Wanted [Archive] - Page 37 - Great Lakes 4x4
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. lookin for an xj
  2. Delete - Looking for S-10
  3. 88-94 truck flares
  4. s-10 or sonoma 2 wheel drive 4 cylinder
  5. need a d-30 ...found
  6. auto body repair near White Lake
  7. Rubicon Drive shaft
  8. WTT 40" Hawgs for H2 wheels and tires
  9. I'm looking for a jeep roller (CJ or YJ)
  10. SKS Stock
  11. Yj 6cyl radiator
  12. Early Bronco big bearing rear axle with 4.10 gears
  13. Toyota Birfield Joints
  14. CJ 6 cyl
  15. meyer's manx style windshield frame
  16. 50 gallon steel drum
  17. 8" rear lift springs, 95 f350
  18. XJ stock or 3" lift rear springs
  19. 88-98 Driver Fender!!!!!!.
  20. TJ stock front bumper
  21. XJ parts wanted
  22. WTB: 30x9.50x15 Goodyear Wrangler GSA
  23. cj dana 30 front axle
  24. aluminum jeep wheels - cherokee, grand, wrangler
  25. 1-1/4" Sch 40 A500 grade B
  26. Ax-5
  27. looking for a 460 efi with trans.
  28. i need a computer for my S-10
  29. I need a back seat for my 94 Wrangler
  30. Looking for a hard top for my 94 Wrangler
  31. I need a Dana 35 4:10 Rearend For my Wrangler
  32. I Want A Puppy ...
  33. Any Licensed Electricians?
  34. bronco body 91 - 96
  35. tires 38 and bigger, 16 or 17 inch rim.
  36. Trade? CJ/YJ Fold-'n-Tumble Seats (gray <--> spice)
  37. Qty - 2, 8 lug wheel spacers
  38. tj fender flare
  39. wanted: 1975 k20 rotors, calipers, and brake hoses for disc conv.
  40. 2003+ Kx 125
  41. HP d44/9inch ..65"
  42. Getrag, NV4500, or NV5600 - buy or trade
  43. 2.5" wide spring plates & spring hangers
  44. Where to buy POR-15
  45. Door parts for a yj!
  46. WTB- 37-39.5 tires and 63" chevy rear springs
  47. 31x10.5x15 m/t
  48. Jeep Grand Cherokee Zj Lift Kit Wanted
  49. 95 XJ in need of Bumpers
  50. Heater Control Assembly
  51. 88 bronco parts and TIRES
  52. Battery
  53. 350 and trans
  54. Rear S10 Spring Pack FOUND PLEASE DELETE
  55. Rear glass for a YJ
  56. Cooper ATR Tire
  57. Need a set of CJ roller wheels/tires 5x5.5
  58. Looking for an XJ under 2000
  59. WTT 2 New 35x16-15 boggers never mounted
  60. 35- 38" tires for 15in wheels
  61. WTB 4 33x12.50 15 boggers.
  62. Tamperproof t-40 torx bit
  63. 2.3 Oil Pan
  64. Rear Seat, YJ, TJ, Tracker, Sidekick
  65. Ladder Bars
  66. AMC v8 Mechanical Fan
  67. Holley Truck Avenger carb.
  68. WTB 77-85 4x4 ford truck. new sweet muzzleloder w/scope for trade
  69. WTB Lift kit and couple other things for XJ
  70. 1991 Geo Tracker 1.6 Engine
  71. Looking for 1/2 doors
  72. building materials
  73. WTB 33" or 32" all terrains
  74. Looking For Cheap 30 or 31" mud tires
  75. wtb cj v8 radator!
  76. toyota parts
  77. tj rear axle housing (bracket donor)
  78. 16" All Terrain Tires Wanted
  79. 327,350, or 400 sbc
  80. chevy pickup
  81. 1994 Bronco steering gear box-GOT ONE
  82. Stock rear CJ springs.
  83. toyota gears
  84. Heater blower fan
  85. wtb suspension lift for s10
  86. wheel spacers
  87. 95 chev s10 transmision 5spd for 2.2L engine
  88. Hard Top for a yj
  89. need a vehical speed sesnor for a 93 xj aw4 asap!
  90. im in need of some tires
  91. wtb 35x12.5.15 Pro Comp X Terrain
  92. AX-15 transmission - cheap / broken OK....
  93. YJ or Waggy Leaves
  94. passengers side motor mount 4 cylinder yj
  95. Thinking about 4x4
  96. Would like to buy a CHEAP quad...
  97. WTB RUST FREE tracker
  98. Lower steering shaft for 78' CJ with power steering
  99. Steering Knuckle for Wrangler SOA
  100. AMC v8 power steering pump brackets
  101. WANTED :::Cat Condo Tall one
  102. arb bumpers
  103. need spare 33x12.5-15 tire
  104. GM V8 2WD 4speed or 5speed
  105. Passenger fender for YJ
  106. WANTED :: CJ 7 Front Grill and Light Assy.
  107. Need ZJ trans
  108. Thinking about some rims for an XJ.
  109. sand rail frame
  110. Wanted: Dead Fiero parts car(s)
  111. Axle, Dana 35/44 or 8 1/4
  112. Roll Bar for a Comanche
  113. 5 on 4.25 rims
  114. Alternator
  115. yj hardware
  116. Yj Disconnects And A Chevy Conversion Radiator
  117. XJ Pitman Arm **** Found***
  118. YJ Center Console
  119. lookin for a cherokee
  120. camachie box
  121. I need a Beater Truck or Car
  122. Wanted WJ Rims 15" 4 - 4.5 BP
  123. Welding / Fabrication Help
  124. HEI distributor 350v8
  125. Parts Or Vehicle In Michigan
  126. car trailer
  127. exhaust manifold or header for a 99 tj
  128. YJ Passenger Side 1/2 Door Hinge
  129. spare 38 or 38.5 tire
  130. I need a aw4 shift solenoid
  131. 2002 Ford Ranger Fuel Door
  132. Lighter Parts
  133. CJ front fenders
  134. Wanted 33/12.5/15 BFG mud or all terrains
  135. Chevy 60 Front 14 bolt - Trade for Rubicon Axles
  136. Looking For 5 Canyon Style Rims For My Tj
  137. Rubicon Express Soa Springs
  138. Toyota High Steer Wanted
  139. Longfields
  140. Wanted 4bt diesel either complete engine or step van
  141. late 70ish to early 80ish CJ power steering setup
  142. old 5th wheel camper
  143. Wanted Trailer Axle 3500# with Brakes
  144. Drive Side TJ Mirror
  145. 35x15 boggers
  146. 8.8 explorer parts
  147. small flat bottom boat
  148. gas tank for 91 Comanche
  149. TJ front drive shaft (for my Rubi)
  150. wanted wrangler 1991-1995 inline 6 man.
  151. Want to rent: Two place trailer non-fifth wheel.
  152. 3.73 gears and carrier for cj dana 30
  153. found parts please delete
  154. Dog Training Collar (Shock Style)
  155. Ford 8.8" backing plate/caliper mounts
  156. D-30 3.73 gear
  157. TJ Front windshield wiper parts
  158. Looking for a fiberglass dune buggy
  159. WTB 01 jeep cherokee
  160. WJ RIMS 5 on 5 bp 15xwhatever
  161. 6 Point Cage in my Fiero
  162. 3 Wheeler or quad CHEAP!
  163. Rear Axle 60/44 with 513 gear.
  164. Factory TJ front sway bar
  165. winch plate for yj
  166. dana 30 w/ 355
  167. WTB:16s 8lug
  168. 4.3 Vortec Engine
  169. i need ceap 33" r15 tires
  170. Need ASAP: Toyoya Rims
  171. Geo Tracker ash tray, suspension stuff, and a tire cover
  172. WJ boster, master, and WJ/ZJ prop valve
  173. wanted G M C sierra light bar/roll bar
  174. WTT Full YJ Hard doors for hard half doors
  175. WTB/T: Hitch Mount Cargo Rack
  176. TJ Drop Pitman Arm
  177. YJ Tub
  178. 4.5" TJ springs
  179. Thunder Tiger EK4 monster truck or any rc stuff
  180. locker for dana 44
  181. Nice Aluminum Open Car Trailer
  182. Driver side 10 bolt or waggy 44 flat top knuckle *found* thanks
  183. 72 - 75 CJ Swinging brake / cluthc pedals
  184. Parts for a Mitsi Montero
  185. Dana 35 locker
  186. need 1 39 irok or something close for a spare.
  187. 1997 Wrangler TJ complete front differential
  188. 95 xj frt swaybar links
  189. Jeep TJ np231 output shaft
  190. someone to set up gears for my toyota 3rd members.
  191. hubs,shafts,top,doors,hood,and lots more!
  192. WTB: ONE good 235 75 15 BFG All Terrain for a SPARE
  193. Need Tow Bar
  194. Plasma cutter
  195. Add-A-Leaf for my S10, or ext cab 4x4 leaf pack
  196. 39.5x15x15 TSL Swamper & 35x16x15 Bogger WANTED...Also Aluminum Rims
  197. I need one or two 35" bfg mud terrain
  198. 4" lift Coils for TJ
  199. running forklift for less than $1000
  200. Tracker Drivers Door
  201. CB radio
  202. info on a top
  203. Pressure Washer
  204. shop tables
  205. tires cheap or wheels and tires cheap
  206. Dana 300
  207. looking for cheap beater 4x4 anything
  208. 700R4 to Dana 300 adapter
  209. Bearing for np205
  210. YJ Parts
  211. h2 rims
  212. Ranger 2.8L C5 flex plate and starter
  213. trans mount
  214. I need an Idler Pulley
  215. Wanted a track bar
  216. WTB: 87 Toyota PU/4 rnr fuel door
  217. chevy dually wheels ** found**
  218. need a dana 44 axle shaft
  219. Wtb: Cutting Torches
  220. wtb 87-up Gm HEI
  221. WTB--YJ--Fenders--windshield hinge.
  222. Paddle tires for dunebuggy
  223. lookin for some old chevy parts
  224. car hauler
  225. 97+ XJ Outside Mirrors
  226. 19" Snapper snow blower auger
  227. couple barn cats
  228. 89 beretta parts
  229. kayaks
  230. wanted 4 31or32" tires
  231. Rim Wanted!! 15x8 5x4.5 Like Eagle 058
  232. Toyota parts -
  233. TJ Windhsield frame & CJ tail gate wanted
  234. 12-14 ft open atv/snowmobile trailer
  235. Early CJ5 top and seats
  236. Straigh axle conv. kit!!!
  237. wanted to buy new beater for the mounds
  238. ford pickup or bronco
  239. AMC 20 4:56 gears and carrier
  240. 5 on 4.5 wheels
  241. np435 out put shaft
  242. chev flywheel and pressure plate
  243. racing harnesses
  244. 2"' square steel tube
  245. 30-33" mud tires for a 15" rim
  246. TJ Green Fender
  247. Need a 4wd 700r4 for a 1989 Chevy K-1500, 350 tbi
  248. 97 to 01 XJ Front Clip and Rear Hatch
  249. heater control unit 99 Tj
  250. bad tj fuel sender
