- 31 a/t or anything
- samurai body
- 3" XJ coils
- F-150/Bronco TTB Shafts
- lap seat belt
- turbo 350
- Looking for TJ frame
- Cj Steering Box
- rear leaf springs
- stack kit
- wanted jk frame and tub
- NEED 10bolt rear axle for blazer
- WTB: Chevy/GMC flares
- YJ Hard top rear window
- Rims 5x 5.5
- 35-38
- wiper arms for a 81 cj7
- Soft top window,soft door uppers
- 24-30lb injectors
- steel rims 15 5x4.5 bp
- cheap pop up camper or pull behind camper
- 1980's Dodge 1/2 ton spring plates
- wtb ford 2.9 Liter oil pan
- YJ inside windshield seal
- wtt my 37x13.50x15 baja claws for...
- 97 and up tj body lift
- F-Head clutch
- 315/70/17, 305/70/17 33x12.5x17
- p/s box for 98 cherokee
- to rent hoist or someont to do front seal
- YJ leaf springs wanted........(Thanks found a pair)
- computer
- trade my 33's plus cash for ur 36,37 or 38's
- 460 carb and intake
- jeep transmission
- need 4.56
- suspension lift for a cherokee
- MSD 6AL Ignition Control
- -Long Shot- 650SX parts
- ford 8.8 rear with disc brakes
- Jeep dana 300
- WTB - 2-3" lift for a TJ
- wanted - your TJ plus cash
- cheap wrangler
- please delete
- Waggy springs( DONT NEED ANYMORE)
- 4.0 HO engine
- CJ5 Steering Column Housing
- Cobalt stuff, tires, tail light.
- th350 D20 adapter
- Yj Lift Shocks!!!!
- Wanted 2.5L or 4.0L
- Used Snomobile Track
- Cj7 Wiper Arms
- enclosed trailer to borrow
- bronco2 flares
- Fj40 Hood, Got one thanks!~
- 31's that'll fit a stock chevy
- 302 or 351
- XJ Roof
- SBF C4 or C6
- wtb 33x12.5 15 on gm 6 lugs or just tires
- ford 78-79 dana 60 shafts
- Fuel Tank, Pump and Tank Shield 1990 Geo Tracker
- waggy/j20/durango steering box
- Yj Front Fenders, And Tailgate
- stock rear yj springs
- wheels/tires for 92 cutlass ciera
- Wanted Riding Mower
- Plywood
- Looking to trade a lifted 95 cherokee for a 4x4 Ranger
- yj skidplate
- gears for 95 YJ
- cheap trailer
- rims
- WTB- Dana 300, Dodge 360 flywheel, & bellhousing for nv 3550
- wtb XJ gas tank
- 2 - 4.0L jeep engines
- Pellet Gun
- amc 20 backing plates for drum break
- 35x14.5 tires
- Carhauler
- 16" rollers Fenton, mi
- Hitch for a Grand Cherokee
- AMC 360 or 401
- 110 volt motor
- *4.56 gears*
- chevy th350 2wd tranny
- WTB: D44, 4.27 gears
- Chevy D60 SRW Front Hubs
- 93 up YJ 4.0 engine harness M/T
- wtb - 40" tires
- anybody resurface flywheels?
- Need a 304 timing cover
- WTB 31s or smaller with wheels
- Front Driveshaft For a Grand Cherokee
- Suzuki Samurai
- dana 300 twin stick
- 8 lug rollers
- diesel welder
- dana 18 or 20 transfer case.
- WTB: 4.30 gears for Ford 9"
- Cheap TJ
- entry door
- 351w block, etc
- Professional Window Tinter
- Dana 60 or Corp 14 Bolt Rear
- dodge avenger parts
- 4.3 s-10 4x4 5 speed transmission and tcase
- Willys pickup parts
- Wanted V8 C4 valve body
- Ford 8.8
- Blazer soft top!!!
- Wanted-Tire/Oil change Guy-Grand Rapids
- Lookinf For a rear bumper for a 1990 F250
- xj stuff
- 94 Ford truck Parts
- 36 Volt golf cart charger
- ***found***
- 33x12.50x15 Roller/Spare
- WTB Deck Over Trailer or Goose Neck
- WTB early 60's ford 1/2 rear end.
- YJ steering shaft
- '97-'01 XJ Driver side Tail Light
- Looking For 2 Tj Canyon Rims Close To Detroit
- Need a new holster
- NP 241 t-case for a 2002 TJ
- WTB set of 35" or 36" tires
- old persons beach bicycle
- TJ Rubicon wheel
- 8 Lug 17s
- 5 on 5.5 wheel spacers
- 99-03 Ford Super Duty, 7.3L
- 6" hole saw
- need axle shaft for a dana 50
- TJ half door uppers
- GM 350 Thermostat Housing
- stock yj rear driveshaft
- Lift Kit
- Mig Welder
- YJ side marker bulb socket and lens
- Need For 94 Explorer
- 4.0 short block
- aw4 front pump
- Shocks For A 4" lift front 2
- cheap tj lift
- SYE, Drive Shaft, Shocks
- please delete WTT 16.5-38" for 36" or 35" tires
- Computer Tech Looking For ANY Work
- wtb quad under $1000
- Wanted CJ7
- Anyone Parting Out a Ranger?
- looking for steering box for 1997 tj 4cyl manual
- wtb off road vehicle
- ford 8.8
- your rotted out CJ frame
- Dodge Truck. Up to a 94. 3/4 ton or higher. Non running.
- Black rims
- YJ jack holder
- FireFighter Warning Lights, Siren, Control Box
- Mean Green High Output Alternator
- Wheel spacers CJ7 ***FOUND SOME***
- wide band o2 or JET4POWER
- roof rack for xj
- Feeler: ambulance bumper
- amc v8 distributor - *found* bought new one. thanks!
- Low D44 gears
- 1999 Dodge Ram PS hose (High pressure line)
- house painter exterior.
- 1990 F-150 T-case Needed
- Stock Jeep 6-Spoke Steel Wheels
- WTB: Autocross Car
- Looking For 80s Or Newer Derby Car
- 2 doors and grille
- 1984-1993 Dodge W250 Bed!!!
- superduty jack GOT ONE PLEASE REMOVE
- Ford 3/4 ton axle parts
- 1-2 33x9.5x15r BFG at
- xj 4.0 headder
- Need Good Set of 245/75R16's
- Need a Ford 9" rear axle
- spring perches
- 1974 CJ5 Rear Driveshaft
- 4.6l v8 motor
- cj speedo assembly
- YJ D30 w/ vacuum disconnect
- ford 7.5 8.8 or 9in
- dana 60 rear carrier
- Early 90's 4.0L Valve cover
- Winter Wheels - 6 x 5.5"
- toyota driveshafts
- TRACKER pass side frunt hub
- Jeep YJ Frame
- WTB: lift
- 1995 jeep wrangler 4 cyl. tranny
- wtb bed for 77 f150
- Reclining bucket seats (Hunsaker, Corbeau type)
- WTB: '62 or older car dirt cheap
- WTB Running 350
- T-18 Tranny
- Wanted: AX-15
- 8 lug rollers, TC or BR area
- remote oil filter block adaptor
- 33's maybe 35's for 15in rim (around $500)
- Custom rock sliders
- Yj Front Leaf Spring Packs
- coil overs or air shocks
- Mud Terrains
- Full size tailgate net
- 97 jeep grand cherokee power steering
- RV steel wheel 19.5/5 hole needed
- need spare tire
- Bike Rack
- 1999 Dodge Ram Tie rod and drag link
- WTT: 05-07 Liberty Grill Insert
- wtb sway bar disco's
- fiber glass tounue cover and cap
- Wanted Cheap Jeep
- Grand Am parts
- Wanted XJ, ZJ, and s10/sonoma window motors
- yj driver side floor panel
- Need 02 TJ pass. front fender (BLACK ONLY)
- Dodge Ram Tailgate 1996-2001 complete in nice shape
- 80-86 CJ7 Skid Plate/Crossmember
- Tj Grill Needed-also Hood, Tj Frame
- kickdown cable
- 9 inch 4.56 gears
- Dehumidifier
- Smittybuilt Rear Bumper Brackets for Wrangler
- WTB: Anyone Parting a Jeep Cherokee?
- Mopar A-Body
- Jeep V8 fan shroud
- XJ or YJ under $1500
- looking for a drop pitman arm (DODGE)
- ford 8.8
- np205 32 spline front output shaft
- Want Steel Work Bench
- 2" wheel spacers for toyota 6 bolt
- Cheap Car Trailer 18' or longer
- 35 spline shafts for a rear dana 60
- Tj D30
- d30 shtfs
- Axles for CJ 7
- Dana 44 spring perches
- Dana 44 and 9" wanted
- Trac Vac for Dixie chopper
- YJ or XJ in-tank fuel pump modular plug.
- Front and rear Bumpers Cj7
- XJ/TJ front shafts
