Wanted [Archive] - Page 59 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. 1986 Chevy 4x4!! Need a ball and socket or shifter arm?
  2. 2-16" rims with 5 on 5.5 bot pattern
  3. 17" x 10" super duty rims NO LONGER NEEDED
  4. WTB: F150 Coil Springs and Shocks
  5. 78-79 ford d44 outer axle shafts
  6. tires for 16" rims
  7. 2000 F250 Bed
  8. Power steering stuff for 170ci Ford
  9. Body lift
  10. 44 spindles
  11. wtb 10' dump box
  12. yj spice soft top rear window
  13. TJ Front DS
  14. s 10 rims
  15. WTB: 302 Intake
  16. 1 42 for a spare
  17. rims
  18. need 2 35's
  19. i 38 16.5 rim for spare
  20. scrambler tub
  21. Dana 44 30 spline pass side rear axle shaft
  22. Wanted speakers (for cj7)
  23. your used/worn out super duty unit bearings
  24. JK Rubi Tires
  25. Good Painter
  26. Electric oven
  27. 16-18' Car Hauler
  28. Schakle Bracket
  29. TJ parts
  30. 6 lug wheel spaces
  31. 31x10.50-15 all terrains
  32. 15x10 5x4.75
  33. I Need Birfield Joint Before This Weekend
  34. Machinist
  35. wanting jeep xj
  36. 15" wagon wheels for xj
  37. cj7 cab cover
  38. .75-1" Lift pucks for a zj.
  39. explorer 8.8
  40. tires and wheels
  41. NEED dana 44 hd 8 lug & 14blt corp w/4:10
  42. WANTED!! 15x12 5x5.5 rims
  43. wtb bfg a/t's
  44. wanted 79 f150 parts
  45. Dually wheels (chevy)
  46. 700r4 trans
  47. WTB: Engine Hoist
  48. need a wench
  49. Stock toyota mini truck steering arms
  50. 2.4l grand am engine 1996
  51. Turbo 350 (Core)
  52. Good Running 350
  53. tj Dual Roll Bar Grab Handle
  54. sand tires for 15 in rim
  55. Redwing tix
  56. Wanted 79 ford f150 parts
  57. winch
  58. dirt bike
  59. 460
  60. Duramax
  61. set of (4) 15x8 black steel 5x5.5" wheels.
  62. Ammo
  63. Whatcha got?
  64. Wanted headlight for a 96 f150
  65. XJ front clip - limited/classic
  66. Wanted: TJ Door Surrounds
  67. WTB Montero shit
  68. D44 and 9 inch shafts
  69. d44 4.10s
  70. CB radio
  71. Center caps
  72. 93 yj wiring harness
  73. Tint Hookup around Ann Arbor
  74. quadrajet
  75. 1997 explorer t case
  76. amc v8 engine mounds for cj
  77. Np241c
  78. Wtb 31" or 32" Mt
  79. WTB: Jeep TJ Upper Door Frames
  80. where to get snap rings for birfields
  81. Need 1.5"-2" XJ Wheel Spacers
  82. 31's
  83. wanted cj 5x5.5 wheel spacers
  84. Wanted Dexter wheel
  85. Mobile Home Axle Tires/Rim
  86. lift kit for '95 tahoe
  87. xj front bumper
  88. axles dana 44 60
  89. GM 60 and 14bolt gears
  90. wanted XJ
  91. Pallets/Good burning wood in macomb county
  92. 04-07 Galaxy Silver Gran Prix Trunk
  93. Ford Dana 44 Alloy shaft(s)
  94. XJ Steel wheel
  95. looking for a driveshaft
  96. WJ 2" Budget Boost
  97. ranger rear end
  98. need a winch
  99. Dirt Bike Wanted
  100. I need a cheap car
  101. Valve cover for 89 YJ with 2.5L
  102. Looking to trade.....
  103. Dana 44 front 9in Rear for my xj
  104. xj headlight brezel
  105. Electric Fan
  106. ZJ trackbar
  107. Loking For A CJ
  108. WTB Dana 44 front and rear for CJ7
  109. Grill Guard for 01 Grand Cherokee
  110. A Couple Cheap 35" Mud Tires,
  111. WTT: Full steel doors for half doors
  112. 454 Wanted
  113. Need some parts for a 96 Cherokee
  114. np 231 front output yoke
  115. 80 style chevy truck
  116. KIds wagon
  117. TJ dash interior fan/heat/ac control
  118. WTB a TJ Hitch
  119. Dana 30 High Pinion Non-Disco XJ/MJ
  120. cj rear underseat drawer/or something to raise rear seat by 3-4"?
  121. wanted dana 20 t-case
  122. TJ Gas Tank
  123. ford front end parts
  124. 8.8 Parts!
  125. WTB 318 motor dodge
  126. 225/60 R16(or close) 5/4.5 Wheels and/or Tires
  127. yj 350 swap stuff
  128. used 14" car tires
  129. Honda ATC70
  130. Stock cherokee bumpers and mounts
  131. Universal Floor Shifter For A Ford Truck
  132. Jeeps SRT8 rims
  133. wtb a winch
  134. welder and sheet metal
  135. Looking for any dana 30 3:73 axle
  136. Dana 60 Rear Swaybar
  137. 12" subs
  138. Tires 33X12.50 15's
  139. AMC 360 Oil Pan
  140. rear 14 bolt with locker
  141. wanted: NP231C
  142. Stock AMC 360 Valve Covers
  143. Model A (coupe, or sedan)
  144. c5 flywheel
  145. train horn or some sort of big air horn
  146. steering column for a 90 YJ
  147. WANTED 97-01 xj oem flares
  148. Wanted: Weber carb for 4.2 YJ, and new rear extended bump stops
  149. SBC Mallory or MSD distibutor
  150. TJ Flares
  151. Lock Out Hubs Dana 44
  152. 4.10 dana 28 or 35 TTB
  153. Wanted 305/70/16 or 33X12.50x15
  154. 73-79 f150 truck bed
  155. WTB 15x8 5x4.5 Steel Wheels (Bought)
  156. CJ ALT and RADIATOR
  157. 15x12 5 on 4.5 rims
  158. Fishing Boat
  159. zj body panels
  160. 36-37 in tires
  161. 16.5 beadlocks
  162. *Early Bronco Steering Gear Box*
  163. Early Bronco Parts
  164. Need front flywheel cover for CJ
  165. 6 lug gm wheels tires
  166. 1310 dana 60 yoke
  167. XJ stock sway bar links.
  168. SM465 w/ Bellhousing, Jeep T15 w/ D20.
  169. Looking for 4:10 on 420
  170. geo tracker grill
  171. Misc CJ INTERIOR PARTS
  172. I need a yj driveshaft close to pinckney/hell
  173. Reputable place for Tranny Rebuild
  174. Bronco2 spare tire carrier
  175. 2007 - 2008 JK Unlimited X Low Miles
  176. 78/79 bronco fan shroud
  177. 35" thornturds
  178. TJ rear seat belt
  179. wanted 90s ifs chevy lift!
  180. WTBorrow: Motorcycle Trailer
  181. windshield 99 Tj
  182. Dana 44 for ZJ
  183. xj fans
  184. Pine trees and boulders
  185. 15x8 Aluminum rims
  186. xj fan shroud
  187. Wagoneer Shackle Mount
  188. Misc Jeep Parts
  189. f250 master cylinder w/ booster
  190. front springs/ shocks
  191. chevy truck engine
  192. power steering box
  193. turbo
  194. F150 tail lights and bumper
  195. NEED 1350 Dana 60 Yoke and 1410 yokes
  196. lift kit wanted
  197. Need some adjustable control arms!
  198. Looking for 37, 38, 38.5 inch tires for a 16 inch rim
  199. Banks with PDA
  200. rear seat for cj
  201. WTB: 97-01 XJ Windsheild washer fluid reservoir
  202. WANTED!! tool box
  203. 99 durango front lower bumper
  204. Tonnaue Cover
  205. 4x8 Steel Table Needed.
  206. I need the Rear spring hangers from a YJ
  207. yj windshield frame header
  208. th350
  209. TJ factory rear hook
  210. WTB: CV Shaft for 1998 Chevy 2500 HD
  211. 2000 s10 2.2 non flex fuel ecm
  212. Ford straigt 6 motor mount brackets - frame side
  213. 93 Jimmy 2"-3" Torsion Keys, 31s or 33s
  214. family style cage
  215. np205 1350 yokes
  216. generator close to downriver
  217. YJ windshield frame + glass
  218. Yj 1.5" Lift Springs
  219. NEED 2.5L header for YJ
  220. 36s or bigger
  221. Barter: work on my truck - I'll help make your home more Energy Efficient!
  222. turck paint sponsor
  223. WTB 4.0L YJ 2 wire clip that goes into coil from PCM
  224. low back seat
  225. TJ 4.0L for a 2001
  226. Stub shaft, chevy
  227. Swing out tire carrier for CJ
  228. 8' tonneau cover
  229. WTB engine hoist
  230. Need Two 33/12.50/15 Mud Kings
  231. WTB: 33x12.50R15 tires, IN
  232. Bumper
  233. Scrambler tub
  234. Inner wagoneer d44 shaft
  235. WTB in IL: Power steering reservoir for a 2.5 XJ/MJ
  236. not needed 15x10 5 on 5.5 bead locks please remove
  237. 1993 Grand cherokee computer needed
  238. 98 XJ Electric Cooling Fan
  239. radiator for jeep cj
  240. Tj for a Tj
  241. wtb xj parts list inside
  242. 6 lug bead locks
  243. YJ Head Lamp Switch
  244. WTB wheels, tires and more
  245. Ax15 skid plate bracket
  246. 33" Walk behind lawn mower
  247. Lockrite for D35. Broken or good one.
  248. Need some 33" Tires
  249. 15x10 5 on 5.5 pattern wheels
  250. Wheelbarrow Wanted
