Wanted [Archive] - Page 39 - Great Lakes 4x4
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49
  1. topper for 99-03 F250 short box
  2. WTB-Dodge ram parts
  3. 83 CJ7, hinges/mirrors/handles and such
  4. 33" Cheap Spare
  5. 35's near 49091
  6. WTB 1ton chevy front driveshaft
  7. 410 dana 35s
  8. 95 jimmy 4.3 w engine
  9. 1994 Cherokee Sway Bar
  10. rear drive shaft
  11. 4.11 gears and one piece AMC 20 axles
  12. AMC V8 4barrel intake
  13. bought a car
  14. Cowl hood for 85 chevy Pickup
  15. WTB Suzuki Samurai
  16. WTB aftermarket stock for SKS and 10/22
  17. wtb 456 gears for a 10 bolt
  18. 30X9.50X15 tires
  19. found
  20. any small 4x4 600 bucks and under
  21. s link
  22. wtb: running pre-96 xj, $1000 or less
  23. Wanted: Jeep Inside Windshield Brackets
  24. yota gears
  25. ax15 tail housing
  26. Dodge Dana 60 Spindle
  27. 6 bolt rims
  28. '94 Bronco hood latch, springs.
  29. wanted 96-99 vortec 5.7
  30. trailer tires
  31. 15" 8-lug rims
  32. body work
  33. 4 Door Car $3000 limit
  34. Rubi 44 Front DS Inner Shaft - FOUND
  35. 35" Boggers for 15" rim
  36. 33-35" R16 Tires needed
  37. 265/70r16
  38. Dropped pitman arm for a YJ box
  39. fuel cell
  40. 6x9 speakers
  41. 4.0L wiring harness
  42. WTB 33" tire for a 16" rim
  43. Siren&Speaker
  44. 76 cj power steering bracket
  45. 3:55 8.8 gears
  46. s-10 limited slip
  47. wtb 36" or bigger for 16.5 rim
  48. trade for ext cab truck
  49. 96 Honda TRX 300 Front end
  50. 40" tires
  51. coolent tank for a 90 xj 4.0
  52. drive side outer nuckle for a 98 dodge dana 60
  53. ford 9 inch detroit locker
  54. ** Log Splitter **
  55. looking for 2 bfgoodrich 315/70R17
  56. 700R4 and T-Tcase
  57. '97 XJ 4 liter machanical fan, bracket & shroud
  58. WTB set 265 or 285-75-16
  59. chevy D60 hubs and rotors
  60. Rear 10 bolt chevy axle shaft
  61. 4.3 carbed
  62. s10 passenger heated power mirror
  63. cheap airfare!!!!
  64. Tube fenders for Jeep CJ
  65. WTB tires & wheels
  66. looking for 88 to 99 full size chevy truck parts (see list)
  67. WANTED: TJ Hood
  68. Sm465
  69. d30 stub shaft.
  70. Widetrack J-10 rear shafts... (D44)
  71. 1 35x12.5x15 BFG AT
  72. snow plow for my 99xj
  73. help, need crush sleeves
  74. 351 Parts
  75. 79 351m motorcraft 2bbl carb
  76. TIRES 33's to 40's, SETS or IND.
  77. WTB front drivers seat for a 1987 wrangler
  78. Yamaha Warrior Front Wheel
  79. Stock YJ spring packs
  80. Jeep Wagoneer Frame
  81. wtb: 4bbl dodge sb intake
  82. need gears and a diff. dana 60 and dana 44
  83. tire mounting and balancing
  84. Custom Exhaust Work - Looking
  85. 1995 Geo Tracker computer
  86. engine stand
  87. feeler: vortec heads off a 5.7
  88. WTB: Stock ford Radius arms.
  89. 15x8s with the 5x4.5 bp
  90. ATV in the $2000-$2500 range
  91. WTB: JD2 bender
  92. 97? ford dana 60 nuckles ball joint
  93. Enigne 350 5.7 Vortec 4x4 To A 98 Surburban
  94. Verizon Voyager phone. new or used.
  95. Who Wanted a Taurus Tranny?
  96. '94 Sundance Fuel Pump?? I know.. Long shot
  97. i need tires.
  98. Black Fold and Tumble Rear Seat CJ7
  99. 55-gal. steel barrels (West Michigan)
  100. power steering block
  101. stall
  102. Bunkbeds!! Both single!
  103. Side door 97 Dodge fullsize van
  104. Fuel Cell
  105. YJ doors
  106. Auto toyota tranny
  107. 16s with the 5x5.5 bp
  108. WANTED YJ bumper
  109. Tail light
  110. 03 or Newer TJ Rear Bench Seat
  111. Possible road trip to Jackson
  112. D30 Axle engagment switch for 92 YJ
  113. A Car 650 Or Less.
  114. 99 TJ rear window for hardtop
  115. 2004-2006 Silverado/Sierra 2500HD GAS!!!
  116. CJ-7 Brake line
  117. Bronco Tailgate
  118. 342 for ten bolt chevy
  119. yj soft top back window
  120. YJ/CJ Tub parts
  121. 99 Ranger tranny
  122. A job
  123. 1991 ford ranger 4x4 automatic trans
  124. 2000ish XJ tranny parts
  125. WTB 31-10.5-15 m/t spare
  126. Cap for 03' GMC short bed
  127. output yoke
  128. Intermediate CJ-5 centered D44 rear w/ 1-pc shafts
  129. Drive shafts wanted *FOUND*
  130. want cheap set of tj wheels
  131. Anyone have a TH 350?
  132. WTB 4.0 for 97 Jeepy
  133. stretch tank for my TJ
  134. floor jack
  135. Toyota engine harness
  136. 4 16 or 17" Ford 5 on 135 wheels wanted for 97 expidition
  137. Paintball and car audio equipment
  138. 92 xj ecu
  139. Seats
  140. YJ Springs
  141. Durango Tailgate (hatch)
  142. 4.5 coils for 1999 XJ
  143. Looking 81-95 F150/Bronco lift and other parts
  144. YJ soft Lower doors that accept Uppers
  145. '75 F250 radiator
  146. WTB 35 inch spare
  147. Yj Lower Soft Doors
  148. scout knuckles
  149. Cja Half Doors
  150. found, please delete
  151. 33x12.5x15 MT Claw Radial or similar tread
  152. WTB 245's-31's, 15" rim loada range D or E
  153. jeep cj7 hard doors
  154. 36-37" tires for 16" rim
  155. samurai tcase, windshield
  156. Auto trans for 96 powerstroke 4x4
  157. CJ7 Column
  158. lift springs
  159. 110 gallon fuel tank
  160. Ford Tauras Alternator
  161. tires and rims
  162. Floor Shifter Needed
  163. YJ parts
  164. D-60 spool
  165. wanted some 15 wheels
  166. High Torque Impact
  167. (4) - 16.5" x 12" Rims
  168. ONE - 40" x 16.5" Swamper or Gumbo
  169. S10 limited slip rear diff
  170. 1961 CJ5 15" wheel and tire.
  171. 99-03 lightning or Harley Davidson super charger
  172. 15" X 12" or 14"wide 8 Lug wheels
  173. diamond plate
  174. Anyone Parting out a WarnŽ XD or HS winch?
  175. Old lift springs for YJ
  176. dodge transmission
  177. YJ Fender
  178. tj stock pit arm
  179. High torque MINI Stater for SBC 350 153 0r 168 tooth!
  180. TJ SuperTop hardware
  181. Misc CJ7 Parts wanted-spare tire carrier, windshield, drag link
  182. trailer tires and wheels
  183. 95 ZJ Drivers side Headlight
  184. wtb- 35" tsl for a spare and nissan doors
  185. Concrete blocks
  186. 10 feet of 2x4 tubing - FOUND! Thanks Ridin Dirty
  187. 38-38.5 tire for spare
  188. 76 and up jeep windshield frame.
  189. 88-98 chevy tailgate
  190. Wanted - D35 Disc Brake Hardware
  191. 98 XJ Rear Leaf Springs
  192. Need a 700r4, windshield for a yj.
  193. I need speaker grilles 6x9
  194. Dash and Fender
  195. Hp60 axle shafts
  196. 16x7,8,or10. 5on5.5
  197. also need a 700r4 for 92 s10
  198. B&M Pro Stick for chevy turbo 350.
  199. wrangler springs
  200. Ford AOD
  201. Dana 35 FRONT Carrier
  202. need die set for model 3 bender
  203. Tj fender flare extensons+marker light lenses
  204. blinker for xj
  205. A coulpe things
  206. manaul trans for 93 1500 chevy
  207. WTB: $2k or less SUV/Truck
  208. 2.5 yj radiator
  209. spare tire
  210. TJ soundbar & speakers
  211. WTT 33" Super Swamper TSL Radials for 33" MTs or 33" MTs for sale
  212. 33x12.5x15 MT Tires on rims 5x5.5
  213. 17" 8 lug rims for Chevy
  214. YJ have $2500 in hand !
  215. 99 TJ white soft top and a 44 rearend also for a 99 TJ
  216. NP231 t-case
  217. 38" to 42"
  218. need today Radiator for 88 jeep xj auto 4x4 4.0
  219. NEED ASAP!! jeep Power steering box
  220. Hard case for my golf clubs
  221. NEED ASAP: Place to live or garage around Durnad
  222. selectro hub!! should be OK mile marker saved the day!!
  223. scuba tank
  224. 1978 CJ5 windshield with good glass
  225. 70-74 AMC Gremlin
  226. 24 carrot gold brick
  227. chevy body lift
  228. tail lights
  229. Need really bad. 96+ Blazer fuel lines (2 door)
  230. Mickey Thompson tires
  231. hp30/waggy44/8.8
  232. KC lite
  233. Need 79-87 chevy 4x4 frame for project!
  234. yj lower doors
  235. Swar Bar QD's or links TJ
  236. 245/75/16 g/y mt/r
  237. 231 t-case
  238. 94 Jeep Cherokee Tie rod
  239. 94 Cherokee windshield Found one
  240. want to borrow f250 unit bearing seal tool
  241. WTT 33" baja claws for swampers
  242. Black TJ or Rubi Mirrors
  243. 37-12.5-16.5 Goodyear MT from HMMWV
  244. wtb 242 transfer case for 95 ZJ
  245. Dana 20 transfercase external part.
  246. TJ Drivers Seat
  247. WTB Grand Cherokee pass side mirror
  248. 1995 jeep cherokee parts
  249. chevy 350tbi motor
  250. Want Bronco II parts
