Needs
  113. 4.88 Gears
  114. tow truck, rollback truck
  115. Xj Axles !!!!!
  116. WTB: TJ Manual Transmission
  117. 4.0 for a Ranger
  118. 2 33x10.5 or 33x12.5 BFG MT's
  119. 31 inch mud tires with 70% plus tread
  120. 4-285/75/R16 Tires
  121. 1990 Chevy Full Size Driver Side Door
  122. Stock tj pitman arm
  123. Tension pully asm.
  124. Shotgun for home protection
  125. need 4.0 for my Jeep
  126. CJ7 Jeep Transmission
  127. WTB single shot .22 rifle
  128. '74 CJ5 Passenger Seat Bracket
  129. xj long arms
  130. D60, 4.10's, Pass drop, KP or Ball Joint, NO Duallys please- Complete
  131. dana 60 open carrier 4.56 up
  132. 35x?x16 Mud Tires AND/OR 8x6.5 wheels
  133. Needed 37x12.5r17 km2
  134. TJ soft top
  135. WTB = WTT Ford Dana 60 SRW 4.10 Front HP
  136. TJ Rear Hook
  137. 95 F150 Short Bed
  138. 9mm Ammo
  139. Radio antenna, WJ
  140. 235/75r15
  141. wtb 35-40s
  142. WTB k5 tailgate access cover
  143. looking for 1999 or newer GM truck
  144. WTB: AEV Jeep TJ Heat Reduction hood
  145. 80's Chevy stearing stabilizer
  146. In Need Of A Tj Hardtop Back Window Desperatly
  147. Steering rack Chevy Tracker.
  148. Auto trans for 2000 dakota 4x4 v-6
  149. WTB: Tires 305/70/16 or 285/75/16
  150. safari top for family cage yj
  151. WTB-Rear bumper w/tire carrier
  152. 4.0 parts
  153. WTB xj performance parts
  154. 4wd actuator
  155. 15x10 black wheels, 5 on 4.5 bp
  156. cheap 4.0 and 4.2 I6
  157. 29" stainless steel brake line....or lines...WANTED
  158. Bracket that holds a track bar on
  159. 15x10 or 15x8 on 5x4.5 black rims
  160. parts cleaning/ hot tank
  161. Axle Needed
  162. H2 wheels and tires
  163. YJ Gas Tank
  164. Axle Needed
  165. 4.88 gears
  166. carpet fixer er
  167. D28 Spindle
  168. 33x12.5x15
  169. YJ: WTB - OEM/Factory Soft Top Hardware
  170. WJ front Dana 30 scrapper
  171. rhino grill
  172. 93 Blazer/Jimmy grill
  173. Utility quad Wanted
  174. Xj front Skid plate
  175. 2.5L motor.. '02 jeep wrangler
  176. WTB: 32-33x10.5x15r tires.
  177. YJ flares and steps
  178. 205 70 15's or 195's
  179. AMC 20 Carrier- 3.08 and up gears
  180. Audiovox PNP2 Sirius radios or accessories.
  181. (4) 16" x 10" or 14" 8lug rims ??_
  182. looking for stock front bumper for tj 1997 -2005
  183. looking for 2001 grand am 3400 engine only.
  184. WARN 8274 parts
  185. NO longer needed! 15x10 5x4.5 rims
  186. Airbox for 03 TJ
  187. Carb/Tires/Tub
  188. TJ rear seat bracket / brackets
  189. sand paddles
  190. 68 chevy 4x4 parts
  191. No longer looking
  192. 205/65R15 tires
  193. wanted H1 rims
  194. ranger fender flares and lift bracket
  195. Wanted TF 999
  196. kayaks
  197. 89 4.2l manual clutch disk 10 spline
  198. 7.3 Powerstroke Injectors
  199. GM spring plates
  200. Dana 44 Front
  201. H2 Wheels and or Tires
  202. Windshield asap
  203. 302 motor
  204. Shift Cable/Linkage
  205. Tires And Wheel For 99 Ford Ranger
  206. 19 inch paddle tire
  207. 14.9x24 backhoe tire needed
  208. 185/75/r14
  209. WANTED (4) 31x10.5x15 MTs
  210. Looking for a 4-6" lift
  211. Cj axle bump stops
  212. cherry picker and engine stand
  213. Farm Tractor
  214. Wanted. TJ Rear Bumper with 2" Receiver
  215. steel ammo box
  216. 95 wrangler front window today
  217. 73-79 Ford Fenders
  218. Childs full face helmet
  219. Tire swing tire(large rim size)
  220. Wanted: 750 cfm Eldelbrok Carb
  221. Long arm suspension kit for 2000 TJ
  222. Slip yoke eliminator kit for 231
  223. wanted cj radiator for V-8
  224. YJ rear hub
  225. tj lift kit around 3" tall
  226. looking for a complete running 454
  227. Ford 9"Rear Dana44 Front
  228. 8 lug trailer axle
  229. cheap 33" spare
  230. 302 intake
  231. Jeep Starter
  232. tj green and tan rear seat
  233. Ruger 10/22
  234. YJ full hard doors
  235. Dodge and Jeep parts wanted
  236. 5th wheel hitch rails
  237. NEED dana 44 rear axle ASAP!!!
  238. some YJ stuff I need...
  239. Gooseneck car trailer 30ft or longer
  240. YJ front bumper
  241. need maual tranny peddle and linkage
  242. 4.0 Drive train wanted for CJy Build
  243. 231J Tail Housing
  244. e4od diesel trans
  245. ax15 trans for a yj
  246. WTB: D30 4.10 R&P and carrier or 4cyl TJ D30
  247. WTB,C.B. antenna mount for an xj
  248. Door Mirrors for TJ
  249. chevy drivetrain
  250. D44 TTB axle shaft
