- locker wanted for dana 35
- 2"+ OME or.... TJ Coils
- moped or scooter
- TRADE 88 yj for ranger 4x4
- Durango/dakota headlamp/fender (97 and up)
- TRADE 35x15 TSL's for 38 11 Boggers
- Suspension Lift for my 04 F350
- WTB 31 inch driveshaft
- Frame Brackets Needed
- Need Some Seats
- portaband
- Parts washer
- I need an XJ rock Bumper
- Cj disk brake dana 30
- front shift fork for np241
- WTB: Peddle Boat/ Paddle Boat
- 39 or 40 inch tires
- HP 44 crossover steering arm
- wanted stock tj rear track bar
- 39 to 42 inch tires for 16" wheels
- Crotch Rocket
- 4.0L Powersteering Pump and wiring harness
- HP30 Housing
- Used Milwaukee Batteries
- need sm465 to D300 adaptor
- 35 0r 37 on 15 x10
- Electric fan
- hp 44
- SM465 looking for some parts
- mini 8 coax
- 302
- stock xj leaf spings
- 6" lift for 88-98 k1500
- Stock TJ front bumper
- brake pedal assambily and master cylinder for a yj
- 6" lift
- Kitten?
- WTB:86-95 Toyota Rr. driveshaft
- late yj gas tank and sheild
- yj fenders
- CJ hood
- CJ windshield frame/glass
- xj electric fan, coil spacers
- drop pitman arm
- grey seats for 97 chevy truck and driver inside door handle
- Need one 32" Mickey Thompson MTX Tire
- need one tire
- wtb 97 wrangler front sway bar
- need a lot of ford parts help.
- Install My Trans For ??
- powerwasher pump
- rear drive shaft
- Waggy 44 with 4.10 gears
- need one peace shafts amc 20
- One Goodyear Wrangler HP 275/60/20 tire
- jeep stock steel wheels 5x4.5
- SII tilt column
- p195-70-14 tires
- tj steering gear box
- 35/12.50/ 17s or 18s or 20s
- SBC parts for 350
- drivers drop 4.10 full width front axle
- Dana 18 / Willys for parts
- wj knuckles
- Old Bear Bows
- WTB: 4X4 turbo 350 or 700R4
- CJ7 Parts dash and wiring (No longer need)
- Need Samarai stock wheel for spare
- 2.5 Litre
- 90 or newer s10 steering box
- Axle's
- WTB A4OD ford trans.
- Someone with a CJ7 in oakland county **done**
- Yj windshield frame + glass...close to ohio please
- *WTD Motor*
- under the hood air compresser
- s10 / sonoma / blazer / jimmy / bravada - Seats, wheels & tires, bed, ZQ8 steer box
- boat
- need YJ bell housing
- Trailer Tires
- car ahuler/ equipment trailor
- bfg mt's 31x 10.5x15
- 4 man tent
- wtb: xj/tj d30 w/ 3.73s or 4.10s
- wtb: radiator for renix 4.0
- wtb: GOOD working ax5
- Adjustable Brake push rod
- Need a Track Bar for my Grand Cherokee
- Full size Dodge topper
- looking for a Truck/jeep
- need rear axle for 87 cherokee
- 91 cherokee radiator
- ford 10.25 cheap
- Geo Tracker 5.13 Thirds
- YJ Gas tank
- welder of some sort
- 37" ties or larger for 16"rims
- Front 6" suspension lift for early 90's Ranger/B2
- Waggy D 44 shafts or axle (with shafts) WTB
- military surplus tires
- need a rear driveshaft---dodge
- 39.5 tires 17" rims
- wanted: H2 rims
- 1989 dodge dakota
- parts
- small bolt chevy wheels
- dana 44 stuff
- Looking For Canyon Style Rims For My Jeep 2002 I Think
- 3" tj rear coils
- explorer/ranger extended radius arms custom built/used/new
- AMC Headers & CJ Parts
- Stock Pre 97 XJ Driveshafts & a 4.0 L6
- drivers side TJ fender?
- junk yj/cj tub
- dj grill
- stock tires and rims for a xj/ GOT
- Roll Cage
- WTB: Sami 1.3L Carbed Motor, Trans and Driveshaft
- Need 91-95 YJ rear brake hose
- cheap tracker or side kick. or jeep
- mustang wheel/tire
- Ford 9"
- 2.5 for a tj.
- MC2100 Carb Spacer Plate (not adaptor).
- tires needed
- power steering box
- 15x8 8 Lugs
- Need a YJ frame.
- looking for a car
- "help"need A/c Compressor
- ford track bar
- ATV Tires
- poison spdyer roll cage
- Ford np 435 bellhousing for small block
- cheap xj project
- 1 m/t Baja Claw Radial Tire 35 x 12.50 x 15( OR ANY MICKY THOMPSON 35 X 12.5 X 15 )
- TJ rear flares CHEAP
- yj wiring harness
- Ford 9 Inch Gears
- Wanted To Trade For 4x4
- 21 spline 231 (TJ)
- CJ-7 Soft Doors or Soft Uppers
- 1996 ZJ left front fender
- Looking For Tj Doors Surrounds For Softtop
- 99-04 Jeep Grand Cherokee
- WTB: Chevy Quadrajet Carburetor
- 27 spline ford 4wd t-case
- WTB: Nikon D40 in Good Condition
- Dana 60
- Wtb 4 Or 5 33/12.5/15
- moped or motorcycle 600 or less
- Thanks
- Roller fairlead
- 1350 yoke for np205 t-case.
- Tool box
- MC2100 Carb
- Looking for 01 Raptor wheels
- Short Side Dana 44 axle shaft
- wtb- 4 lug mustang wheels
- cheap truck topper wanted
- Water ski's junior/youth size
- 2door Xj interior parts
- YJ Parts Needed
- 4.0 Oil Pan
- summer and or part time work
- Stock front sway bar link for XJ
- yj 350 swap stuff axles trans t case
- 4.0 head
- ford fender flares
- Xj BDS Shocks
- s10 body
- heater control
- Speedo And Tach 88 Yj
- 2.5 Engine
- CHeap GPS
- wheel bearing
- motorcycle
- mail jeep grill
- Lift, Half Doors, Cool stuff... WTT Hard Top
- 98 XJ rear drive shaft + rear axle yolk
- steering colum
- cj7 Steering colum
- pipe bender use
- WTB ford alternator
- cj-6 frame
- wheels for 86 xj
- 3.73 or 3.90 gears GM 10 bolt
- used sye?
- Dodge 727 trans
- transfer case 32 spline input shaft
- WTB: Ford 8.8 31 spline pass. side axle shaft
- sprint phone
- YJ/CJ soft top for full doors
- Bench Seat For 82-87 Chevy P/U
- left front half door
- CJ Seat belts
- 700r4 transmission needed
- Super Swamper tires
- NEED to find a car for around $800
- drivers side window Bestop Soft Top
- TJ windshield
- AC Compressor
- AMC 401 Harmonic Balancer/Damper
- xj body
- '93-'95 f350 4wd front springs
- Wated a lower plastic skirt thing (AIR DAM) for 99 Cherokee sport
- spare 35 inch bogger
- CJ Steering Column or part
- Looking for CJ project
- need a winch.
- tj hood hinges
- 36 37 or 38 radials
- (2) 35 x 12.5 x 15 BFG A/T's
- Foam Deer
- 31's
- 78 CJ7 power steering box brace
- NP231 21 spline
- Starter for a 1990 Kawasaki 550 jet ski
- Wanted intake hose from TB to MAF for 95 ranger
- WANTED: ford dana 60 caliper brackets
- WTB: 35" Spare Tire
- air box bracket YJ 4.0
- 38x11x15 boggers
- hp d30 shafts
- 2x 5 on 4.5 15" steelies
- Fire wood
- explorer axle shaft
- tube bending needed.
- Cheap Jeep
- Windshield Frame Needed
- 35x12.5x15 BFG AT good tread
- Air cooled VW stuff wanted (maybe)
- 83-84 or 84-88 Chevy fullsize truck grille
- 90 and up Ford truck with EFI
- wanted 31s
- D30 yoke
- Points distributor for a 258.
- 4.0 wanted
- TJ Bikini top
- Steering Stabilizer mount, TR end for Waggy 44
- 23 spline np231j
- 727 to NP adapter plate
- stock jeep tires, good tread
- steering box for a 99 ram
- cheap 33-12.5-15
- XJ Front DS w/ Good CV Joint
- Chrysler 8.25 Spiders(27sp.)
- pocket style flares for tj
- tail gate trim grand cherokee
- T5 transmission
