Wanted [Archive] - Page 45 - Great Lakes 4x4
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53
  1. Amc 401
  2. 1998 Durango Box
  3. BPE for a TJ
  4. in dire need..cj5 tub
  5. 4.2 AMC Timing Cover "Found"
  6. need boat parts
  7. trans
  8. MSD Ignition module
  9. Ford d28 spindle
  10. Fan, and fan shroud for 2000 XJ 4.0
  11. YJ Seatbelts
  12. Junk Yards
  13. YJ 1-ton steering
  14. Wanted 2.5 4 cyl for 97 Cherokee
  15. Project OLD VW BUG or BAJA type
  16. 18" dirtbike rear tire FOUND
  17. whinch
  18. WTB 8.8 axle
  19. 2.5L for 2000 ranger
  20. tires today
  21. Need a 4.0L for a 93 ZJ
  22. 3.4 for my xj
  23. air tank(s)
  24. Trxus 33x12.5x15
  25. WTB:Wii
  26. WTB Ford Ranger A/C compressor 4.0
  27. vintage cycles <$300
  28. WTB XJ passenger side mirror
  29. Gibson SG/Explorer
  30. Need a manual lockout for a 94 ranger
  31. mini keg /tractor tires
  32. 409
  33. Fuel Sender For An 83 CJ
  34. 4.0 HO engine...
  35. 70's Ford D44 caliper bracket and spindle
  36. YJ Fuel Pump
  37. WTB: Rear end for 98 ZJ larado with Quadatrac
  38. TJ t-case linkage and rear seat locking brackets
  39. found - need tires 215/60r16
  40. radiator
  41. aluminum bell housing
  42. winch
  43. Toyota Connecting rod...
  44. ZJ front Coils
  45. WTB tire for mobile home axle
  46. Looking For 2002 Canyon Style Rims Close To Detroit Area
  47. yj parts wanted
  48. In Need Of Tj Softtop Door Surrounds With The 4 Bolts And 2 Black Back Window Pieces
  49. yj fuel sender for a 94 4 cylender
  50. Seats for a full size blazer
  51. six lug 16" rims
  52. 14 bolt disc brake brackets
  53. WTB XJ 5-4.5 15" rims
  54. wanted hood latch,rh fen. flare,rh marker light, for tj
  55. bearing seal kit for a 1 piece amc 20
  56. help cherokee parts
  57. help needed someone to come out and help, engine wont run
  58. ***found*** About 12 ft of 2.00" OD x 0.250" wall DOM tube
  59. Laptop for the house.
  60. chevy 15 inch 6 lug rims
  61. wtb - Road Bicycle
  62. I need a Marine Carb
  63. heavy duty spare tire carrier
  64. Wtb Chevy 88-99 Chevy Truck Bucket Seat
  65. 1997 Dodge 4x4 tranny
  66. YJ 6cyl NP231 Stock Slip Yoke or Drive shaft Assembly
  67. Cummins B Series Manual FOUND
  68. free rollers
  69. 98 Escort zx2 manual trans
  70. Rims 15x10 5on 4.5
  71. Need to find a 4x4 fab shop
  72. th350 to dana 300 adaptor
  73. WTT/WTB 2-place Sea-doo trailer
  74. Truck box for 2nd gen RAM
  75. control arms. 99 Tj
  76. **FOUND** YJ 2.5 engine bracket needed
  77. Need a divorced chevy 205 case
  78. Full size Blazer Frame
  79. psp slim
  80. Wrangler stock steelies
  81. 6 lug rollers
  82. stock front seat belts
  83. Found
  84. trailer spindles (2)* Found *
  85. 3-40" x 16.5 Cepek tires , FOUND THEM , Thanks !
  86. Looking for French mopeds
  87. love seat.
  88. wanted: stereo reciver
  89. Front lift parts for an XJ
  90. spot for a 5.0
  91. moped
  92. Good Tj Windshield Brackets!!!!!! Asap
  93. 14 bolt C&C hubs please
  94. matching set of steelies
  95. Power Steering bracket for SBC
  96. Land cruiser steering gear
  97. A JOB in Grand rapids
  98. Geo Metro 3cyl 5 speed manual transmission
  99. 1997 TJ Hard top
  100. 35" tires 15" rim size
  101. Motorcycle Wanted
  102. need SBC headers
  103. Pops wants a wrangler
  104. 92-96 bronco front seats/brackets/console
  105. 17" oem ram 1500 wheels aluminum
  106. WANTED 6 EV6 fuel injector pigtails
  107. Dana 30 WJ passenger side knuckle or long drop pitman arm
  108. 2.5 YJ Power Steering Parts
  109. wtb: yj shocks, front track bar bracket, t-case drop
  110. 91 YJ radiator 4.0
  111. thank you
  112. wanted asap, yj auto, trans bracket
  113. 96-97 F-series 40/20/40 gray split bench
  114. **Found**Cheap TV
  115. Wanted: 4-bbl AMC intake manifold.
  116. fender flairs
  117. 95 chevy 1500 door rods
  118. Today maybe 4L60E band drum
  119. tj bikini top
  120. Hard Top for a YJ
  121. 35x12.5x17 MT's or Swampers
  122. steering ext for 3in body lift on a 91 ranger
  123. shifter ext for a 91 ranger
  124. 302 shorty headers
  125. WTB: Small boat trailer
  126. 96 and under XJ door trim piece
  127. 5 point bucket seats
  128. WTB 96 Tracker Convertible Top Frame Complete
  129. haro pedal bike,
  130. Amc V8
  131. Need 98 Elporer rim/wheel
  132. 05-07 Grand Cherokee Door
  133. Rim for 96 Grand AM
  134. Rear axle - Dana 35 for 98 XJ
  135. Need: YJ hard half doors
  136. Half Door Uppers
  137. Wtb Gas Power Golf Cart,
  138. Motorcycle Project
  139. Small Block C-6
  140. TJ Rear Doubletube Bumper
  141. dana 60 stuff
  142. XJ subwoofer pox/box, 8" or 10"???
  143. wtt mated 205 for a divorced
  144. high misalignment spacers 3/4-5/8
  145. Chev/gmc Sb Tonneau Cover
  146. CJ Radiator
  147. Grand Cherokee Engine Needed
  148. mount & balance 4 tires
  149. WTB 16v goe tracker motor
  150. 4.0 for a 97 XJ
  151. Wtb: Thunder Kings
  152. XJ lift, bumpers, +
  153. foam canoe blocks
  154. I'd like to borrow a KD2044 tapered reamer if I could
  155. 4.0 motor trans xfer
  156. steering colum for a yj
  157. yamaha maxim 650 or 750
  158. DIY beadlocks 16.5" flavor
  159. '83ish J-10 Wiring
  160. chevy dana 44
  161. 350 and 4wd turbo 350
  162. warn A2000 ATV winch cable
  163. front lower adjustable control arms TJ
  164. 2 15" Aluminum Wheels - 5x5.5 Pattern
  165. Power Steering Pump Pulley 79 F150 460
  166. c4 or c6
  167. 33/12.50/r15
  168. 03 7.3 diesel 4x4 trans!
  169. garage downriver to rent
  170. 4.56 gears for a Dana30
  171. YJ 4.0L Longblock
  172. Need 4.0 Engine with Ax-15 Transmission
  173. 4x4 aod
  174. Rear TJ seatbelts wanted
  175. bicycle, BMX or mountain bike
  176. 3" lift and 31"s
  177. smaller utility trailor
  178. 15x10 STEEL RIM
  179. WTB 31" Super Swamper Spare
  180. I need a couple large brake rotors and suspension springs
  181. 10 bolt disc brake axle flange
  182. Beach Cruiser Bicycle (or similar)
  183. wanted: cj7 around $4-5K
  184. chevy front dana 44 pass knuckle.
  185. 12' boat
  186. 83 CJ light switch
  187. 8 lug hp d44
  188. WTB:coil springs
  189. Looking for two 33" TSL Super Swamper Boggers
  190. Wanted cab cover for YJ
  191. cj tailgate,hood,and small block chevy rad
  192. Tracker Fuel Filler Neck
  193. YJ powersteering gearbox
  194. 16" rims 5 on 5.5
  195. Grey YJ seat
  196. 31-33 inch tires
  197. tracker driveshaft spacer
  198. Wanted - Pontoon
  199. STOCK YJ Leafsprings
  200. wtb 33x12.5x15 and 15x8 black steelie
  201. Needed: Chevy 10 Bolt Cover!
  202. 35" mud tires
  203. 5 bolt CJ lockouts
  204. tj master
  205. CJ to YJ conversion shackles**FOUND**
  206. Engine for TJ (2.5) or (4.0 + ax15 + harness)
  207. GM 10 Bolt
  208. CJ-7 or older front grill
  209. wagoneer springs
  210. Chevy D60 shafts
  211. Motorcraft 2100 for my 258
  212. need torchs in tc area to cut a few bolts
  213. 2.3 Ford Motor
  214. Longtube Headers 79 Ford 460
  215. AMC V8 Brackets and Pulleys
  216. Hi- Pinion ford 9"
  217. wrangler
  218. Bikini top
  219. CJ Soft Top Parts or Bikini Top
  220. 91 ranger tube bumper or something to get a good start with
  221. s10 Leaf flip kit
  222. boomerang schakles
  223. Yj 4.0 with ax15
  224. Big heavy steel layout style table- make an easy $100
  225. 35 12:50 15 bfg mudd. terrians
  226. House for rent
  227. 2.5 Cylinder Head
  228. wtb. 1-15x10x2.5 gm 8 lug spoke steelie
  229. D60 Driveshafts
  230. (4 OR 5) 16" Rubicon Moabs
  231. 37x12.5x15 or 38's
  232. Cab & Chassis 14blt FF
  233. 1st gen ranger/b2 fenders needed
  234. Dana 44 Gears, Spool, Wheel spacers....
  235. soft top for a CJ7
  236. winch, new, or nice used, 9000 or bigger.
  237. 5 x 4.5 BC Wheels & Tires
  238. WTB Jeep
  239. 4 inch CJ lift
  240. Wheel spacers/adapters 5on5.5 to 5 on4.5
  241. F250 Superduty Front Springs
  242. Rear axle from Jeep, Bronco II, Ranger, or Explorer
  243. CJ V-8 fan shroud ***Found One******
  244. 31s
  245. 1994 wrangler oem hood hold downs
  246. Winch 4500lb - 8000lb
  247. yj Front driver side fender
  248. I Want A Dodge Dakota Sport*
  249. .22 pistol
  250. Front Parking Lamp for CJ (Grill)
