- Looking for Ammo
- T-Case Skid Plate
- 90 XJ Mirror
- 2000 dodge neon 4 door body-parts
- Gas Tank Sending Unit for '73 CJ5
- Motorcycle Lift/table
- 2" XJ shackles
- 1999 cherokee 4.0 exhaust mani needed
- need a small 5 hp engine
- Black 80's CJ factory console with lock.
- Pass. Drop Wagoneer Dana 44 axles
- anyone have a timing light?
- XJ Bumpers
- s10 blazer front ds
- T5 trans for my 87 5.slow mustang
- drop down tail gate for jeep wrangler
- auto trans 2.4l 98 eclipse
- 78/79 ford f150 4x4 frame
- YJ Tub
- Project/Parts Jeep - CJ, YJ....
- 6" FORD Front end TTB Lift Parts
- Need AX15
- dodge 2500 power wagon axles
- manual lockouts for dana 60
- pull behind lawn sweeper
- WTB 44's and 8 lug rims...
- Ranger Windshield and 14" Tire
- ZJ headlights, others
- 97 GMC suburban running board end cap
- old ram 250 springs
- locking hubs for explorer dana 35
- Dash Parts
- 350 engine and trans
- need parts for a 93 blazer
- Ranger gas sending unit
- Full cord of oak or hickory firewood.
- Stock GM Dana 60 Tie Rod
- RBV 6" Lift Coils
- cheap complete sbc
- Locker dana 44
- 15x12 5 on 5.5 steel wheels
- 9" spool, 33-35 spline
- 92+ Cherokee Radiator...
- yj 30 housing?
- muscle car
- 1- p235/75r15 spare
- reliable vehicle
- Wanted: Rear Axle for 1992 XJ Cherokee - Found Delete
- windsheld frame
- 700r4 trans 4x4 with adapter
- Wanted broken X-BOX 360
- Ford Plow Truck (((soon)))
- 93' Xj T-case
- need to borrow a plasma cutter
- 245-75 x 16" Rim and Tire - need for spare
- AC/DC tickets for the 11/5 show at the palace
- 33x12.50 15" tires
- Log splitter to Borrow Fenton Area
- cj D30 spindle
- Jeep CV FOUND DELETE
- Still need ax15 and np 231 or something ???
- Wanted CJ tilt steering column (FOUND)
- Axles wanted
- 2.5L for a 99 tj.
- OEM Dodge 2500 hemi exhaust
- Wanted T.V.
- plate that goes between AMC engine and trans(FOUND)
- need a steering column for 95 yj
- 1994 ram 1500 trans found
- Np231
- 98XJ steering column
- 97 up dodge ram Y-pipe and cat for V8 magnum motor
- winter vehicle
- 1 Piece AMC 20 WT axles **no longer need**
- XJ tow hitch
- 3500 stall converter for a 400 turbo
- Off Road Lights
- gas tank & windsheld needed for 87 jeep
- 1-1/4" Heims and Bushings
- Construction! Outside shed.
- Complete CJ 7 dash *FOUND*
- 1990 Firebird headliner and spoiler
- Explorer, Ranger, bronco II Grill/Brush Guard
- 16x10 Wheels 5 on 5.5 Needed!!!!!!!
- ford half ton axles.
- adiator for 1985 Chevy K10 w/ 350
- 429-460 ford heads
- soft top yj
- dana 60 spider gears
- Motorola Razor battery
- Wanted: Rear Axle for 95 Chevy PU
- YJ hard top, hard 1/2's or wholes
- 8.8 explorer axle gears/locker
- TJ Parts, hood, grill, windsheild frame
- ram 250 springs needed
- cheep running chevy 350
- jeep power steering pump
- parts or parts truck 91 ford
- Need 14" Tires
- looking for FSJ parts jeeps, Jeep Cherokee chief
- 97-01 Cherokee
- Sye
- Need NP246
- Fender Flares
- CJ locking hub part needed
- weight bench
- air horns
- Rear Axle w/4.56 or 4.88 gears
- H1 double beadlocks
- 4 cyl. flat head engine
- Ford 3.8 liter V6
- Need Asap! Under Dash Wiring Harness For 88-91 Full Size Blazer !
- Jeep yj/ tj wire harness and computer for a 97 4.0 liter
- Polaris Ranger or Rhino
- REALLY, REALLY LARGE TAP - Roch Hills
- YJ SBC Swap Radiator
- Ford Front HP Dana44
- 15" 8 on 6 1/2 wheels
- dana 60 locker and gears
- stair climber or other leg exorcise equip...
- Snorkel for YJ and 35's
- Old, Rusty, Broken, Shitty Chainsaw near Kalamazoo
- 16X10 8 lug wheels
- 36-38.5 tires and rims 8 lugs 16" rims
- need XJ stuff
- Turbo 400 trans to dana 300 adapter found
- np 233 transfer case electric motor Working or broken
- np205 fixed yoke
- Stained Glass / Tools etc.
- old snow plows
- western snow plow pump or plow
- electric oven/stove
- Vehicle Battery for my XJ
- FOUND Need Right Taillight for 1999 XJ
- fender well headers
- ornothopter
- 4 link parts
- Need Machine Work Done.
- looking to trade
- yj besttop frame
- 95 Chevy 3/4 ton rear leaf springs
- Wanted: DD-able, cheap 4x4 pickup
- Need Parts For 1992-96 Ford F350
- 99 ranger d-shaft
- cheap or free stock or drop waggy pitman arm
- Locker for an 8.25
- minifridge
- Spindles for F-150 hubs on a D44
- WTB: Parts for ZJ
- Need Explorer 4.0L 5 Speed Transmission
- 3" xj coils
- tj 4.0 radiator
- jeep cheeroke
- lookin for tranny
- Samurai Driveshaft Flange
- side shaft lawn mower engine
- 4x4 f-250 frame
- i need a jeep for under 1000$$$
- 3.5" -4.5" xj leaf springs
- 93 xj turn signals
- shih tzu or other small breed
- LS1 or LQ9(6.0) motor and trans
- 6.5" XJ Springs
- '96 xj gas tank
- wood/pallets
- 1989 XJ: Rust Free Rear Floor Pan Metal
- garage doors
- XJ coil isolators or coil spacers
- ext cab silverado 6'5" cap or fiberglass tonneau
- two 33x12.50x15 tires
- TJ soft top skin Black please
- 31" All Terrain for spare
- yj power steering
- j10 axles
- TJ Dana 30 Front
- locker for 8.8
- TJ black soft uppers and side mirrors
- 99 suburban T-case
- Vintage fridge
- wtb: Big Block drivetrain
- 36"-37" Tires and or 5-5.5 Wheels
- power steering pump. 91 cherokee
- yj brake pedal and windshield frame
- 5x114.3 rims for a nissan
- Litle Tykes, Power Wheels
- Tj Dana 30 3.73 Gears No Abs
- Tj Front Clip Needed
- WTT 32x11.5 MT's for AT's
- 8.8 open carrier
- xj upper control arms
- ALt and Starter for 4.0 XJ
- hp dana 44 and 9 inch gears...
- 31x10.5x15 at or mt
- Need Vortec 350
- wtb: nice cj7
- 8 lug 17" rims and tires
- EB long side d44 shaft
- 77 f-150 steering dana 44
- Need 14" Tires or 15" Wheel/Tires for Ranger
- 4 or 5 40" or 42" tires
- XJ Stereo and 5 on 4.5 Wheels
- 2000 arctic cat 600 zrt stock exhaust can
- delete 87 ranger stx 4x4 rear axle
- 700r4
- WTB Stock Spare Tire Brkt off Wrangler
- 95 blazer leaf springs
- trans for a yj
- Random Stuff Needed!!!!!!.
- 87-93 mustang body parts.
- Looking for VW Paddle Tires and Rims
- YJ tub section from Rollbar back or solid scrambler tub
- 17x8 5x5.5bp rims
- Rebuild 90 2.5
- 4.0L starter
- 15x8 or 10s
- ACME Top CJ5
- 258 alum. valve cover for 1978ish CJ7?
- D30 axle housing
- dana 30 and ford 8.8 gears
- Ford 8.8 Open Carrier
- needed 33in tire and rim for spare
- Dana 35 Warn Manual Hub Spindle Kit
- bfg at 31/10.50/r15
- 33 10.5 15
- Wanted: Somebody to install Superlift F.I.T. Kit on 00 Silverado
- Broken or cheap np 231c
- Hi Pinion Dana 44 4.56 Gears
- WTB 35x12.5x15
- xj adjustable trackbar
- Pleasse delete found one thanks Bob
- WTB: 35's for 16" wheels
- WTB Jeep gas tank
- TJ soft uppers - black
- Looking for 8 lug wheels on all terrains or mud terrains
- 1" lift shackles for cj7
- WTB Turbo 400 for chevy pickup 4x4
- want to trade (5) 33s plus cash for 36+ tires
- Scroll saw
- 07 Jk Stock Rear Bumper 4 Door
- hpd44 and 9" gears
- 39.5-42 iroks or 38-42 tsl
- tj hardtop for atleast 600 bucks or a rear window for softtop
- WTB Mud Truck
- dana 30
- Wtb (1) 265-70x16 Bfg At/ta/ko
- WTB set of 4 265/75/16 or 285/16
- Radiator Grand Waggy Needed
- 6 lug rollers
- 15x35x15 super swamper tsl
- Tj
