- Looking for steel wheels, 15x10, 5x4.5 BP ANY CONDITION
- Looking for stock YJ front bumpers
- 15" Rims for a cherokee
- Air Filter
- 15" steel wheels - 5 on 5.5 by 10
- Need Gas Tank, Send. Unit for 93 Suburban
- Ring and pinion install
- 73-87 chevy fleetside box
- wanted t18
- yj frame
- ford 400 parts
- Winch Controller - E12000 Milemarker
- TJ D35 4.10 complete
- eagle
- long shot 17 inch rim 5x5.5 cheap/spare
- 1997+ XJ AC Compressor. Southwest side of MI. By Sat. FOUND!!!!
- 87ish toyota box
- TJ half doors
- blazer driveshaft needed
- Wanted: 63" 88-98 Chevy leaf springs... *FOUND*
- 17 tire
- uniden 510xl
- (GONE)Trade My T-Maxx For Your Tires
- WTB: Car Hauler Trailer
- divorced np205
- 2wd th350
- D44/D60 cj7
- Utility trailer
- ECU and PCM 91 YJ
- ramcharger hard top
- cj-7 parts
- Ranger overdrive box
- CJ7 Soft Doors (black)
- Need good gas mileage car
- transmission control unit needed
- need dana 30 with 3.55
- ford explorer 8.8" 96-or newer
- microsoft power point disk
- Sammy transmission
- 2003-2005 Dodge 2500 4x4
- Dubs!
- WTB: 15x8s or 7s
- WTB: Jeep 4.0L
- WTB: YJ Soft Top Parts
- WANTED: Dead or Alive
- Racing Kart and some 32"
- Need 1974 CJ5 3 or 4 spd. 258 bh
- CADDY 472 or 500
- cheap leafpacks - yj S-10 dakota ~40-45"
- Exploder seats
- 1983-1992 EXT. Cab Long Bed Ranger
- WTT: Built Chevy for Mid size
- Power Steering Gearbox
- 99 ranger 4x4 switch and trim
- early bronco front 44?
- Door Linkage, striker plate, handles
- *****wanted: Yfz450 *****
- frame
- Cheap CD Player and 6x9's
- 73-87 Chevy DRIVER or both Doors WITHOUT POWER WINDOWS
- 15'' 5 on 4.5 steel wheels
- someone on the s or sw side that does paint and bodywork
- Wtb 31's Or 32's
- 4 to 1 transfer case!!!!
- 94 XJ steering gear box
- back to building 4link rear of tj need rod ends
- Dyno testing
- 4:56 gears for 98 chevy 10 bolt
- 15x7 or 8 5x4.5 Wheels (FOUND)
- gears and parts for dana 44 and 9 inch
- 4 TJ Rims for Winter Tires!
- *DELETE* Torque Wrench (in./lbs. )
- 38-40 inch MT for 16 inch wheel.
- Stock F350 Rims
- need a tj hard top n full doors
- steering box for a tj
- 1350 Driveshaft
- Tj Full Hard Doors
- Need a lid for a 78 CJ5
- astro and safari van hydro booster
- 35x12.50x15's
- full doors TJ BLUE
- wanted 88-96 chevy extra cab p.u.
- yj wanted
- quad or single cab short box.
- YJ soft top wanted
- Wanted: Volkswagen 1600
- club car parts needed
- 1997 ZJ limited grill
- looking for cheap cd player (FOUND)
- Dodge 1/2 ton Pitman, ZR2 Leafs
- need 98' TJ soft top
- Need 245/75R16 Tires
- Cummins Tow rig
- 99 tj soft top plastic sides.
- 98 cherokee front bumber
- Boat wanted for fishing and cruising
- XJ Radiator
- manual lock out
- Need tires: P235/65R17
- go kart or quad frame
- Black Hardtop For 94 Wrangler
- 16x7 ADR wheel 5x100 bolt pattern
- Skid or truck mounted septic pump
- CJ-7 tub
- 79 chevy doors.
- output shaft for th350
- yj hitch
- Locker for a Dana 30 front axle
- Dana 44 Rubi Take-off
- JEEP TJ Rear Axle
- yj front leafs
- 225/45/17 all season tires
- 97-06 Tj Frt Upper & Lower Trailing Arms(no longer needed)
- Sheet Metal For Tj (no longer needed)
- 6cyl CJ radiator
- 8 lug 15 inch rims
- Delete
- Apache Camper parts
- 89-92 ranger hood and doors
- need a 4.0 and other xj parts
- tj blinker switch
- Rubi T case
- TJ D30/RubiD44 with 4.10 gearing
- WTB Lawn sweeper
- Shifter assemly or just this piece for AX5 for pig gig
- GM Factory Radio (I need some buttons)
- Chevy Turbo 400 trans
- Wide 15" 6 Lug wheels
- yj d35 93 and up 3.73 or 4.10 spider gears NON ABS
- Trailer to borrow/rent... mid october...
- Wanted: Dark Tan soft uppers -or- trade for black
- WTB Bronco, fullsize
- does anybody know...
- Powerstroke engine and lp 44 4.09 ring and pinion.
- Wanted: {nes} Anything
- Gone!
- H1 Beadlock Wheels
- Help need Dana 44 parts
- 1 inch angle Iron....
- Need any Isuzu engine parts
- WTT Yj for Scrambler
- AW4 transmission
- 93 YJ 4.0l PCM
- d44 low pinion 5.13 gears.
- 1997 ZJ D/F lock actuator
- 1986,87,78,96,2000, 70 lic. plates
- Boat hauler
- trans jack this weekend novi area or were to rent
- looking for 95 ford bronco tailgate
- TJ Soft Windows
- HELP!! STUCK IN DRIVEWAY need 2.5 and 5 speed for 87 yj found one
- '94+ 351w short block
- Dirt Bike.quad.sled
- FOUND...Flywheel puller - dirtbike
- need mud tires asap
- pre runner rear bumper
- Michigan Football Tix
- 33s on 6 lugs
- WTB ford 4.0 flywheel
- Body Shop - Good one in Ann Arbor/Chelsea Area
- pto corkscrew log splitter
- jeep tj back window for softop
- Trailor Tires
- WTB>>xj,yj, for plowing
- wtt 35s
- parts for 94-98 mustang
- dana 30 and 35 with 410s
- chevy truck parts
- yj shackles
- Quality / Older locking tool box
- explorer trans...
- jeep 4x4
- trade for a truck
- good running motor for 95 civic
- Backhoe to rent/borrow
- Dana 60 lockright or powertrax
- TJ full doors wanted
- Wanted 4in susp lift for 91 ranger
- Kayak J bars
- I need electrical work done-Port huron/Memphis
- 16" rims 5 on 4.5
- looking for a cj jeep
- CJ2A Winshield pivot bolts
- dana 44 flat top knuckles
- wtb racing seats
- TJ axle
- TJ starter
- in need of a cj jeep please thank you
- passenger door mirror 86 fullsize wagoneer
- yj pass fender flare
- XJ driver side seatbelt needed fast!
- jeep
- WTB: Cheap XJ or ZJ
- 2000 s-10 door glass
- Black rear CJ seat
- need 38-40" mud tires
- astro van steering box
- 36-37" Tires.... Iroks or Maxxis?
- free / cracked pickup topper
- 1989 Chevy 1500 Lift Kit
- (GOT ONE) Wanted Jeep! Anyone need a Full Size Truck?
- 32" tire
- ford GT-40 heads
- 90 YJ For Trade
- Log Splitter to rent/buy
- need 265/75/16 tires
- YJ tailgate and hard half doors wanted
- Np231
- Wanted western 7.5 or 8ft unimount for ford
- waggy springs
- ax15 trans
- WTT 32" ATs
- toyota axles and 15x7 6 on 5.5 steel wheels
- cj jeep wanted
- 4wd th350 trans
- need a 2wd toyota pitman arm 1989 to 1994
- wtb one 37" mtr
- 14 bolt dif cover
- 2.5 motor for wrangler 98 to 2002
- air compressor for an hour or two
- * FOUND * XJ 3" Coils
- Need Asap Please Fuel Rail 97 dodge ram 360 found please delete
- Looking for a 2.5 for a 94 YJ (found)
- computer for a 91 Geo Tracker
- dodge ram hemi exhaust
- SBC Aluminum intake in West Mi and perfer close to Grand Haven
- (Never Mind, Got Xj Now)89 Yj D44 needed
- dana 30
- Riding Lawnmower?
- Laptop
- Borrow a Cherry Picker for a Day? (Near Rochester)
- WTB Jeep Mirrors, The larger sq. ones
- wanted=>'99 OEM Wrangler tailgate
- Wanted: Your full doors for my half doors
- YJ trans skid
- (4) 275/60r16
- wanted engine hoist 1-2 ton *found one*
- found wanted jeep tj 5 speed
- 17x8 or 17x10 rims 5 on 5.5
- (5) 15-inch 6-lug rollers 10.5" wide for Chevy
- Wanted: 70's Ford Maverick or Mercury Comet
- 1970s Ford window
- WJ Center console/ shifter cover
- Tailgate for fullsize blazer/jimmy
- oil pan
- YJ brake pedal.
- Needed d44 axle shaft
- wanted stock 73-87 chevy 1/2 ton leafs (**DELETE**)
- want to trade my 4L60E (needs rebuild) for your 7004r k-case that needs rebuild.
