- nice racing quad
- chevy 305
- YJ Exhaust for a 94 YJ w/ 4.0L auto
- Auto Trans for a AMC 304
- Looking for a P S cyl bracket Dana 60
- Wanted: 5.7 Vortec heads.
- 02 ktm 125sx front and rear fender
- TJ parts; Winshield frame/hinges, misc dash pieces and COWL
- yj fenders
- xj front and rear bumper
- WTB soon: YJ, TJ, reliable CJ under $3000
- 1990's Chevy Beretta Parts
- Jeep Scrambler Motor Needed A.S.A.P.
- CJ or YJ tub
- Need Core Support For 88 Ranger
- Front 95 ZJ Drive shaft FOUND DELETE
- Ford hp44 F250
- 96 dodge ram lift
- Headers
- 2 wd 4l80e
- rear axel for 78 c5j
- wtb used welder
- yj radiator
- Old connecting rods
- need a trans for a dodge ram 1500 4x4
- Looking for ZJ Grand Cherokee Gas Tank Skid (Oxford, MI)
- Junk Np231J Transfer case
- wanted: YJ windshield frame and tailgate
- WTB: Cheap mountain bike
- Natural gas stove
- v8 blazer or jimmy
- Looking for either...
- xj fender flares
- dana 300 shifter
- WTB SM465/D300 combo
- Revolver Shackles
- nice 16 wheels for chevy
- YJ Fenders and inner fenders
- TJ hood, driver side fender and flare
- WTD beef cow
- 30-32" tires AT
- adjustable track bar for an xj
- wtb AMC 401 CRANK
- stock steering for a yj
- Rear Driveshaft for 2000 TJ with SYE setup
- wtb: Drop bumper 87 chevy
- Yj parts
- Need help Raccoon removal
- D35 Discs
- CJ bottom hing tailgate
- 91-96 ford f150
- 52'' Rear Chevy Springs Wanted
- WTB ford lift springs
- Delete! 4 or 5 16" x 8" rims 5 on 4.5
- Looking for a Dana 35 Rearend with 4:10
- CJ Dana 30 with 4.10s
- I Will Pay Someone To Get My Dune Buggy Running For Me
- WTB chevy starter 91 2.5
- WTB: Set of good P235/75/15 tires
- 33 12.5 tires and rims
- 4 cyl. beater
- some 15x10 jeep rims 5on 4.5
- Tj D30
- 2 10" subs
- 80-86 Ford f150's door
- WTB a Car trailer
- HP44 from a F250
- tough truck
- *FOUND* WTB - 2 35x??x15
- steel or cheap alloy wheels, 15x8.5-10 with 5x4.5 BP
- Factory soft top frame TJ 1999
- tail pipe...
- *found* tranny cooler
- anyone from port huron area?
- honda cr 250
- wtb 80s crew cab or 2wd 50-80s truck running
- 14 bolt 4.10's
- 35" tires
- dodge parts
- Cheap car radio
- not so stock 350 sbc heads
- CJ Rims
- Magnum bellhousing and flywheel
- 97 or newer receiver class 3
- XJ spindle
- Locker for Chrysler 8.25
- Silver Diamond Plate
- Edelbrock rpm intake
- Chevy Dana 60 front
- *FOUND* WTB: (4) 33/34x12.50xR15 Tires
- Wanted Chevy 350 Turbo Tranny 4x4
- 83 Jeep scrambler intake, and weber carburator wanted
- vehicle carpeting
- 15x8 5x5.5 Rim
- ECA (computer) '86 or '87 aerostar 3.0
- 8 lug 44 or 10 bolt outers - or complete axle
- Trailer House Frame
- rear diff.
- Rail Buggy/ Sand Rail
- 2wd E4OD
- somebody to build roll bar for my tracker
- 31" All Terrains
- 4.5" lift upper control arms for XJ
- 94 and up s10 mirrors
- *Found* WTB 5 x 5.5 Rims
- looking for an anvil.....
- running AMC 360
- Trade only nice bike and sled for a quad
- any thing that would be good in the dunes or trails for $5000-$7000
- good dirt
- CB Mic
- Standup PWCi. Pref Polaris Octane, or Kawi 750.
- *FOUND* set of 215-70- R14's
- tires wanted for S-blazer
- NEEDED 79 cj5 AIR dash switch for plunger vent
- Thermostat housing
- Wanted: Small block Ford parts
- wtb 4- six lug chevy wheels and tires
- Wanted: A job
- TH400 to a 205 Out put shaft
- looking for some cheap rims 5 4.5 for xj
- Stock Street tires 15"rim 30"max
- Safari bikini top needed
- yj gas tank
- 14 bolt
- AX-15 trans
- 38 tooth speedo gear (blue)-no longer needed
- crotch rocket
- WTB Ford Ranger/Jeep xj/yj/tj/cj
- Np231
- Many parts for TJ
- Ford 9 inch high pinion
- Super Swampers/Boggers
- 2.5L Engine
- 33x12.5x15 Mt tires
- tj dana 44
- Dog Kennel/Crate
- wanted wheels
- 1" coil spacers for 98 XJ
- cheap highway tires
- Jeep Cherokee Wiring Harness
- doors 89 xj
- Sway bar links for 3" lifted XJ
- mud jeep/ford
- Cheap Treadmill !!!
- ford ranger
- NP 242 Transfer case ~ 1994
- Chevy NP205/NP208/NP241 (married) - 32 spline input
- YJ windshield frame and glass
- I need a 700r4
- WTB/T: Mountain Bike
- 34x9.5x15 TSL's or 35x10.5x15 Bogger
- Ford hp dana 44
- XJ steering conversion
- Buick 225
- CJ 5 Firewall
- Ford hp44 F250
- wanted ford 460 aftermarket alum. intake
- mini bike engine
- 31s and rims
- TJ Marker lenses
- Leaf Spring Bushings
- Pipe bender to borrow for a week
- plymouth horizon parts
- needed 89 xj doors
- YJ Soft Top
- nv4500
- CJ7 4" springs
- Wanted: TJ half door panels and bar on back of soft top
- WTB right rear TJ sahara flare
- WTT trade hardtop and doors for soft top and half door TJ
- T-14 trany 3 spd. from 72-75 jeep cj
- TJ Fender Flares
- Trenching
- Chevy 350 TBI
- welder
- tube bender
- Charcoal 97+ XJ Console
- spider gears
- yamaha quad
- 33" Tsl
- cheap tires
- TJ or ZJ rear dana 35 housing
- Ar 15 or M4
- cheap litte car
- *No longer needed* Low mileage 4.0
- AMC Trans
- 5x5.5 wheel spacers
- Anyone have an AX5 transmission? Need one ASAP!
- 31's tires
- tj dana 30 passanger side axle shaft
- tire changing machine
- AX-15 Transmission
- wtb SYE kit for np231 98' tj
- stock XJ leaf springs
- 33-12.5-15r
- 2 Piece Rear Main 350 Manual Flywheel
- Cheap CB antena
- Still Looking For Canyon Style Rims FOR MY 1997 TJ
- turn signal lever
- Samurai rear axle carrier
- R & P Gears for 1957 CJ-5 OR Overdrive Unit
- 350 vortec heads
- 99 cherokee factory cd player/cj low back seats
- 38x15 inch inch creepy crawlers or trepadors
- Tracker axle
- ZJ doors and rear hatch
- Replacement or upgrade Carb for CJ 258
- YJ seats gray
- TJ rear seat
- To Trade Tires **PIC UP**
- YJ frame motor brackets/plates/mounts
- looking for a 32x11.50 bfg at for a spare
- Place in Kzoo to keep my bronco
- mud tires for 16" rims
- CJ5 need a oem volt gauge for 79 anbd fender flair's
- '01 and up GM 8 lug wheels
- looking for ends for 4-link rear
- 10 bolt shafts and stock seatbelts
- swaybar disconnects
- 2008 Ford factory 20's
- NEED 17" Tires
- D30 for cj
- zj 4.0 neutral safety switch needed
- oem TJ foglights
- 35 inch mud tires/perf Bogger or TSL
- 87 yj lower stearing shaft
- Postal Jeep grille/ DJ
- 2 235/85/16 tires
- 231d for my 99 dodge
- WJ Tires, 225/75r16
- 93 yj center gauge cluster and speedo (working)
- 8ft chevy pickup cap
- wtb some mudd tires
- stock TJ lower control arms
- GM 12 Bolt
- want a quad. $3000 or less **FOUND ONE**
- 79 Cj Doors Full Or Half Hard Or Soft
- Cherokee, hitch,tow hooks & other msic.
- Wanted 4x4 vehicle
- looking for doors for a 97 wrangler
- YJ mirrors
- Cj7 Cj5 Yj or Tj Project
- Wanted old school car
- 98 tj hood and grill
- Jeep CJ7 $3000 or less.
- need a rototiller/ with a trashed horizonal shaft motor
- wtb 1991/92 wire harness
- *completed sale* S-10 1st Gen doors *completed sale*
- Need P/S Pump For 2.9 V6 Ford
