Wanted [Archive] - Page 50 - Great Lakes 4x4. The largest offroad forum in the Midwest
  1. Dana 60 rear axle shafts
  2. Tj: 03 And Up Rear Seat / R.h Mirror
  3. Full Size Bronco Driveshaft
  4. CJ7 doors...
  5. Looking for a way to get ahold of (bigbchevy)
  6. 16" 5x4.5 wheels any cheap
  7. CJ7 Steering gear box
  8. CJ7 fender flares
  9. 17 Beadlock Rims, Nonsteel
  10. Full Roll Cage for CJ5
  11. snow plow 88-99 chevy truck
  12. Cap For Fullsize Chevy
  13. Scout II pitman arm...
  14. old 2wd chevy truck thats clean
  15. XJ hitch
  16. 89 ish S10 Std Cab (just the cab.. or whole truck)
  17. ring and pinion
  18. Snowmobile Parts
  19. 2wd standard or extend cab s10 or ranger 2wd.
  20. 110 welder
  21. 14' V Bottom alum boat
  22. 245/75/16 M/t's
  23. Dana 60 yolk 1310
  24. 98 s10 frame
  25. Need 351/400 modified bellhousing for 4 speed trans
  26. 1990 ford ranger 7" lift want to trade
  27. Wanted briggs&Statton Starter
  28. Wanted: Dodge 3/4 - 1 ton springs
  29. dana 30 stub shaft
  30. Land Rover/Range Rover bottle jack
  31. zr2 front axle
  32. bronco 2 parts
  33. 37's for 94' tracker
  34. 97+ cherokee (xj) blower motor resistor
  35. Small snow plow
  36. my buddys xj got stolen so he needs a new DD..
  37. 2" body lift
  38. i need tires?/ waterford mi.
  39. Complete 208 T-case or long 23 spline input shaft for 231J
  40. trade 2 front 60's 2 rear 70's for Rockwells
  41. 22re Ecu
  42. WTB 10 bolt Chevy gears for a chevelle
  43. Wanted: Blazer, Bronco, RamCharger
  44. hitch for cj5
  45. 4x4 rig
  46. Jeep TJ wheels and tires
  47. 350 sbc
  48. wanted: step bars for 93 GMC extended cab
  49. Ford Front Dana 60
  50. xj 4.5 rear leaf springs.
  51. WJ with V8 and Quadratec Front Driveshaft
  52. WTB Mickey Thompson Baja Claw Tires
  53. 98 ZJ Parts: Infinity speakers, drivers side door panel
  54. np231j transfer case
  55. good running WJ 4.0 99-04
  56. Stock Tires
  57. h2 rims and tires
  58. wanted
  59. bw 13-56
  60. 97 f350 4x4 e4od
  61. Looking for chevy SAS swap parts
  62. snow plow lights
  63. 4.0L for a 2000 WJ
  64. looking for trans for 88 chevy 4x4
  65. any plumbers nearby?
  66. NEED 700r4 for 92 Chevy 2wd
  67. yj radiator w. mich
  68. 4x4 DD updated
  69. Truck Cab
  70. Need 4.0l motor for my 94 ranger
  71. Street Tires
  72. ford dana 60 kingpin passenger side knuckle
  73. 4 325/60-18 all terrains
  74. lifted 4x4
  75. Coilovers
  76. TJ catalytic converter
  77. '00 Xterra leaf springs n shackles
  78. plow truck wanted
  79. Full Floater Dana 60 Spool
  80. Wanted 4-35 12:50 15 ( OR 16) (i can also go up to 38's) mud or allterrain tires.
  81. 1987 Ramcharger trade??
  82. looking for a 4.3 Vortec engine/ Driveline
  83. Ranger sidemarker and trim
  84. need spare tire 35/12:50 15
  85. wanted 38.5 ground hawg for spare
  86. Lift for 84 toyota pickup
  87. best top soft top rear window
  88. 4.10s for an 8.25
  89. Garage/hand pulling a trans (TC)
  90. looking for enclosed trailer >sleds<
  91. 8.8 with discs
  92. 285/75-16 or 305/70-16
  93. 5th wheel hitch
  94. 8 FT Chevy Truck Cap
  95. 302 brackets
  96. 97-03 Ford F 150 rims and tires
  97. Discount Code
  98. Wanted Corn Burner
  99. Passenger Drop NP205 Fixed Yoke
  100. cj windshield frame complete 1976+
  101. beater XJ or..
  102. ford starter
  103. Wanted shifter for NP 203
  104. room mate wanted
  105. Need Tires!!!
  106. 92-96 Dakota lower valance/air dam...
  107. CJ/YJ door hinge
  108. need some 33/12.50/ 15's
  109. Front driveshaft
  110. Programmer for Dodge 5.9l gas
  111. good used optima redtop
  112. 235/70/15 or 235/75/15 in. tires/wheels
  113. LTB HP44 for TJ
  114. Wtb Jeep Tj 03-06 Parts / Accessories
  115. 12 gauge pump shot gun
  116. Model 20 Rear End WANTED
  117. $$Electrical work$$ Earn Christmas cash!!
  118. 4l60e
  119. Electric fan
  120. looking to by some Ice Fishing stuff for cheap if anyone has any......
  121. Need trans install job paying CASH
  122. 35 spline lockouts or drive flanges
  123. 1995 Grand cherokee hitch
  124. i need 265/75/16
  125. snowthrower needed.
  126. WTB: TJ Steering box
  127. 1 15" 5x5.5 bp wheel
  128. YJ Air Box
  129. Looking for a SYE for NP231
  130. xj tube bumpers
  131. WTB 17" wheels 5x4.5
  132. dana 30 locker
  133. d44 diff cover
  134. TJ Built and ready to get F-ed Up
  135. XJ lift Minimum 6"
  136. WTT Electronic 231 for manual 231
  137. All I want for Christmas is a NV 3500
  138. looking for a ba 105 for cherokee
  139. 110 Welder
  140. trolling motor
  141. Looking for a 10/22
  142. Used Rower
  143. divorced NP 205 wanted
  144. 4.0 Hp
  145. 5x4.5 soft 8's or d-solts
  146. xbox 360 wireless controller
  147. wtb 89 up cutlass
  148. dodge ram front bumper
  149. Transfer Case NEEDED ASAP
  150. Stock Upper Control Arm for 90's XJ or TJ
  151. 35" Spare Tire
  152. looking for dana60 and d70 spring plates
  153. 81 cj-7 soft top HARDWARE
  154. wtb-52" chevy springs
  155. Hey Machinists: Need a little help
  156. 1.3l sami engine
  157. 17" 33 to 35" tires
  158. Hockey Equipment
  159. th350 to jeep 231 adapter needed.
  160. snow plow
  161. Beadlocks 5 on 5.5
  162. wtb 4r44e from a ranger.
  163. 2001 mopar
  164. Swapping Air into TJ need some wiring
  165. CJ front fender flares
  166. Vehicle to rent/borrow for a week or so
  167. WTB Low Milage 4.0
  168. d44 short shaft needed asap
  169. cobra 75wxst The handheld model
  170. to trade hard tops. TJ
  171. np 231 for 01 xj
  172. looking 4 cheap plowtruck
  173. auto trans for 86 bronco
  174. superlift front driveshaft
  175. Ford shifting Linkage
  176. need 8 lug chevy brake parts
  177. WANTED: Beater Ford 4x4 Diesel under $1500
  178. front track bar for WJ
  179. Gears
  180. 17" wheels for cherokee 5x4.5
  181. lightweight enclosed trailer to hold 2 or 3 quads
  182. 8-lug Wheel Spacers
  183. WTB 6 cyl TJ Frame
  184. 1993 F150 steering wheel
  185. Xj ABS stub shafts
  186. Looking for some 33-35" Tires
  187. 1995 or newer snowmobile
  188. wanted zr2 s10 or 4x4 sonoma
  189. T5 trans for my 87 5.0 mustang
  190. need track/kick parts
  191. Wanted Steel Wheels 15x8 5 on 4.5 bolt 3.75-4"
  192. ***remove***2 33-12.5 15 tsl boggers
  193. pistol.
  194. Adult Hockey Team needing players?
  195. looking for an sks
  196. (2) 30x9.5x15 BFG A/T.
  197. wanted yj fender
  198. 07 wrangler hard top
  199. Bronco 170 cu. in. inline 6 pulleys
  200. 4.10 or 4.56, ratio axles for a TJ, front and rear needed.
  201. TJ lift parts? have anything
  202. Snow Plow For a Church...
  203. 351w headers
  204. looking for toyota
  205. Clarkston area mechanic side job
  206. Half Doors Upper
  207. Dana 300 adaptor
  208. Tj winch mount plate
  209. 97'ski doo formula torque specs
  210. 2 old man emu shocks, tj front
  211. Wii Sports
  212. YJ Frame
  213. Xj Rear Axle
  214. 94 zj dana 44 rear driverside axle shaft
  215. XJ off road bumpers and rear wiper
  216. snow plow
  217. wj track bar
  218. Recentering H1 Wheels
  219. Toyota 22re Parts
  220. flame paint job
  221. CB Radio
  222. 95 yj driver's side mirror.
  223. amc 360 headers wanted
  224. Ranger/Explorer/Bronco II 6" Lift Brackets
  225. Rockwell 20" 6 bolt rims wanted
  226. wtt a 95 polaris xcr 600 triple for a ENCLOSED TRAILER 6X10
  227. 77 f150 d44 housing
  228. 85 Blazer tail gate
  229. Stock rear XJ shackles
  230. 88-2000 1 ton truck springs
  231. 8 lug rollers
  232. TJ Alternator Mount Bracket
  233. s10 blazer trans and t-case
  234. NEED ASAP Front Diff
  235. Military Tires 14.00x20 or 16.00x20
  236. Cherokee roof rack
  237. 4x4 700r4
  238. xj lift kit
  239. xj front extended bump stops
  240. Drivers Side Fender for '89 YJ
  241. th350 to dana 300 adapter
  242. Trade 06 Club Car Lifted Gas Power
  243. YJ Frame/Tub/ or Rolling Chassis
  244. winch
  245. WTB Bronco2 cargo cover
  246. Wanted headlights/parking light/signals 1992 chevy fullsize
  247. at&t phone w/ sim card
  248. steering arms
  249. Looking to trade a brand new 32x11.5R-15 BFG MT for a newish 30x9.5R-15 BFG AT
  250. set of 16" 5x5.5 rims
