Wanted [Archive] - Page 48 - Great Lakes 4x4
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53
  1. K1500 Rear axle with 3:42 Gears
  2. YJ items needed
  3. 2 Door XJ Drivers door glass
  4. Np 231
  5. 3.42 10 bolt rear end
  6. 81-87 k-10 parts
  7. WTB: 15x8s with the 5x4.5 bp
  8. WTB: RE 3.5" tj springs
  9. 98 tj front axle
  10. WTB:15s 8lug
  11. stock fender flares
  12. jeep 4.0 ho head
  13. Need 17" rims for 5x4.5" bp
  14. Trailer to borrow/rent - FOUND
  15. Friend is looking for some 31's or 33's
  16. 4.0
  17. needed tranny
  18. 92-93 dodge cummins
  19. Grill support rods and cowel grill
  20. 1974 Michigan License Plate
  21. i need a good decent running car or tuck or jeep or blazer
  22. Side Steps
  23. TJ 2.5 Power distribution center
  24. np241
  25. WTB sliding rear window for 1994 F150
  26. 78-79 bronco fiberclass top windows.
  27. c6 inspection cover
  28. 91 YJ Fuel Tank / Skid
  29. GONE!!! Wtt 2 bead lock rims
  30. lookin for a soft top
  31. TJ Control Arms
  32. WTB - 8 lug Chevy/GMC rims 73-89
  33. Double Cardon 1330 driveshaft
  34. WTB - 17" rims for JK 2007-08 5X5 lug pattern
  35. Running Outboard Motor, 90-120 HP
  36. 94 jimmy fuel sending unit
  37. I need a car or truck 500$$$$$$$$
  38. control arms
  39. looking for offroad rig.
  40. Working Typewriter
  41. 94 XJ exhaust man/ header needed
  42. 33x12.50 r15 spair tire on xj rim
  43. military poncho liners, MOLLE pack
  44. 79 short box
  45. Jeep YJ Radio AM/FM Antenna
  46. Welding Tank
  47. Wanted: 1990 YJ W/S Frame & Glass (found a tank)
  48. Rollers---5x5.5 bolt pattern FOUND SOME
  49. 456 for dana 70 and carrier
  50. Rubicon Front Axle
  51. ZJ carpet
  52. Power Steering Pulley, AMC V8
  53. Steelies
  54. 20" Tires and 1 rim for an '03 dodge ram 1500
  55. Wanted Super Swamper
  56. WTT: 400/auto for a 302/auto.
  57. rear greasable shackles
  58. roof rack.
  59. wanted Ford Topper
  60. scuba tanks
  61. Muscle car wanted
  62. Chevy s-10 rear-end 3.42 ratio
  63. 2 inch lift
  64. RV/Marine Fresh Water Pump
  65. Drivers drop 208j
  66. chevy NP205 t case front output yoke
  67. Wanted 1984-1988 toyota pick up parts
  68. i need a cheep truck
  69. Chebby leaf springs
  70. My TJ is in need of some new parts
  71. 17" stainless dually wheel simulators
  72. WTB: 3-4" xj lift
  73. Want to trade 35" bfg MT's for 33" AT's...
  74. 8.8 rear end
  75. Mustang Valve Cover
  76. RBV lift parts
  77. Miscellaneous TJ items
  78. Wanted: Yj springs
  79. Looking for YJ Windshield Frame
  80. need 410 or bigger for d-30 chry 8.25
  81. need xj steer shaft
  82. Wagoneer PARTS
  83. 350th
  84. Rims!!! PLEASE HELP!!!
  85. Wanted RB Chrysler parts. 440.
  86. stock radio for TJ
  87. Sonoma,S10,Ranger im looking for a pickup truck
  88. YJ with an automatic
  89. Dodge Ram DRIVERS DOOR extended cab 1994-2001
  90. 1 piece or 2 piece soft doors
  91. handlebars for my kx125
  92. H1's
  93. F350 lift springs
  94. geo tracker top
  95. 4x4 Pick-up
  96. TJ Pass Fender
  97. 2 junk BB chevies
  98. looking for jeep cherokee tub
  99. WANTED 16"x10 5x5.5 RIMS
  100. locker and gears for gm corp 10 bolt
  101. 93 jeep yj sending unit
  102. backhoe
  103. wrangler 31's and cash trade for 33's
  104. yj front leafs wanted
  105. samurai trans
  106. WTB: XJ Stearing gear box.
  107. WTB 32 spline 1350 yoke
  108. Insert hitch/custom bumper 94 Jimmy
  109. gas tank
  110. lift
  111. i NEEED A CAR OR SOMETHING BAD!! ill do payments if sum1 wil alow it
  112. Youth hunting bow
  113. 1st gen dodge cab
  114. 2nd gen dodge lift
  115. I need 373 gears for a chevy 12 bolt rear end
  116. Need tires
  117. Buy or trade leaf springs
  118. Wanted toyota parts Wanted L@@K!!
  119. need a 36in tsl radial.
  120. Need a ford 2.9L
  121. 1997 jeep grand cherokee tailgate needed!
  122. 1.3 Sami engine
  123. WTB: TJ license plate holder, & door limiter strap
  124. WANTED: 1995 YJ Wrangler 4.0l Radiator and Alternator
  125. super black eagle 2
  126. Jeep TJ rear track bar 3-4" lift
  127. Wanted 24+ foot open trailer
  128. 4.0 for a 99 XJ
  129. need 03 grand cherokee. front drive shaft
  130. 12 gauge shotgun in the U.P.
  131. Used 38 - 42 's
  132. 2nd gen dodge manifold
  133. tj or cj grill
  134. WTB: VW Bus!!!
  135. 27 Spline NP231
  136. kawasaki dirtbike
  137. Ashtray
  138. GM 4.3 V6 Oil filter relocation block
  139. tj pitman arm
  140. Need XJ parts
  141. hood & fender
  142. Ann Arbor area tire shop hookup
  143. 1.3l sami motor
  144. Delete
  145. 16.5 rims
  146. plow mount
  147. Trailer to haul my Jeep
  148. stock yj rear leave springs.
  149. 39-42 in. tires
  150. 4x4 trail rig
  151. 33s or smaller
  152. YJ Full Steel Door Interior Trim panel
  153. cheap/free kitchen cabinets
  154. Tj 4 or 6in springs.
  155. 700R4 Adapter
  156. '89 XJ Bumpers Needed
  157. (found)Wanted Need S-10 TAIL GATE. 92 STYLE
  158. yj tub
  159. ring and pinion for a rockwell plantary
  160. Shocks
  161. WTB: XJ 90' and 94' parts
  162. 78-79 ford f150/bronco front diff
  163. Wheels and tires for a 97 ranger 5 on 4.5"
  164. Cherokee parts
  165. TJ Hard Top
  166. Jeep Wrangler 87-95 Dana 30 parts
  167. Scout transfer case
  168. Tj Ashtray
  169. Amc Dual Quad Tunnel Ram
  170. Ansen Sprint type wheels
  171. 8.8 posi
  172. 9" third member
  173. Complete XJ driveline 4.0/aw4/242
  174. Rubicon rims 03-06
  175. 97 Ram Trany
  176. Terra tires
  177. Tow Rig
  178. Tj
  179. 6.0L GM LS engine
  180. stock TJ radio
  181. 32'' tires
  182. '89 - 93 Mustang 5.0L
  183. 2nd gen dodge hood n grill
  184. 3.73 10bolt gears (chevy)
  185. quad wanted
  186. lllllllllllll
  187. Dana 30 Lockrite locker ***FOUND ONE***
  188. 79 bronco wiring harness
  189. WTB Mossberg 500 in .410 configuration
  190. Wanted Ford 3.0 taurus engine
  191. (FOUND)Wanted 100 gallon fish tank or bigger
  192. WTT N/T Dana 30 Axle Shafts for Scout Outers
  193. Chevy s10 brush guard 2wd
  194. wanted a rearend for a 98 chevy zr2 s10 4x4 8 1/2 gear 30 splin 3.73
  195. Taurus Judge
  196. Looking for a wrangler or cj
  197. Needed 37x12.5-17
  198. Two 5 x 5.5 steel rims/tires 31-35"
  199. seats
  200. **Nevermind*****
  201. 351w
  202. 304 Dipstick and dipstick tube
  203. zj ignition w/keys
  204. trac bar for xj or tj
  205. 3inch body pucks
  206. Computer for 94 yj
  207. Ford 351w
  208. sb 350 oil pan needed
  209. 1.6L SOHC 8V Suzuki Wiring Harness *ASAP*
  210. 12v starter for willys
  211. 16.5 toyota rim
  212. yj springs
  213. FOUND 8 lug knuckel or wheel hub FOUND A COMPLETE AXLE!
  214. 8 Lug Rims and Tires
  215. soft top for 1994 wrangler
  216. Rubicon Rims 03-07
  217. complete wagoneer axle
  218. Any parts to assist in a tacoma SAS
  219. suzuki 1.3L distributor
  220. WTB Stripped AR 15 flat top upper
  221. TJ Hood Latch
  222. wtb cj fiberglass fenders
  223. Tv
  224. WTB:hvac unit for '06 Wrangler
  225. ATV Plow Blade
  226. Underbody Cleaning (Heated Power Washer)
  227. I need some s10 Parts
  228. NT dana 30 or dana 44 front for cj7!!!
  229. 36-39" tires only wanted
  230. Elliptical machine
  231. Welding, Detroit area.
  232. XJ trade for YJ
  233. SR 4 transmission or T-4
  234. Door latch passenger front Cherokee.
  235. 89 yj driveshaft
  236. FOUND - Adapter - 700r4 to 208/241
  237. 97-up tj rear seat and seatbelts asap
  238. stock tj or yj front bumper
  239. 87 ford 2.9 engine
  240. 32/11.5/15 Goodyear MT/R
  241. TJ hood and windshield frame
  242. ax-5 trans
  243. 30" or 31" tires
  244. 35" tires
  245. Jeep 258/304 in Sault Ste. Marie area
  246. FireFighter Vehicle Stuff
  247. Running XJ, Tracker or Samurai around $750
  248. Need Hitch For 2000 S10 Truck
  249. found
  250. wtb or wtt rearend for a 98 s10 zr2 4x4 auto 4.3
