- P.S. Pump for a 4.2L
- WTB: 1995-1996 XJ 2-door Driver Seat
- small enclosed trailer
- 18 or 19 foot travel trailer
- 31" MT's and 15x8 wheels
- Dana 300 bearings
- ANY rear bumper for a 95 Ram
- cj tailgate hinges
- possibly borrow a trailer/tow dolly
- need hubs for moser axle shafts
- Chevy small spindle
- Drummer Near Kzoo.
- D44 Front Inner Shafts (TJ/Rubi)
- Jeep 4.0 Must run good
- MJ Leafs (4" Lift)
- chevy 8 bolt rims
- cj7 tub
- CJ gas tank
- (2) 5 on 5.5 rims with small tires by friday night
- spare tire rack
- Broken 231 With Internals
- cj drive shafts
- WTB: Dana 35 Rear Axle 3.07
- Stock air intake system for TJ
- Samari Parts
- fuel cell
- Band/musician to play August 5th cookout (Allendale, MI)
- Amc 20
- 92 Chevy 350 Stock Exhaust Manifolds*** still need
- 94 ZJ tranny
- Cherry picker
- blazer s-10 roof rack
- Wanted: Trampoline
- clean xj
- Tranies
- yj 2.5L front driveshaft
- WTB 5 speed car
- Looking for a Utility Quad
- 1993 explorer door
- np208
- Chevy 348/409 BB Stuff
- tj flares
- wtb Chain link fence stuff need 160'
- Welder/Fabricator
- dana 44 flat top nuckle pass side
- late '80s Ford truck parts
- Lift Coils
- diff cover
- MJ Rollbar
- Transfer case needed
- WTB: dirt bike
- Looking for nice car for around 1500 or less
- yj wrangler
- AW4 Neutral Safety Switch
- 95 ZJ needs a LIFT
- stock control arms
- Wooded land, between Milford and Flint...
- 8 bolt rims
- Need asap chevy rear 10 or 12 bolt
- junk car & trucks
- TJ 231 T-case or output shaft
- Job Needed
- AW4 Tranny pan and drain bolt
- TPI computer. 88/89 a plus. Just the computer..
- wanted! `92 Geo Tracker 4 door Parts.
- King Link Pin front end parts (vw)
- Dune buggy, Dirt Bike, Quad, Snow Mobile, Jeep
- Wtb 94 To 01 Dodge Truck Front End/clip
- Xj lift and reciever
- WTB samurai front axle or toyota front axle
- Trans for 91 4 cyl wrangler
- quad or buggy for around $1500
- 16" Tires 245's, 265's ,or 285's - at's or mt's
- 66 f100 ford parts for sale
- Rear Driveshaft and AMC 20 axle/differential
- Wide Trac Amc20 2:73 TruTrac
- scuba stuff
- need 1 procomp xterrain tire
- Towbar for an XJ, or car dolly.
- pair of sway bar links
- MJ E-Brake Lines
- 97 and up TJ soft top hardware
- 15x10 5 on 5.5 rim for spare
- WTB: LCA's and UCA's-XJ
- XJ 4.5" Leaf Pack
- Linoleum Source/Installer
- chevy truck lift kit
- WTB: CB radio
- WTB....Ford Carb
- jeep yj with a 4-banger and 5speed CHEAP
- job
- need a amc 304 or 360 running cheap
- 9mm Ammunition
- 32x11.5-15
- dual barel carb
- Auto steering column ('80-'86 CJ non-tilt)
- Nevermind
- need amc401 man flywheel a.s.a.p
- 4x4 Vehicle Wanted
- Rubi Wheels and tires
- wtb: xr50 pit bike parts
- 33x12.5x15 spare on 5x4.5 rim
- WTB: Windshield CJ7
- cheep s10 2wd short bed
- seatbelt
- Jeep!
- 2-1/2" YJ Springs
- D60 spring perches
- Toyota topper
- dana 30 narrow track axle shafts
- YJ Windshield
- 245/70-17 tire just (1)
- WTB: driver's seat and/or bracket for 2001 XJ
- Need 1 35x12.5x15 spare
- YJ Parts Needed
- 90-95 2 speed 9 blade Taurus fan
- 33" spare
- Wanted, used older tub with "Jeep" tailgate
- windshield glass for a yj
- possible flare trade?
- 350 heads
- Need sm465 and np205 for chevy
- 5-speed manual for '97 TJ
- zj amplifier
- compleate 2.5 ready to drop in and run
- Weird Request
- Wanted Yj Parts
- chevy frnt shaft and 6" kit
- Looking for 97 TJ Running Boards
- reat seat for 05 Tj
- looking for dana 30s or 35s
- 36" Spare
- XJ/MJ doors needed
- 6 Bolt 15x12s rims
- Distributor for 94 yj 4.0 liter
- A/C Compressor 97 Ram
- CJ Steering Box Brace
- 6 lug wheels
- axles
- Side Job
- 2.5 with all rotating assambly.
- WTB right away! TJ stuff: OS spare carrier, 15x8 wagon, quick discos, more
- 34-36 inch tires
- WTB: Golf Car
- One shock boot for my driveshaft.
- Swaybar w/ Disconnects
- Mechanical or Electrical side work
- Wtb: 4.0l I-6
- WTB: 31" MT's and Wheels
- 32 spline NP241 input
- SM465 hydraulic bellhousing
- yj seat belt
- XJ stock radio/cd player
- sbc crank pulley
- dodge durango leaf spring (stock drives rear)
- Rubicon flares in good shape
- xj front double cardon shaft...
- t-176
- Ax-15
- Rubicon Suspension Parts
- 8lug wheels
- Good Used Raditor Jeep Chero 4.0
- 4-6 inch lift for 73-87
- TJ Sway Bar Links Front
- 904 trans
- 1998 wrangler owners manual
- Astro Van inner axle shafts
- 1991 XJ Exhaust, Cat back and 8.25 cover
- hard top parts
- TJ Windjammer
- dual sport motorcycle
- no longer need
- YJ hard top
- the male end of the 4.0 oil pressure sending unit
- Fuel Cell
- YJ/CJ bikini top
- Wanted Rubicon Wheels
- sailboat
- Needed ASAP Stock TJ swaybar links
- Need two 31" BFG AT
- Tj dana 44 rear axle assembly.
- XJ/TJ adj. trackbar, fixed/adj. control arms
- power steering setup
- Full size bronco, Good-Great condition, Road worthy..
- '76-'86 Soft Doors WANTED
- 35/34 inch tires
- cheep '71 bronco
- wanted Dodge v 10 truck parts
- 90 YJ Top
- Steering Wheel WANTED for my CJ
- Jeep cj5 / cj7
- YJ Safari Bikini Top
- YJ Driver's Seat Slider
- YJ Driver's Window
- Spider Gears for Ford 8.8
- Wanted 97 wrangler body mounting bolts
- CRT monitor
- NP205 for chevy...
- 98 cherokee header panel
- used version picture phone
- Wanted: Lower unit for 25-35 hp Evinrude or Johnson outboard motor
- Chevy 10 bolt or Dana 44 front axle
- wtb chevy case
- WTB 2.5L fan shroud.... 91yj
- Friend Wants a Jeep
- small V8 for chevy and a transmition.
- Spare 34/35
- Waterproof Seat Covers (or seats)
- Bronco II Lift Kit
- 351!!
- YJ frame (or two)
- i neeeeeeeeeed
- I Need Jeep Wrangler Seats!!!!
- 37-38 to fit a 16.5 rim or 16 rim
- wanted yj front fenders
- 33s
- 3/4 ton Chevy caliper brackets
- Tj Pass. Side Front Seatbelt
- Front lower control arms
- to borrow tow dollie
- 15x8 xj/tj/yj rim steelie black
- car dolly to borrow/rent
- Rubber boot for Hydr. clutch slave cylinder
- CJ power steering box brace
- m.j. comanche cab and bed
- dana 44 rear or gm 12 bolt
- TJ 4"+ Quick Discos ASAP!
- 37-38 15 inch rim
- YJ tub
- XJ hitch
- Stock TJ Air Box!
- orbital steering valve
- roll cages or bars
- Nascar Tickets
- XJ gas tank for a 2000 xj
- tj flare signal lense
- tj half doors/ safari doors
- Stock TJ springs
- 225/70R16 Goodyear Wrangler HPs
- YJ powersteering box
- 97 or newer S-10 wanted
- 88 XJ Ball joints
- 1999 to 2004 Jeep Grand Cherokee 4.0 Engine
- Transfer case drop
- Stock CJ7 Driveshaft
- Broken down riding lawnmower/yard tractor
- amc 20 rear end
- CD player
- Shifter kit for TH350
- Now it is easy to leave iTrader feedback!
