- Bald Tires Wanted
- Sway bar end links, non-OEM
- Ford wheels (f150)
- Stroker I6 and AX15 for Cherokee
- need a chevy 208 shifter
- xj rear leafs
- Lawnmower Repair Near Rochester Hills
- Ford Manual steering box 79+
- toyota engine
- traxxas emaxx rc truck
- 4 or 5 ) 15x10 5on 4.5 jeep rims
- daily drivable Jeep or 4x4 for under $1000
- Warn Winch Controller
- bronco topper
- T-4 manual trans
- YJ Speedometer
- Riding lawn mower.
- 94 f-150 parts and tires
- DD Car for wife
- Junky rusted rollbars.
- front marker light for 93 Toyota p'up
- Tracker 1.6 16 Valve Sohc Cylinder Head
- 95 4.0 fuel inject wire harness
- landscape mulch
- need hard top and doors
- Rubber brake pedal cover
- joe dirt style footprint gas pedal!
- 1999 ford F-150 -passemger side extended side door
- Jeep CJ-7 Windshield frame
- Air Compressor
- Wanted: 74' tp 79' Wagoneer Narrow Trac D44 front
- tires wanted
- wtb rims!
- Someone to rewire my trailer
- tire balancing
- GM Corp 14 Bolt Spider gears or a GOV Loc
- 4.0L Distributer Needed
- 4.10 R&P for D30
- hitch for xj
- Golf cart
- 3" Lift TJ Coils
- caddy motor parts
- need a spare 38 to 40 inch
- 17 inch rims.
- old lawn mowers
- Full Door Seal
- 14 bolt FF gears
- ISO: hi lift jack
- good tires 35/12.5/17
- WTB Ford 9" w/ 4.10 gears Locker 59" Width
- TJ Rear Output Shaft
- Np205
- Tires 37" - 39.5 for 16.5s
- Trade: generator for springs
- tires
- Gun Safe
- four wheeling spot
- 2.5 liter flexplate and converter
- tilt steering colume
- Shifter for 700r4
- D35, 231
- Hitch for 2004 Liberty
- tj axle shafts
- XJ, commanche , wrangler???
- 4.10 R&P for HP front D44
- 8 in Dodge lift springs
- Need a 5 speed trans for a 89 jeep comanchee Mine wont bolt to a T-case
- WTB Fullsize Pickup
- Dana 60 parts. Ballistic fab high steer (5 bolt), 5.13 gears, detroit locker
- wtb jeep $1500
- Clean Yj frame
- TJ Rear Seat wanted
- 2000 TJ Soft half doors
- Trailer for Riding mower
- Wtb Two 31/10.5/r15's
- WJ trailer hitch
- want to buy 33's
- 17x8 Cragar Soft 8`s or Similar
- Jeep to buy as a DD
- V-Dub parts
- Wanted: BBC headers, flexplate, water pump, dipstick
- Wanted: Grant 15" steering wheel and adapter for Chevy column
- WTB Dana 28 Manual Hubs
- Borrow: Engine lift and/or leveller around Dexter/A2
- rebuildable dirt bike??
- 93-98 Jeep Grand Cherokee Wanted
- Enclosed Trailer
- 79 Cj5 Top Frameless(?)
- TJ K&N filter and air box
- Sterling 10.25
- 5 speed for 94 f-150 mazda m50d-r2
- Jeep YJ A/C Compressor for 4.0l
- 17x8.5-11 5lug 4.5 bolt pat. steel rims!
- need leaf springs xj
- wtb jeep cherokee leaf spring
- 48" bucket or smaller
- M.O.R.E. Bomb Proof Motor Mounts
- Xj Coil Springs
- 3 1/8" dom tube .5 wall
- Jeep CJ Carpet Black
- wtt: wheels, maybe wheels and tires
- TJ Door Surrounds
- Drive shaft
- 90 cherokee for parts or the anti lock brake pump.
- 97+ Cherokee Antenna BASE
- need rear leafs 6 inch and long arm kit for xj
- Pop up camper
- Lift Kit For A 2000 Gmc Seirra 2500
- two cheap 36" tires
- XJ tinted rear glass for hatch
- looking for a jeep
- 4.0 and AW-4
- 3 inch body lift pucks
- 1/4 ton jeep trailer
- WTB '99-'03 7.3L Powerstroke engine *Will also consider '96-'97*
- Wanted to Buy or Rent a Box Blade
- wanted fuel cell
- Axles
- Need some help.
- WTB boat
- WANTED A 37 /12.50 16 JUST 1 blow out on my truck
- Hub for Dodge D60 rear
- trade dana 35 posi for
- trailer storage in the Plymouth/Livonia/Southlyon/Ann arbor area
- XJ Radiator needed
- WANTED cb whips
- 4 or 6 cylinder
- TJ drive plate cover
- Dana 60 carrier
- WTB: Tracker Transmission
- need receiver hitch!!! 99 Dodge 1500
- Pontoon Motor
- looking for new toy...very open mind
- right tail light assemly and lens for samurai
- hp d60 carrier and gears 14b gears
- Chevy lift kit
- 4in lift anyone
- 97 TJ Right Turn Signal Pigtail
- motorcycle frame
- Wheel adapters
- Silverado lift, maybe fullsize blazer lift
- Fiberglass Body for TJ
- Fender Flare
- Front bumper and/or grille 93-98 ZJ
- Wrangler radiator and exhaust
- 4.10 gears for a 8.8
- NEEDED: 2.5L Jeep Engine
- 4" shocks
- tj lift
- rock guards for 97 cherokee 4 door
- Looking for s10, sonoma, ranger or jeep for $1,000 or so
- 6 lug pressed wheel centers for h1
- 96 Tracker 1.6 L Harmonic Balancer
- black tj soft uppers and back window
- wtb: stock jeep rims and tires
- Need Cherokee Fender Flares (00-01)
- 700r4
- k5 blazer driveshafts
- Need XJ fuel tank/pump
- wtb: sm465 steel bellhousing
- Rototilling
- 4.0 motor and aw4 trans
- H2 wheels and 35-37 tires
- Turbo 400 Trans
- 1 36 for 16 or 16.5 rim
- Looking for a Boat
- Kickdown for a 70's = 727 trans Mopar Stuff
- K5 blazer frame
- Wanted: set of 1" wheel spacers
- NOT NEEDED PLEASE REMOVEmodel 20 axle w/ 3.54 gears or just ring and pinion
- 4:10 gears 8.25 and Dana 30
- 14 bolt hub
- needing parts
- a pillar gauge pod for jimmy
- 31" tire for spare
- wanted 95 yj rear seat
- 79 ford filler tube.
- I need a TJ radiator!
- needed chevy 6 bolt aluminum 15" wheels
- moped
- Pool Heater
- Dual diaphragm booster/master assembly for 97+ XJ
- Need 14 Bolt FF 4.56 Gear
- wtb: bogger hauler or axles for a trailer
- 16.5"- 6 lug rims
- Wondering? My custom rig for a TJ/YJ?
- Wanted: NP241C shift linkage
- 255/70/16 or 31" or 32" Radial AT's Or summer tires
- 2000 GMC Rear Bumper & Wheels Wanted
- Garage around K-zoo
- 95 Dodge
- 17" 5 on 4.5 wheels
- 97 TJ transfer case linkage
- AMC 360 Timing Cover
- XJ Header panel trim / Sway bar mount
- tj half doors/or black soft doors
- Please close!!! $4k to spend what u got? really want something bagged!
- looking for sport bikes up to $3k
- s-10 leaf springs
- need 42re transmission
- 75 Jeep commando
- wtb quadzilla frame
- big block chevy
- Dana 44 4.10/4.56 gears
- CJ front 3.5" lift springs
- Need a lawn mower
- Parts for: Yamaha XS1100 Special
- Jeep Fuel Pump
- 1995 cherokee parts!
- bronco gas tank
- 14 bolt hd diff cover
- cherokee chief decals
- cherokee steering box
- trailer
- cj7 or yj project
- Tube Bender
- TJ parts
- Wtb: triton 5.4 or v10 ford motor
- WTB 97 TJ seat covers and a upper drivers window
- 99 F150 parts
- hydo steering
- shocks?
- TJ Parts
- yj bumper
- =GOT ONE= Industrial 2 stage Single Phase 5 -10 HP Compressor
- Drop Brackets, Leaf Packs, Bumpers.
- TJ Front Upper Control Arm
- chevy dana 44
- 14 bolt FF w/ 4.10
- Wtb 35-37" Tires (4)
- Wtb 4 5x4.5 Alum. Rims
- ZJ Rims & Tires
- wtb ax5 trans,spare wheel 5 on 5.5 lug pattern
- ford awd t case for a 98 exloper
- need long side shaft from tj
- lookin to get a truck for $500
- wtt 315/75/16s for a set of 265/75s or 285/75s
- WTB 4.0L Ranger/Explorer motor.
- 15x8 or 15x10 5x4.5 rims or 2" wheel spacers
- Wanted: Clean TJ Frame and Body
- wanted 37 to 40 inch mud tires
- brake lever for my cbr
- cheap tires
- TJ Rubicon or ZJ Springs
- chevy truck box
- washer
- Wanted: Jeep JK or TJ Grill
- cherry picker
- Kawasaki KZ400
- ford 1 ton rear leaf springs
