Wanted [Archive] - Page 32 - Great Lakes 4x4
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
  1. 2 35x12.5x15 tires
  2. 15 x 10" wheels 5 on 4.5, STEEL
  3. hi looking for a lift for 91 jeep xj 2door 4x4
  4. 2" trailer hitch wanted
  5. WTB: waggy D44 Axles!!
  6. Western Plow
  7. Factory Tow Hooks front and rear 97 TJ
  8. Spare 33" mud terrain
  9. found
  10. W.T.B. 4-5 POINT harnesses
  11. Wtb Yj Parts
  12. Transmission For 94 Zj W/V8 And Front Pig
  13. wtb asap front axle for a 97 cheroke laredo
  14. 302 timing cover
  15. 60 gears,carrier, and drive flanges
  16. Wanted cj soft doors
  17. 4x4 Quad under $3000..
  18. Side Marker/Mirror
  19. (4) 285/75/16's for tow rig
  20. need tail gate
  21. **FOUND*** Ranger 5 speed M5OD
  22. i need a pittman are drag link
  23. doors
  24. wanted tranny for an s-10
  25. WTB hydraulic steering valve
  26. 35-36 spare tire, drop pitman arm for TJ
  27. T18 from a CJ
  28. tj rear seat
  29. 242 or 231 T-case
  30. Nice rims wanted....5x114.3 16"+
  31. **Got one**
  32. 16" ford 8 lug rims
  33. Under-dash Wiring for '87-'94 YJ
  34. WTB Seat Slider
  35. tj windsheild frame.
  36. external d60 drive flang
  37. cheap to free old chevy 4x4
  38. wanted GM NV4500 5 speed transmission.
  39. 95 F250 steering column, driver's taillight, radio, pass. headlight, pass seat armres
  40. 6" KC lite
  41. XJ Driver door glass - GOT IT
  42. ax-5 bell housing for my 91 yj
  43. power window switches 91 XJ
  44. Mig welder
  45. 904 or 727 trans
  46. YJ half door latch
  47. (4) 6 lug 15x8 steel wheels
  48. 17 inch rims 5 on 5 anything
  49. rear soft top window
  50. 31x10.5x15 AT
  51. stock chevy 1/2 ton rear leaf springs.
  52. Need steering column for '95 YJ
  53. 8 lug 15x8s. trade for 15x10 5on 5.5
  54. wtb...2000 tracker soft top
  55. clean plate steel 1/4 thick or more
  56. need front bumper brackets for my 78 chevy
  57. need an 8.8 w/4.10's
  58. Weight Bench / Weights
  59. Good E4OD Trans for 2WD Diesel
  60. Welder
  61. xj rims wanted
  62. sway bar
  63. Cylinder head - 98 XJ 4.0
  64. Looking for Car Hauler purchase or trade---pics added
  65. 4x4 gas rc truck
  66. Dana 30 3:73 REVERSE ROTATION gears
  67. VW engine
  68. Dana 60 parts..
  69. 208 Ford Or Dodge T-case
  70. WTB wrangler fuel tank
  71. Found
  72. wtb: yj chrome grill overlay
  73. dodge big block 400 dist.
  74. WTB GTP Supercharger
  75. Overhead garage door (single width, insulated)
  76. heim joints or radius arms for rat rod.
  77. WTB YJ Fenders
  78. Wanted: Snow plow blade only or full setup for '98 Ranger or any size that will work.
  79. Dana 300 Jeep Shifter and Knob
  80. wtb 5.2 engine
  81. Car Hauler to Rent
  82. *Done* Vehicle transport ASAP: White Lake to Novi (14 miles)
  83. 14b/d70 srm hubs
  84. rear axle for jeep grand cher.
  85. YJ Fender, misc
  86. wanted 454 TBI unit and wiring harness
  87. Explorer/ ranger rims
  88. Wanted BBC Intake manifold.
  89. roller tool cart/box
  90. toyota axle wanted
  91. WTB 700R4 and Chevy Np231
  92. Parts for 94 chevy cheyenne 2500
  93. Welder wanted
  94. 17" jk wheels
  95. xj computer
  96. Long Shot - M151 Tire - NDCC 700x16
  97. MJ or 2 door XJ wanted
  98. 38 or 38.5 Tire
  99. delete found
  100. WTB Dana 30 Spring Perches
  101. Half Shafts!!!!!!.
  102. Fuel check valve
  103. tires 28-30" m/t or a/t
  104. Snowmobile Track
  105. gas tank for 1986 cj7
  106. 16X10 8x6.5 Lug wheels
  107. 351 windsor with 4wd tranny
  108. (1) 15" XJ Steel wheel
  109. older pickup truck, 4x4, EFI, auto trans
  110. Manual Hubs 93 F250
  111. Looking for 78-79 f250-f350
  112. gm 10 bolt locker
  113. cheap 94 or newer dodge truck
  114. Black GM Truck Hood ('88-'98)
  115. 6 lug 14 bolt rear axle
  116. 82 CJ7 Axles or Gears (4.10 or 3.73)
  117. alternator bracket
  118. Yj signal stock or column
  119. Anyone near Lansing with good tube bender
  120. 258 P/S Pump bracket
  121. Windows 2000 or newer Install disc
  122. a few things for my Jeep (updated)
  123. ford 9 Inch
  124. Dash dimmer switch for a YJ
  125. wings tickets for new years eve
  126. Need Car Asap
  127. lookin for drive shaft
  128. flat bed for super duty short bed (fab work)
  129. Wanted Black Spare Spare Tire Cover Says Jeep On It
  130. looking for junk yard along 127 btw ohio and lansing mi
  131. 39.5 or 42 TSL's
  132. Boat shrink wrap. I need a bunch. 1440 square feet.
  133. Need YJ 4.2 engine mounts, Trans crossmember, PS Gearbox, TF999 trans and NP231 case
  134. Final Fantasy VII (7) for PS1
  135. WANTED!!! 91-94 Ford explorer 4dr
  136. 88-99 chevy parts
  137. 4"toy rear leafs
  138. front axle shafts
  139. looking for a set of axles
  140. The office season 2
  141. Wanted: Tamiya TA02 S-10 or F-150
  142. Looking for two Jeep rims 5x4.5
  143. wanted 5 canyon style rims for my 1997 tj
  144. TJ dark grey or black full center console
  145. TJ Steel Bumper
  146. 70's ford high pinion dana 44
  147. jeep liberty wheels
  148. Christmas Lights
  149. HP Dana 30 Locker
  150. 8.25 lsd or locker
  151. yj fender and hood
  152. ZF five speed
  153. tire rack/rear bumper combo for cj7
  154. 4.0 HO Engine
  155. 35s or bigger
  156. WTB headers for a 88 bronco
  157. cj axels or f150
  158. Haul from MI to AZ Cancelled Delete
  159. 33lb Aluminum Propane Tanks (Fork Lift tanks)
  160. Flat fender body
  161. Zj brush guard or someone that can make a nice one
  162. camper windows
  163. Cherokee Coils
  164. Lawn tractor
  165. 89 gmc serria
  166. sheet metal or sheet AL
  167. Empty wine or liquor bottles
  168. Goose/Duck Decoys
  169. 92 camaro parts
  170. small 4x4 dodge
  171. Used 3" lift Coil over shocks
  172. 2.5L Jeep Distributor
  173. i6 4.0 computer
  174. 727 and tcase
  175. Wanted: Extra Tall Enclosed Car Hauler
  176. Double Cardan Drive Shafts
  177. 1997 era Zuk 1.8L coils (coil-on-plug style)
  178. 96- XJ Gas Tank - FOUND
  179. Looking for a 2-3 inch lift of a S10
  180. 96-97 Pontiac Grand Am Hood
  181. Chevelle axle. 10 bolt with 8.5 ring gear or a 12 bolt.
  182. stock swaybar links
  183. John deere sled parts
  184. TJ/XJ/ZJ/MJ stock Upper front control arm
  185. spring spacers for tracker/sidekick
  186. Gas saver
  187. FOUND ---Working laptop, old POS
  188. WTB: class III trailer hitch for 98 Tahoe *FOUND*
  189. 33" MTR's and maybe some wheels
  190. 17" 5on5.5" rim, any style condition?
  191. dana 80
  192. YJ soft top for full doors, and full doors
  193. NP 205 Rear Output Shaft
  194. lifted tj
  195. D-60 front spindle nuts for 78-79 ford front
  196. need electric fans or fan shroud
  197. Old CHEAP Steel Snow Plow
  198. T case for a 2000 TJ
  199. ATV snow plow wanted
  200. Oldsmobile engine
  201. 88-98 full size chevy tail lights
  202. Looking for Either a TJ or YJ
  203. Chainsaws what you got dead or alive?
  204. Fender mounts for Coolant and wiper fluid Res
  205. wanted - rear bumper step cover for 97 K1500
  206. Looking For Rubicon Rims Set Of 5 If Possible
  207. TJ sun visors
  208. tj fender flare cutout pattern
  209. TJ sound bar/speakers
  210. Kyosho Jet Stream 1000
  211. amc 727 flex plate need!
  212. speedo cluster for 95 yj
  213. wanted asap 94 yj fuel pump and sender
  214. Dana 30 with 3.73 gears
  215. 2.5 cyl yj exhaust manifold
  216. WTB your Grandma's Wrangler
  217. 4 stroke dirt bike
  218. TJ Rear Flares
  219. 231 T-case for 4cyl/5spd TJ
  220. (1) BFG M/T KM 35x12.50x15r
  221. wtb: muscle car
  222. Need Yj Front Drive Shaft!!!!!
  223. 84 cj7 radiator
  224. please deleate
  225. Jet Ski-standup
  226. Need Covered Trailer for sound equipment (4x8ish)
  227. cb antenners wanted
  228. Nutmeg Dash Pad For CJ
  229. Nutmeg Front Carpet for CJ with Automatic Trans
  230. Front Clip.
  231. Black Leather CJ Laredo Steering Wheel
  232. Harley Davidson Carb 40MM
  233. wanted: help with a d44 rebuild (gear setup)
  234. N64 Stuff
  235. Trailer wanted
  236. gas can
  237. 4x4 ford tranny... ranger
  238. d44 brakes...
  239. 9? xj with 2.5
  240. gears
  241. Oxy-Acetylene torches.....
  242. Weight bench, free weights and elliptical machine
  243. jeep grand cherokee
  244. wanted stock xj DD
  245. looking for Jeep Add a Leaf for a 89 xj 3in lift
  246. 15x10s wanted
  247. D30 locker of any kind
  248. Locker
  249. TJ front shaft
  250. 17" JK wheels 5x5 with 4.5 BS or spacers
